Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 02-28-2013, 05:30   #16 (permalink)
Member: 1644704
Thanks Meter: 4
Not thank because you did not give credit to the program.
The Following 2 Users Say Thank You to imac2 For This Useful Post:
Old 02-28-2013, 06:04   #17 (permalink)
Member: 1891253
specail thank แจก โปรแกรมแก้ปัญหายอดฮิตของแอนดรอยด์
Credir SE-THAILAND
tamkbox
The Following User Says Thank You to tamkbox For This Useful Post:
Old 02-28-2013, 07:15   #18 (permalink)
Member: 1035338
Sonork: 9391
Thanks Meter: 195
Okay i will post test result here!
Old 02-28-2013, 08:14   #19 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
One thing should be cleared that all device which were enabled usb debug can be unloked otherwise it can't be used.Second thing if it were made for comport for using uart cable than may be it should be more powerful....Like One Click Pattern Unlock made by gsm finder as freeware utility...
Old 02-28-2013, 11:08   #20 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
not working on karbonn A21
all process sucsess fully done but
phone patturn lock its my bad luck....
i m all show try with fast mode.....
can any body help...plz pm
Old 02-28-2013, 11:10   #21 (permalink)
Member: 784847
Thanks Meter: 45
plz briefly guide its use
and also clear how to..s.?
Old 02-28-2013, 11:24   #22 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,976
Originally Posted by jr astigin View Post
Option 7-9 can be used with the machine that faithful into Fastboot Mode only
How to work with this fastboot mode?
Here Example -
How to Enter Fastboot / Bootloader Mode in Huawei MediaPad 10 FHD
Here are two quick steps on how to access bootloader / fastboot mode on your Huawei MediaPad 10.
Step 1 - Power off the tablet.
Step 2 - Press and hold the Power + Volume Up keys together for about 10 seconds. MediaPad 10 FHD will start and boot into the FASTBOOT mode.
Originally Posted by sackam2010 View Post
how to use this software
Read And Try . Its Easy . Just You Need Read Correctly .
Originally Posted by tamkbox View Post
You Are Right I Never Asked Its Create Me . I Just Share Here .
I Also Post It .
Note-This program is conducted by a single line with Thailand Central Thailand Central branch line to the site.
You Can Check My 1st Post .
[email protected]
Here Your Answer ,
Originally Posted by naughtyboyd View Post
โปรแกรมนี้จัดทำโดย เสไทยแลนด์ เจ้าของเดียวกับร้าน เสไทยแลนด์ ทุกสาขา รวมถึงเว็บไซท์ se-thailand.com และ se-thailand.net
หากมีคำแนะนำหรือแจ้งปัญหาในการใช้งานสามรถติดต่อได้ ทางเฟสบุ๊ก facebook.com/sethailand.net หรือทางหน้าเว็บด้านบนได้เลยครับ
This program made by SE-Thailand The owner of SE-Thailand shop all branch inclued se-thailand.com and se-thailand.net
if you have advice or report problem about program please contact via Facebook.com/sethailand.net or our website
Read 1st Post Correctly . Its Easy . Just Read And Try To Understand .
Old 02-28-2013, 12:26   #23 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
after wipe data/cache on firstboot mode it's network unknown,how to solve?
model num:softwiner f761
android ver:4.0.4
bb ver:m1190-v1.0.3
Old 02-28-2013, 12:36   #24 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
android ver:4.0.4
bb ver:m1190-v1.0.3
pls some body help me
Old 02-28-2013, 12:40   #25 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Bro to Reset From Setting . Post Result
Old 02-28-2013, 16:32   #26 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Bro same not solve here is status
battery-staischarging
batt-leve:65%
network:unknown
signal streghtdbm99asu
mobile network type:unknown
service status:disconnected
mdn:unknown
imeik
imeisv:unknown
lp add:unavailable
serial number:unknown
model number:softwiner f761
android ver:4.0.4
base band ver:m1190-v1.0.3
kernel ver:3.0.8cs
build number:f761-dblgc0308-v1.0.1
pls tell me now what?
Old 02-28-2013, 20:35   #27 (permalink)
Member: 622461
Across explain pictures or video program
Thank you
Old 03-01-2013, 01:41   #28 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
ZTE-Huawei Password fastboot ok
http://forum.gsmhosting.com/vbb/f802...ot-ok-1614542/
Old 03-01-2013, 07:52   #29 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
Thank you
to hard-reset any android based INQ, and many others, use fastboot. connect in fastboot mode (camera + power in inq t2-218u), and type 'fastboot -w' (of course abd tools need to be installed).
Old 03-01-2013, 17:55   #30 (permalink)
Member: 193186
Thanks Meter: 16
brother i want its driver plz post it..........
Page generated in 0.28440 seconds with 9 queries
