08-30-2014, 13:02 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Need china htc c9600 spd 6820 flash file http://4.bp.********.com/-3dbl3RZJv0...600-SC6820.jpg After formate phone auto restart |
08-30-2014, 13:26 | #3 (permalink) |
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | [IMG]http://4.bp.********.com/-atTueYyjp0c/U6Ug3y7aYMI/AAAAAAAAAMA/c1y6YWtwQT0/s1600/Miracle.jpg[/IMG] [IMG]http://4.bp.********.com/-3dbl3RZJv0I/U6Ugq3BhZAI/AAAAAAAAAL4/8moJrNZlSHU/s1600/C9600-SC6820.jpg[/IMG] |
08-30-2014, 13:28 | #4 (permalink) |
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | need flash files china htc c9600 >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM50 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
09-01-2014, 14:25 | #5 (permalink) |
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM50 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 All Done... |
07-05-2015, 10:19 | #6 (permalink) |
No Life Poster Join Date: Dec 2013 Location: algeria
Member: 2081857 Status: Offline Sonork: 1000.2 Thanks Meter: 38 | me too i need this firmware i have flashed with one in need rom c9600 spd sim 2 but no display yours Last edited by ..::Nokian CareŽ::..; 07-06-2015 at 05:01. Reason: Contact info removed |
