Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
12-23-2014, 03:53 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2315593 Status: Offline Thanks Meter: 0 | problem pattern lock screen i have samsung galaxy gt-i8190 the problem is pattern lock screen also -no usb debugging enabled -no combination button for recovery mode or download mode only a mini recovery mode(just power button+home) -no root /bootloader acces when power on the phone show the lock pattern also button for emergency call only and if i make a wrong scheme 5time only after 30sec i can retry and if i make a wrong scheme 5time also make 30sec for another try so no google account to help no other help i ask what i can do in my case please help i am newbi also this is my first post so i hope this forum can aids me |
12-24-2014, 06:04 | #3 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Forgotten pattern lock. Forgotten user code. Forgotten phone code. See your phone repair steps : Turn off your Samsung android device. Release any “sim card or sd card” in your phone. Press & Hold “Vol+ key,Home key and Power key”. When you see in your mobile screen “android downloading mode”,Then release all hold key. You got “Android system recovery mode”,Use “Vol – key” and select “wipe data/factory reset” and press “power key” to confirm. Again use “Vol- key” and select “Yes — delete all user data” and press “power key” to confirm. After complete the hard reset, select “reboot system Now”, And press “Power key”. Now your Device will reboots. |
The Following User Says Thank You to ALI_MAFIA For This Useful Post: |
12-24-2014, 06:14 | #4 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | download file here-HARISHhttp://www.4shared.com/rar/vIf...I8190tar.html? open odin 1.87 in pda select this file flsah patternlock remove done |
12-24-2014, 06:25 | #5 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: bharat Age: 35
Member: 2276401 Status: Offline Thanks Meter: 98 | Use miracle box then select port then factery reset easy without flash Quote:
12-24-2014, 09:15 | #6 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: PaKiStAn & KSA
Member: 2023768 Status: Offline Sonork: 100.1661054 Thanks Meter: 76 | Quote:
frist check is your device gone in download mode or not if not then its must be clone model check chip inside it mostly mtk and spd and then do service wit chinese servic boxes if gone in download mode its samsung orignal model search on google about that model hard reset hunderds of website have hard reset soluation | |
