Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > J.A.U - Box (c) Just Another Unlocker
J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010
Old 01-20-2011, 02:23   #1 (permalink)
oOXTCOo's Avatar
Member: 2878
hehe, my first N97 mini (SL3) unlocked using J.A.U SL3 Server ;)
see my first tests:
it works
the software wich you see on screenshot is just my first testsoftware...
i made it just for fun...
it will not look like now when it is finished... just the needed basic functions are implemented for now...
and found that it realy is 50~100% faster then mx.key
i dont know way, but mxkey shows a very high speed and very good time, but at the end, it need mutch mutch more time then it will display.
i also found that it dont use complete gpu speed...
mxkey runs with 1 HD5970 dual gpu with every gpu ONLY at 50% each.
when i use 2 HD5970 (this are 4 gpu“s) every gpu speed is only at 25%.
so in my tests, it is useless to use more gpus, because mxkey dont use full power...
i think they use some old ighashgpu.exe
my software dont works with all gpu“s at same time at 100% speed, but it balance the speed at very high rates...
wbr.
hari
Old 01-20-2011, 02:31   #2 (permalink)
Member: 218546
Sonork: 100.1619187
wow! time after time sl3 unlocking takes only a minute...
Great job!
Old 01-20-2011, 02:36   #3 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Great job !!!! 0 _ O
BR / TA@UFIK
BY / QUICK - MOBILE
Old 01-20-2011, 02:37   #4 (permalink)
oOXTCOo's Avatar
Member: 2878
Great job!
no, it taken (with 4 gpu“s) 4,5 hours (but i was lucky, it was already at 1375)
Old 01-20-2011, 02:40   #5 (permalink)
trio1's Avatar
Member: 757799
4 gpu's what motherboard you use? gigabyte? g1 or 6 series?
Old 01-20-2011, 02:56   #6 (permalink)
oOXTCOo's Avatar
Member: 2878
yes, its a gigabyte board, but dont ask me wich one exactly...
i used a board wich i already got from another computers in my office for this pc..
but iam already building next one.
i whant to make some tests, making cluster computation
The Following 3 Users Say Thank You to oOXTCOo For This Useful Post:
Old 01-20-2011, 02:58   #7 (permalink)
Member: 1241682
is there possibility that you can reduce the time taken to get more faster the code with your work?
or maybe you just Lucky
Old 01-20-2011, 03:03   #8 (permalink)
oOXTCOo's Avatar
Member: 2878
its definitiv 50% and more.. faster then mxkey, thats for shure..
just take any timer and check REAL time per salt, you will find out that 32 seconds or with 2 cards at 16 seconds is NOT THE REAL time... real time witch two cards using mxke is about 44 seconds per salt!
and i have another idea to reduce the time a little bit more.. but need to test.. i havent enugh results till now... (only about 6 unlocked devices till now).
The Following 6 Users Say Thank You to oOXTCOo For This Useful Post:
Old 01-20-2011, 03:15   #9 (permalink)
pawans's Avatar
Member: 346345
wow thats great jau unlocker..........
Old 01-20-2011, 04:09   #10 (permalink)
:::MACUGSM:::'s Avatar
Member: 348590
Sonork: 100.108198
I need a friend you recommend a good CPU to achieve faster unlock!!
Old 01-20-2011, 09:44   #11 (permalink)
trio1's Avatar
Member: 757799
here is the one faster GIGABYTE G1-Killer Series Motherboards
The Following User Says Thank You to trio1 For This Useful Post:
Old 01-22-2011, 19:03   #12 (permalink)
Member: 49594
Thumbs up Good job
This is a very big step brother i will be behind you.
Old 01-22-2011, 19:15   #13 (permalink)
Member: 18832
971 MHz??? is that watercooled, or what?
Old 01-22-2011, 20:59   #14 (permalink)
buds1's Avatar
Member: 1002500
no. without watercooling. only opened case and much fresh air
Old 01-23-2011, 20:27   #15 (permalink)
Zegarek's Avatar
Member: 551345
Sonork: 100.1590161
see my first tests:
it works
wbr.
hari
Please add this program to the Jau .
Best Regards.
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
Page generated in 0.43079 seconds with 12 queries
