Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
02-26-2013, 13:00 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | [Utility]Android Multi Tools_V1.02 /RESET User Lock ,Gmail , Wipe Data By AzimBahar Android Multi Tools_1.0 III-FOR-TEST-III Works On All kind Of Android Phone and Tablets (Reset User Lock ,Gmail Lock , Wipe Data & More Other ) Download Link Android Multi Tools v1.02b AzimBahar - Download - 4shared - azim bahar First, the Driver must be installed on the machine before then. 1-6 commands can be used with the open marriage Debug Mode only. 7-9 can be used with the machine that faithful into Fastboot Mode only. Profile commands. 1.Check Device used to check the connection of the machine mode ADB. 2.Reset User Lock Code using the tools that are in the data is not lost. 3.Reset Gesture Lock machines that are used to draw a line through the data is not lost. After the installation is complete, it will fire up. Then draw anything for a closed lock. 4.Reset GMail using the machine to try to unlock the machine several times to enter to unlock. 5.Wipe Data used to resolve the symptoms or slow down. Or that an error or some missing. 6.Reboot to reboot your PC or from adb shell. 7.Check Device On Fastboot Mode to check the connection of the machine mode FastBoot. 8.Wipe Data / Cache On Fastboot Mode This command is available only Fastboot Mode to resolve the symptoms or slow down. Or that an error or some missing. That is often found in the CPU Spreadtrum. 9.Exit Fastboot Mode to reboot your PC or exit FastBoot. Help. Press the number that corresponds to the condition of the machine and then hit enter. Note-This program is conducted by a single line with Thailand Central Thailand Central branch line to the site and permission granted to share New Version Coming ..... Use It If Any One Do Help You I Think Respect Is Immortal Life Cordially, AzimBahar/ParvezAhmed Last edited by aZimBahar; 03-08-2016 at 07:34. |
The Following 361 Users Say Thank You to aZimBahar For This Useful Post: |
02-26-2013, 13:06 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | Okay i will post test result here! br. PHONEPATCH |
The Following 4 Users Say Thank You to Asia_Phone For This Useful Post: |
02-26-2013, 13:10 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA - GOING MY WAY ......... Age: 31
Member: 1417101 Status: Offline Sonork: 100.1619006 Thanks Meter: 157 | XPAD Tablet Done . Tested By Me problem is gmail lock i try wipe data option . working well thanks azimbahar.......... RIJAS2010 |
The Following 13 Users Say Thank You to RIJAS2010 For This Useful Post: |
02-26-2013, 13:14 | #4 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | Quote:
The Following 21 Users Say Thank You to aZimBahar For This Useful Post: |
02-26-2013, 13:38 | #6 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Yes It's Working Well With Win-7 Very Easy. Tested By Me . Bro:- Palash Ahammad |
The Following 7 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
02-26-2013, 15:20 | #8 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Inside CPU Age: 43
Member: 23420 Status: Offline Thanks Meter: 3,080 | keep in mind you need to have ROOT ACCESS access else you cannot wipe the files from the /data partition (option 2,3,4) |
02-27-2013, 05:01 | #9 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | Note- Option 7-9 can be used with the machine that faithful into Fastboot Mode only. |
The Following 2 Users Say Thank You to aZimBahar For This Useful Post: |
02-27-2013, 17:03 | #13 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Get it here Android Multi Tools_1.0.rar But i don't think its work well all Android devices |
The Following 3 Users Say Thank You to .::AZEEM::. For This Useful Post: |
