Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Spice
Old 03-29-2013, 07:12   #1 (permalink)
Crazy Poster
Member: 1880249
Thanks Meter: 11
spice mi-424 how to hard reset
spice mi-424 how to hard reset???
Old 04-30-2013, 16:05   #2 (permalink)
Member: 1855296
Sonork: 2656786786
Thanks Meter: 3
Turn off your mobile
keep press power+volume up+option button until recovery mode comes
press menu button to bring utility
navigate to wipe data,
press option to select
again navigate to erase option
and press option button to confirm,
it will take some time to ready the phone to use.
The Following User Says Thank You to rahulperfect123 For This Useful Post:
Old 05-01-2013, 17:38   #3 (permalink)
baba_sandeep's Avatar
Member: 931438
Sonork: 1614828
Thanks Meter: 26
The Following User Says Thank You to baba_sandeep For This Useful Post:
Old 05-16-2013, 16:22   #4 (permalink)
SHARMA NEERAJ's Avatar
Member: 419331
Thanks Meter: 86
Question
how to spice mi 424 phone hard reset only vol. and on/off button
Old 05-16-2013, 16:28   #5 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 4,869
format with volcano 100% tested by me
select boot 6820
tick format
b-rate 115200
run
1000000000000% success
mobile on wait 1 min your mobile is ok
The Following 2 Users Say Thank You to Umesh_Arora For This Useful Post:
Old 05-17-2013, 08:57   #6 (permalink)
Member: 419331
Thanks Meter: 86
Question
select boot 6820
tick format
b-rate 115200
run
usb or com or test point becouse i am counnect normal no detected any driver i counnect via usb than need driver if throw usb than plz send usb driver
Old 05-17-2013, 10:34   #7 (permalink)
Member: 419331
Thanks Meter: 86
Question
how to counnect shive volcano box i am try but not detected
Old 05-17-2013, 11:32   #8 (permalink)
Member: 419331
Thanks Meter: 86
problam not solve phone return to custmer
Old 05-18-2013, 17:35   #9 (permalink)
Member: 1248310
Sonork: 100.1641641
Thanks Meter: 4
Old 05-22-2013, 09:44   #10 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 636
Talking
Hi All,
Use Modified Cable For Format This SPD Handset.....
Boot = 6820
B.Rate = 115200
Regards,
Old 05-23-2013, 16:03   #11 (permalink)
Crazy Poster
Member: 1301079
Thanks Meter: 11
which type off modified cable pls explain full process
Old 05-23-2013, 19:19   #12 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 791
sold rx-tx .........open valcano selet 6820 cpu ,then format 100%%%%% done
The Following 2 Users Say Thank You to amit kanpur For This Useful Post:
Old 05-24-2013, 14:12   #13 (permalink)
Member: 1838311
Sonork: 100.1638474
Thanks Meter: 15
thanks bro my problem solved with volcano
Old 05-24-2013, 14:18   #14 (permalink)
Member: 1838311
Sonork: 100.1638474
Thanks Meter: 15
open phone solder rx tx
open volcano select spd tab
select boot 14 6820/8810
select type com(rx/tx)
select baud rate 115200
select format and run
set to factory successfully
100% bypass google acount
tested by me
Old 05-24-2013, 16:11   #15 (permalink)
Member: 1792140
Thanks Meter: 4,869
use 07b jig 100% detact with volcano, no need solder tx rx
The Following User Says Thank You to Umesh_Arora For This Useful Post:
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.40135 seconds with 7 queries
