Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
01-13-2014, 19:26 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Location: Romania Age: 44
Member: 60973 Status: Offline Thanks Meter: 2 | Spreadtrum bml 9500 hard reset If you lost your password or your security code and you can't use your phone anymore, here is the solution: press vol - and power at the same time, and keep it pressed about 10 sec and the on the screen you will see a triangle with the "!" inside. realese the power key and vol - key and press the home (middle) button to enter in recovery menu select reset to factory and after that wipe cache. Tested and worked!!! That's it, hope to help you friends! |
The Following User Says Thank You to KruggerDj For This Useful Post: |
