Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
04-07-2011, 21:31 | #16 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: М.o.s.c.o.w.
Member: 649775 Status: Offline Thanks Meter: 242 | Quote:
04-08-2011, 11:40 | #17 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 202954 Status: Offline Thanks Meter: 32 | MB200 unlock free usin USB cable, for all good people of this FORUM Hi friends, here are how to unlock Motorola MB200 using USB cable mb200fls.rar flash mb200 RSD Lite 4.9.rar RDS Lite Rootmb200.zip Root mb200 mb200sd.rar mb200 sd files ASTRO_File_Manager_2.5.2.rar Astro file MB200 UNLOCK 1.- Unzip the the zipped files on C: 2.- You will need a micro sd card to put into the phone to unlock, need to load in to microsd card the 2 files that are in MB200sd folder, after unzipped files and MB200sd files loaded in microsd card, put micro sd card to phone, in Phone menu go to Settings, Aplications, Unknowresourses, and click it (activate), go now to Development and activate too USB Debug, 3.- With battery full charge, connect the phone to PC with Original usb cable and Flash it with Flash file using RDS Lite program. 4.- After Flash with phone power on, create a Blur account 5.- Go to MB200root folder and run Superoneclick.exe program and click on Root button, ptogram will ask you if you have and OS higher than 2.0 you click yes and let to program finish (success) 6.- After root phone install instalarapp.bat file, (file is in the MB200root folder too) 7.- Reboot the phone, go to installed App, (better Terminal) and choose the NOT NOW option, the scree will appears like Dos OS, click with your finger on screen and will see the Keyboard, write SU and click enter, will ask you if confirm to be a SUPER USER, click allow, then the $ will change for #, after the # write the follow: Insmod /sdcard/memdump.ko ENTER Check well between insmod and /sdcard have one space If there is any mistake go to phone home page and like if you are going to make a call writhe the follow: #073887* and will ask for unlock code, just put 12345678 click UNLOCK and ready, enjoy your Unlocked MB200 Hope you can enjoy this. BR alexsl63 |
The Following 5 Users Say Thank You to alexsl63 For This Useful Post: |
04-08-2011, 11:45 | #18 (permalink) |
Member: 202954 Status: Offline Thanks Meter: 32 | mb200 real unlock by USB cable MB200 unlock free usin USB cable, for all good people of this FORUM Hi friends, here are how to unlock Motorola MB200 using USB cable mb200fls.rar flash mb200 RSD Lite 4.9.rar RDS Lite Rootmb200.zip Root mb200 mb200sd.rar mb200 sd files ASTRO_File_Manager_2.5.2.rar Astro file MB200 UNLOCK 1.- Unzip the the zipped files on C: 2.- You will need a micro sd card to put into the phone to unlock, need to load in to microsd card the 2 files that are in MB200sd folder, after unzipped files and MB200sd files loaded in microsd card, put micro sd card to phone, in Phone menu go to Settings, Aplications, Unknowresourses, and click it (activate), go now to Development and activate too USB Debug, 3.- With battery full charge, connect the phone to PC with Original usb cable and Flash it with Flash file using RDS Lite program. 4.- After Flash with phone power on, create a Blur account 5.- Go to MB200root folder and run Superoneclick.exe program and click on Root button, ptogram will ask you if you have and OS higher than 2.0 you click yes and let to program finish (success) 6.- After root phone install instalarapp.bat file, (file is in the MB200root folder too) 7.- Reboot the phone, go to installed App, (better Terminal) and choose the NOT NOW option, the scree will appears like Dos OS, click with your finger on screen and will see the Keyboard, write SU and click enter, will ask you if confirm to be a SUPER USER, click allow, then the $ will change for #, after the # write the follow: Insmod /sdcard/memdump.ko ENTER Check well between insmod and /sdcard have one space If there is any mistake go to phone home page and like if you are going to make a call writhe the follow: #073887* and will ask for unlock code, just put 12345678 click UNLOCK and ready, enjoy your Unlocked MB200 Hope you can enjoy this. BR alexsl63 |
The Following 7 Users Say Thank You to alexsl63 For This Useful Post: |
04-12-2011, 04:37 | #22 (permalink) |
Freak Poster Join Date: May 2008 Location: Santa Fe, Argentina Age: 48
Member: 764418 Status: Offline Sonork: 100.1593578 Thanks Meter: 45 | hello, just wanted to know where I can get or should I charge flash to release a logical MB300 and that the procedure is the same. thanks the_phant |
04-13-2011, 00:08 | #24 (permalink) |
Insane Poster Join Date: Jun 2006 Location: Portal GSM team Age: 36
Member: 293419 Status: Offline Thanks Meter: 29 | yes this process working in mb200, mb300, mb501, only the firmware and .ko are diferents for each model test 100% tested with 2pcs 100% working |
04-25-2011, 23:32 | #27 (permalink) |
Junior Member Join Date: Nov 2007
Member: 627068 Status: Offline Thanks Meter: 6 | starie, you can install astro file manager and terminal from sd card with application appinstall, you can download from market later proceed to steep 7, it worked for me and thanks for all. |
The Following User Says Thank You to JAGJ For This Useful Post: |
04-28-2011, 06:49 | #29 (permalink) | |
Member: 202954 Status: Offline Thanks Meter: 32 | Quote:
adb devices @echo si ve la serie del mb200 esta ok pause adb install c:\rootmb200\astro.apk adb install c:\rootmb200\terminal.apk pause you have to install rootmb200 folder on C:, hope you can do it. BR alexsl63 | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
