Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 09-02-2013, 15:20   #1 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,228
[MT6575/6577/MT6572/MT6582/6589]MTK Android Based Phone IMEI Write Tool
IMEI&SN Writer
100000% Working & Tested With MT6572 & MT6582
Download DB File for MT6572, MT6575, MT657 & MT6589
Download from here 4shared folder - DB file
MT6582 DB File Is Here
Warning
Only For Repair Original IMEI
Br,
azam
The Following 29 Users Say Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Old 09-02-2013, 16:12   #2 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,042
where is db file can share that also
The Following 2 Users Say Thank You to akhil_bbsr For This Useful Post:
Old 09-16-2013, 16:08   #3 (permalink)
ASSANDHCDMA's Avatar
Member: 1169871
Thanks Meter: 175
bro select db from set is og flash file.......
The Following User Says Thank You to ASSANDHCDMA For This Useful Post:
Old 09-23-2013, 13:24   #4 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,079
scr file not work in this tool
this solution not work in mt 6572
The Following User Says Thank You to Umesh_Arora For This Useful Post:
Old 09-23-2013, 13:30   #5 (permalink)
Member: 505794
Thanks Meter: 2,228
i have 6572 100% solution
10000% tested over 100pcs,
If any one face any problem post here with screenshot.
Br,
azam
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Old 09-23-2013, 13:48   #6 (permalink)
Member: 1532854
Sonork: 100.1639591
Thanks Meter: 105
sir i need hlp for micromax a67 pattern lock problem!
pls hlp me sir thanks in advance!
Old 09-23-2013, 14:00   #7 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 135
Steps:
1,Please power off the phone
2,Then plug in the USB cable
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Enter to ModemMeta Start:
Enter to ModemMeta PASS
Start Write IMEI:
WriteIMEI_1: 911202151313301
WriteIMEI is OK !!!
From ModemMeta to APMeta Start:
From APMeta to ModemMeta PASS
It is over !!
sir after write ok , phone restart again and imei goes same as old one ,mt6572
The Following 2 Users Say Thank You to sunil1670 For This Useful Post:
Old 09-23-2013, 15:09   #8 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 135
nokia care plzz help up the thread
Br,
azam
Old 09-25-2013, 17:30   #9 (permalink)
Member: 960366
Thanks Meter: 4
works for mt 6572 100 %
The Following User Says Thank You to messiaah For This Useful Post:
Old 09-26-2013, 10:41   #10 (permalink)
sonualok's Avatar
Member: 1738848
Sonork: 100.1640328
Thanks Meter: 500
Post your screenshot....help others
guide other also
The Following User Says Thank You to sonualok For This Useful Post:
Old 09-26-2013, 14:47   #11 (permalink)
Member: 739546
Thanks Meter: 15
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Enter to ModemMeta Fail:
It is over !!
MT 6589 imei write failed
The Following User Says Thank You to mahesh712 For This Useful Post:
Old 09-28-2013, 06:05   #12 (permalink)
Member: 138265
Thanks Meter: 50
Br,
azam
I9500 MT6572 wirte ok but imei no chage
Old 09-28-2013, 11:30   #13 (permalink)
ivanrommel's Avatar
Member: 144777
Sonork: 100.111515
Thanks Meter: 99
works perfect for mtk 6577 model: skk a5
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Start Write IMEI:
WriteIMEI_1: 359310045241189
WriteIMEI_2: 359310045241197
WriteIMEI is OK !!!
It is over !!
thanks man!!!.....
Old 09-29-2013, 10:37   #14 (permalink)
unlocker_786's Avatar
Member: 711273
Thanks Meter: 78
hi
thanx for reply all of u guys my s4 i9500 mt6572 problem is solved and my imei is repaired by dis tool and thanx to dat who give me solution this not possible yet on volcano but dis tool make my problem solve so i give dat linkhttp://forum.gsmhosting.com/vbb/f606/mt6572-6575-6577-6589-mtk-android-based-phone-imei-write-tool-1708731/#thisthis tool repaired imei successfully as u see in below pic even serial no an etc
i thanks to nokian care
The Following 2 Users Say Thank You to unlocker_786 For This Useful Post:
Old 09-30-2013, 11:46   #15 (permalink)
ashakaass's Avatar
Member: 1695196
Sonork: 100.1623915
Thanks Meter: 504
mito tab t520 mtk 6577
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Start Read SN:
ReadSN: MT012345678901234567
Read SN is OK !!!
Start Write IMEI:
WriteIMEI_1: 111111111111111
WriteIMEI_2: 222222222222222
WriteIMEI is OK !!!
Start Read IMEI:
ReadIMEI_1: 111111111111111
ReadIMEI_2: 222222222222222
ReadIMEI is OK !!!
Read BT Address Start:
ReadBT: de1246662867
Read BT is OK !!!
Read WIFI Address Start:
ReadWIFIAddr: 000000000000
Read WIFI Address is OK !!!
Read SW Version Start:
GetSWVer: ALPS.JB.MP.V1.22
Read SW Version is OK !!!
Read Internal SW Version Start:
GetSWVer_Internal: GM1503_M10_V1.1
Read Internal SW Version is OK !!!
It is over !!
The Following 2 Users Say Thank You to ashakaass For This Useful Post:
Page generated in 0.54966 seconds with 8 queries
