Micromax General Micromax phones discussion, firmwares, solution, root, help |
02-23-2013, 11:22 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: nashik maharshtra
Member: 1532854 Status: Offline Sonork: 100.1639591 Thanks Meter: 107 | micromax p275 hard reset need hlp me |
03-05-2013, 06:42 | #2 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | Here For You.. Please Try This Way And Post Ur Result Bro.. 1.Shut down your phone. 2:Press Volume up button, Menu button and Power on button at same time and hold up for 10 secs. Your phone will start and a screen appears with the android sign and after some time few options 3:Use your volume button for scrolling. 4:Select factory reset option using the power button.It will reset your tab. 5:Now select reboot option or restart your tab. Note: Factory reset will erase all data except on the SD card. This takes the tab to the state when you unpacked it. Good Luck |
03-12-2013, 16:01 | #5 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
http://forum.gsmhosting.com/vbb/f811...5/#post9248727 br, azam | |
03-12-2013, 16:06 | #6 (permalink) | |
Member: 547368 Status: Offline Thanks Meter: 254 | Quote:
but,he have userlock-password problem. Do you think its fare to restore it insted of reset it ? | |
03-12-2013, 16:32 | #7 (permalink) | |
Note: I post this coz many users reported that they can't hard reset their tab br, azam | |
03-12-2013, 17:14 | #8 (permalink) | |
and reset is safe and in this case no need update,then why you misguide him ? you can see issue by update here also here .....etc hope you next-time be careful | |
03-26-2014, 11:35 | #10 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1656503 Status: Offline Thanks Meter: 0 | Hello friends if u are pattern locked then i think there is no need of any tool,here is the easier way: 1) Power ON your tablet. 2) Now after its turned ON just hold down the "HOME BUTTON" & at the same time press "RESET" switch with some type of pin or something in the hole. 3)Hold it for 10secs and release. 4) Now your tablet will reboot n get a option of reset tablet. 5) Jst tap it & U r done.. Say thanks if u like the solution.. |
