Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Q-Mobile
Old 07-11-2013, 14:27   #1 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 972
qmobile a10 hard reset by shaikh mushahid
Procedure
Step One
Do not panic!
Turn Off you mobile phone.
Step Two
Keep pressing both the volume keys on the left and while doing so, press the power button. This will start the mobile in Factory/Recovery Mode
Step Three
Select Recovery Mode by pressing Volume Up key
Step Four
Using the Volume Down key, come on the fifth (5th) option from the top which says “wipe data/factory reset
Step Five
Select the option by pressing the Option Touch Button on the bottom left corner of your Qmobile NOIR
Step Six
The mobile will inform that this step would erase all the user data and that it cannot be undone.
Again, do not panic. You don’t have any other option left.
Using the Volume Down Key, select the eighth (8th) option which says “Yes – delete all user data”
Step Seven
Step Eight
The mobile will show on the screen
“Wiping data…
Formatting /data…
Formatting /cache…”
Step Nine
Just sit back and relax while your Qmobile NOIR is being factory reset and rebooted.
After reboot, the mobile will start as if you just unpacked it and are using it for the first time.
The Following 5 Users Say Thank You to shaikh.mushahid For This Useful Post:
Old 11-17-2013, 07:28   #2 (permalink)
Member: 1659559
Sonork: 100.1625156
Thanks Meter: 5
Qmobile Tuch Not Working any other solution please ?
The Following User Says Thank You to latif20 For This Useful Post:
Old 11-17-2013, 17:32   #3 (permalink)
Registered User
Member: 1669709
Sonork: 1654655
Thanks Meter: 163
go hear and enjoy.and pres thanx
http://forum.gsmhosting.com/vbb/f606...-help-1737372/
The Following User Says Thank You to kifayatjan For This Useful Post:
Old 08-06-2014, 12:58   #4 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
a10 lite
did not work always ...
Old 10-23-2014, 09:47   #5 (permalink)
Member: 1113899
Thanks Meter: 39
when press down volum key then wipdata setting not appear ...........
Old 12-12-2014, 17:42   #6 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
Originally Posted by .....::::GsmAdeel:::::..... View Post
a10 lite
To select ( wipe delete/factory option ) u need to press menu + return back button same time. in case of A10 lite.
Page generated in 0.13708 seconds with 8 queries
