Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
10-23-2010, 13:15 | #1 (permalink) |
No Life Poster Join Date: Sep 1999 Age: 54
Member: 521 Status: Offline Thanks Meter: 76 | [Tutorial]Gigabyte G1305 / Orange Boston unlock and upgrade to 2.1 with CMLMod 1.5.1 Testet!!!!!OK Tutorial]Gigabyte G1305 / Orange Boston unlock and upgrade to 2.1 with CMLMod 1.5.1 EDIT: Upgrade to CMLMod 1.5 based on Muchtel ROM (below outdated CML 1.4) With this tutorial you sould be able to unlock your Orange Boston (aka GigaByte G1305 Codfish, Apanda A60, WellcoM A88, Vibo A688, Cincinnati Bell Blaze f800, Commtiva Z71, Muchtel A1, Chinavision Excalibur, Motorola Greco, Nexian A890) and install CMLMod 1.5.1 (or 1.4) (by c.martinez.lozano) based on the ROM Muchtel 2.1 (eclair) Main advantages/disadvantages of CMLMod 1.5.1: +Unlocked device (can use any SIM) +Android 2.1 (Eclair) +Root access with Superuser permissions +Preinstalled programms and other features +Easy SD partitioning and more features thanks to the new recovery +Optional App2SD +Processor speed adjustable in a range between 122 and 600MHz (with the possibility to set variable processor speed to have performance and longer battery life at the same time) +Other features: 3 different launchers, flash light, setcpu, app2SD in one click, other preinstalled apps and tweaks =Camera autofocus not working (like on stock ROM) =Different UserInterface (in my opinion better, but that's subjective) -You may loose the warranty on your device -IMEI may change, to restore your original IMEI use the tutorial in my second post -Languages not fully implemented (english is working fully, other languages settable with LocaleSwitch but not fully integrated ) Important!!! There may be the risk of damaging your phone in an irreparable way! Be aware also by installing this ROM you will loose your warranty! I do not take any responsability for the status of your device! I translated the tutorials on htcmania.com Requirements Hardware requirements: -Phone model: Orange Boston (aka GigaByte G1305 Codfish, Apanda A60, WellcoM A88, Vibo A688, Cincinnati Bell Blaze f800, Commtiva Z71, Muchtel A1, Chinavision Excalibur, Motorola Greco, Nexian A890) Edit: never seen a phone with so many different names!!! -PC operating system: Windows XP 32 bit with SP3 and .NET Framework 2.0 and Winrar installed. Do not try with Windows XP working on a virtual machine!!!. Seems to work also on other Windows 32 bit operating. Does NOT work with Windows7 64 bit -USB to micro USB cable (comes with the phone) Software requirements For CMLMod 1.5.1: Firmware Apanda A60 1.6.2 Firmware CMLMod 1.5.1 (this file already contains RUT 1.2.2 and the Phone drivers) Additional for CMLMod 1.4 (Outdated): RUT 1.2.2 Phone drivers Firmware Apanda A60 2.1.9 Firmware CMLMod 1.4 Tools like adb, fastboot, etc Ready to start! make sure you have enough battery left (at least 30%) PART 1: Installing Apanda 1.6.2
PART 2: Installing CMLMod 1.5.1 (for CMLMod 1.4 skip this and go to PART 2 OLD)
Now select Partition sdcard, Partition SD and confirm with the Home key. set swap=0, Ext2=512 (is more then enough! you can also set less) and Confirm twice again. Then press the back button and select APP2SD if you want your apps being installed on your sd in the Ext2 partition. Attention!!! if after you want your apps being installed on your phone memory you have to make a Wipe, that means, your data will be lost. Always in CMLMod1.5 you can select a launcher, install flash lite and install setcpu to set the speed of the phone's processor with the possibility of variable speed. FINISH!!! PART 2 OLD: Installing Apanda 2.1.9
PART 3 OLD: Installing CMLMod 1.4
The Following 9 Users Say Thank You to reserve For This Useful Post: |
12-13-2010, 09:14 | #3 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | thx for this solution and plz reupload this file Firmware CMLMod 1.4 |
01-05-2011, 09:35 | #6 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Another link for CMLMod1.5.2.rar Hotfile.com: One click file hosting: CMLMod1.5.2.rar |
04-09-2011, 11:47 | #9 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | Hi All, Have some problems in the entire process Firstly in the step 4 of Part 1 When i run in compatibility mode i only get Windows 95 Windows 98/Windows me Windows NT 4.0(Service Pack 5) Windows 2000 Do not have the one specfied here Windows XP(SP3) Not sure which mode to run in in ??? *********** Further in Step 7 of part 1 After the phone is in recovery mode it shows and error E: Cant open /cache/recovery/command not sure what to do with this ? does it appear normally ??? what to do with this ... ******** Further if i proceed with this i get an error Task 1 of 3, Switch 2 Diag Mode fail Error Device not configure (0X4000) What is this error and what to do with it ??? Can any one help me with all these issues ... really need serious help here ... BR / Manbir |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
