Micromax General Micromax phones discussion, firmwares, solution, root, help |
01-25-2013, 14:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 758310 Status: Offline Sonork: 100.1601610 Thanks Meter: 71 | Micromax a65 hard reset [guide] power and volume up for 10 sec then press power for android hiden menu select factory reset form list then press power for select enjoy for hang pattern unlock |
The Following User Says Thank You to b12345 For This Useful Post: |
08-16-2013, 10:44 | #4 (permalink) |
Junior Member Join Date: Feb 2011 Location: fatehpur (up)
Member: 1514527 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Micromax a65 hard reset [guide] Press and hold power and volume up for 10 sec then press power for android hiden menu select factory reset form list then press power for select enjoy for hang pattern unlock yes good thankssssssssssss |
11-04-2013, 11:45 | #5 (permalink) |
Junior Member Join Date: May 2010 Location: india,darbhanga
Member: 1301266 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Press and hold power and volume up for 10 sec then press power for android hiden menu select factory reset form list then press power for select enjoy for hang pattern unlock |
12-16-2013, 09:13 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hyderabad INDIA
Member: 892484 Status: Offline Sonork: not using Thanks Meter: 916 | Press and hold power and volume up for 10 sec then press vol up key to see android hiden menu don't press vol up again go to wipe with vol down key press power for select now all is done |
The Following User Says Thank You to chinnivardan For This Useful Post: |
01-10-2014, 09:53 | #9 (permalink) |
Crazy Poster Join Date: Jul 2012 Location: india Age: 40
Member: 1780708 Status: Offline Sonork: 62645 Thanks Meter: 7 | Micromax a65 hard reset [guide] Press and hold power and volume up for 10 sec then press power for android hiden menu select factory reset form list then press power for select enjoy for pattern unlock 100 % tested |
01-10-2014, 10:20 | #10 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Islamabad / Riyadh Age: 58
Member: 90733 Status: Offline Thanks Meter: 39 | Touch pad senser problem If this type of set have touch pad senser problem then which method should be applied (Replaced the senser from the other board) Regards |
04-01-2014, 08:23 | #14 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Lucknow, Uttar Pradesh,India Age: 31
Member: 1856209 Status: Offline Sonork: 100.1626211 Thanks Meter: 44 | New method..... Using fast boot.. MICROMAX A65 SPD 8810/6820 PATTERN/RESET GMAIL TRY THIS METHOD POWER OFF MOBILE THEN PRESS VOLUME '-' & POWER KEY AT SAME TIME FOR BEING THE DEVICE IN FASTBOOT MODE.. REMEMBER ALL DRIVERS ARE TAKEN NO YELLOW ICON IN DEVICE MANAGER NOW USE ANDROID MULTI TOOL 1- TYPE '7' FOR CHECKING DEVICE CONNECTION 2- NOW '8' FOR WIPING USER/CACHE DATA 3- PRESS '9' TO EXIT FASTBOOT MODE TO NORMAL... NOW YOU ARE DONE...... PRESS THANKS IF IT WORKS FOR YOU.. B.R sachin.mishra |
The Following User Says Thank You to sachin.mishra For This Useful Post: |
