Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
07-22-2014, 16:14 | #1 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | [solution] Brom error : s_ft_enable_dram_fail in SP_tools/Mtk hang on logo After Nonstop Hardworking i'm Finaly able to solve few mtk phone And 2 Bricked tablet I learn something Found Few Method to recover Bricked Mtk Finally Sharing If it's help anyone Very common issue In SP tools Tish Error Common issue for Firmware is Unsuitable For phone BUT....... Many time in my personal exp i found same Error After Trying same phone Firmware The Think is That android scatter file is the direction library File to be copied to the chip area Every firmware scatter file contain different target area even thought phone is same model This differences For firmware version if we try update same phone higher/lower version firmware we are unable to downlod firmware to phone by sp tools got same "Brom error type massage , this have another reason why can't write higher/lower firmware last i success to Downlod Higher version firmware in this way I write P1000_v51 by P1000_v53 Stap >1 Select downlod agent" MTK_allinone_DA" Stap>2 Format phone Following pic way stap>3(only for those phone which hang on logo after flash with same phone same version firmware) write same version Firmware again without "userdata" Stap>4 Select Higher version Firmware scatter file and important must select "Firmware update" in this way i solve wallton_symphone hang on logo /before try same firmware many times & samsung clone P1000 dual sim dual standby MTK tablet IMP NOTE : Format will damage phone imei and all i tested to Only MTk6572 cpu based phone & TABLET & I reapir imei by serial no writing tools in meta mode & to write imei database file can be found to org stock rom folder or use universal mtk6572 database file serial no writing tool & letest imei driver can collect from HERE [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] Br_gsm mithun roy |
The Following 7 Users Say Thank You to gsm mithun roy For This Useful Post: |
12-31-2014, 10:24 | #4 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | And what does each image do ? Boot.img : boot.img contains the kernel and ramdisk, critical files necessary to load the device before the filesystem can be mounted. Having a wrong Boot.img on your phone can refuse it to boot ! cache.img Contains the cache data where Android stores frequently accessed data and app components. not really needed and should be unticked when trying to flash a device. Checksum.ini verifies md5 checksum , if you get a checksum error before flashing, just delete it Wink EBR1, EBR2 Are your partitions. 1+2 Means 2 Partitions. You can also edit the size of them , Check out this thread : You are not allowed to view links. Register or Login to view. UBOOT (LK.BIN) U-Boot is an universal boot loader for embedded systems, targeting different platforms including ARM. Uboot and BootIMG are important files on your phone. If your device is not booting or your display is not working ( black or stripes ) , you should reflash and check those files. Logo.bin As the name suggests, this is your bootlogo Happy It can be changed using this tutorial : You are not allowed to view links. Register or Login to view. MBR Stands for Master-Boot-Record. MBR is generally referred to as first sector (size : 512 bytes) of any partitioned drive whereas volume or partition boot record holds code to initiate booting and is invoked by MBR. So in short words, it defines your partitions. Scatter File : Scatter is a file which is used to describe the loads of regions in a specific android device running MediaTeks ARM architecture. Bascially it tells the flash tool where to flash each image. Preloader : this is really important. The preloader communicates with your PC. Itīs needed when you want to flash your device. Due to the preloader your phone should be detected as a port on your pc and should be flashable. Downloading a wrong pre-loader can brick your phone , so be careful ! Never flash the preloader if not needed. There are different states of the pre-loader (like META Mode). Even when you think your phone is bricked, mostly you can revive it. Recovery.img Thats you recovery. It must be "tailored" to each device. You cant flash a recovery image from a different device, but you can create your own CWM recovery using MTK droid tools. Secro.img Is an important file for the baseband and the IMEI. You need to reflash it to rebuild the structure. But anyway you have to restore your IMEI too. System.img As the name suggests, this partition contains the entire Android OS. You can try different system.img from other phones without a problem. just be sure to have a backup when you try them Happy User Data : Contains your personal data (do not share it with a backup) So this partition contains the user’s data like your contacts, sms, settings and all android applications that you have installed. While you are doing factory reset on your device, this partition will wipe out, Then your device will be in the state, when you use for he first time, or the way it was after the last official or custom ROM installation. I hope this helps you to understand the rom structure |
12-31-2014, 10:47 | #6 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | read the thread carefully what the reason of error why error comes .. it can be firmware problem ... flasher problem .. higher or lower version problem |
05-24-2015, 03:57 | #8 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 427344 Status: Offline Sonork: 100.1666688 Thanks Meter: 213 | good job done. we appreciate ur hardwork usually when such type of errors occur i recommend to use box (miracle box )and then problem solved but we never tried to r&d . keep it up |
