Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
06-26-2016, 07:52 | #1 (permalink) |
Crazy Poster Join Date: Jun 2014 Location: Mirpur,Dhaka
Member: 2205481 Status: Offline Sonork: 100.1667971 Thanks Meter: 28 | Qualcomm Cpu Phones Unbrick Guide Qualcomm Cpu Phones Unbrick Guide You Can try this on All Brand Phones which is stuck on Qualcomm HS-USB QDLoader 9006 & 9008 Note : This is only a guide and you can give a try but i won't say it would unbrick your phone for sure but there is [50 -50] Chances Requirements: Win32DiskImager Download A working Phone with Root. And mmcblk0.img partition dump from working phone. Procedure For Read mmcblk0 partition * Insert 8gb or 16 gb sdcard * Note your sdcard path 1st so you can use the path while runng command * To View partition Tables adb shell su -c ls -al /dev/block/ * After Running this you can see this partition mmcblk0 in starting and make sure that the partition is available. * Backup your Partition adb shell su -c dd if=/dev/block/mmcblk0 of=storage/sdcard1/fulldump.img * After Done to Copy the dump file to Pc Use this command adb pull /storage/sdcard0/fulldump.img Final Step For Unbrick * Connect card reader with 8gb or 16gb sdcard * Run Win32DiskImager * First select fulldump.img then choose sdcard drive path and click write. * Make sure that you hav fully charged battery. * Insert sdcard and hold Bootloader mode Hardware keys Example: Samsung : Vol Dwn + Home + Pwr Moto : Vol Dwn + Pwr Htc : Vol Dwn + Pwr Try your lucks using this guide and we appreciate if you post success reports and dump files here. Last edited by Dipu Razz; 06-26-2016 at 08:01. |
