qmobile a10 hard reset by shaikh mushahid Procedure Step One Do not panic! Turn Off you mobile phone. Step Two Keep pressing both the volume keys on the left and while doing so, press the power button. This will start the mobile in Factory/Recovery Mode http://www.moremag.pk/morepics/2013/...a10.jpg?994aa0 Step Three Select Recovery Mode by pressing Volume Up key http://www.moremag.pk/morepics/2013/...ode.jpg?994aa0 Step Four Using the Volume Down key, come on the fifth (5th) option from the top which says “wipe data/factory reset” http://www.moremag.pk/morepics/2013/...jpg.jpg?994aa0 Step Five Select the option by pressing the Option Touch Button on the bottom left corner of your Qmobile NOIR http://www.moremag.pk/morepics/2013/...btn.jpg?994aa0 Step Six The mobile will inform that this step would erase all the user data and that it cannot be undone. Again, do not panic. You don’t have any other option left. Using the Volume Down Key, select the eighth (8th) option which says “Yes – delete all user data” http://www.moremag.pk/morepics/2013/...set.jpg?994aa0 Step Seven Select the option by pressing the Option Touch Button on the bottom left corner of your Qmobile NOIR Step Eight The mobile will show on the screen “Wiping data… Formatting /data… Formatting /cache…” http://www.moremag.pk/morepics/2013/...ipe.jpg?994aa0 Step Nine Just sit back and relax while your Qmobile NOIR is being factory reset and rebooted. After reboot, the mobile will start as if you just unpacked it and are using it for the first time. |
Qmobile Tuch Not Working any other solution please ? |
http://forum.gsmhosting.com/vbb/f606...-help-1737372/ |
a10 lite did not work always ... |
when press down volum key then wipdata setting not appear ........... |
