ASUS ASUS Devices |
05-02-2015, 10:58 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Zenfone Flashing Done With ASUS Flash Tool By AzimBahar* ASUS Flash Tool - http://forum.gsmhosting.com/vbb/f606...lease-1919755/ Zenfone RAW File - http://forum.gsmhosting.com/vbb/f606...-here-1919800/ How To Flash - How To Flash Zenfone With ASUS Flash Tool Below Screenshot Without Any Error < Some Of You always Get Error ! Flashing Started Flashing Successfully Done __________________ Use the Forum according to Rules...! Each section has Rules to follow Cordially, AzimBahar/ParvezAhmed Last edited by aZimBahar; 12-21-2015 at 14:13. |
The Following 20 Users Say Thank You to aZimBahar For This Useful Post: |
06-02-2015, 16:56 | #3 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1200276 Status: Offline Thanks Meter: 16 | i also ASUS TAB K017 FIRWARE HOW TO CONVERT ZIP TO RAW FILE PLEASE HELP ME Last edited by aZimBahar; 08-31-2015 at 14:09. Reason: Quote remove |
The Following User Says Thank You to thewarismobiles For This Useful Post: |
06-08-2015, 09:57 | #4 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Both of you for RAW file you can search Or post in those thread , where they provide (You can search for this) Anyway for your tablet no need RAW firmware. Its possible fix via zip . Check below link its will help you. For more create your own thread with details info !!! http://forum.gsmhosting.com/vbb/f606...ation-1874625/ Br AzimBahar/ParvezAhmed |
The Following 2 Users Say Thank You to aZimBahar For This Useful Post: |
08-31-2015, 14:07 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | same problem here tool not asking for raw file only asking zip extension to select kindly revert.... Last edited by aZimBahar; 08-31-2015 at 14:09. Reason: Quote remove |
08-31-2015, 14:11 | #6 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Hello You guys selected wrong model and for zenfone 4 install RAW to Boot-loader mode For more info read in Sticky |
08-31-2015, 17:03 | #7 (permalink) | |
No Life Poster Join Date: Nov 2008
Member: 901472 Status: Offline Thanks Meter: 48 | Hi, i downloaded the latest asus flash tool(1.0.0.7) only have a450cg model.But the problem is i cant select .raw file,only can select .zip file. try to use 1.0.0.0 flash tool can select .raw but dont have a450cg model.I try use pf400cg but failed. How to flash my phone.Pls check my attachments WBR Mod Edit ------------------ Excuse me , Kindly read above reply you got the answer Quote:
09-05-2015, 07:34 | #9 (permalink) | |
Member: 901472 Status: Offline Thanks Meter: 48 | Quote:
WBR | |
12-21-2015, 14:04 | #12 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Quote:
FJ are same ! | |
01-21-2016, 17:38 | #15 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2516526 Status: Offline Thanks Meter: 1 | the AFT i installed on my pc doesnt detect the raw file i have i've spend two weeks to solve this still no luck please give me some advice how do i fixed my zenfone 4 its stuck on ASUS LOGO Fix it already but got a new problem Flash image failure(FAILED (remote: ERROR: Image-SKU: 'TW_Zenfone' Device-SKU: 'WW_Zenfone')) |
