J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010 |
03-08-2010, 22:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 54
Member: 322444 Status: Offline Thanks Meter: 24 | huawei unlock counter reset? |
The Following User Says Thank You to Rastafari 69 For This Useful Post: |
03-09-2010, 18:23 | #2 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
yes, already written... when new security server is up and working, you get huawei counter reset but first need new secure login server... iam already working some days on it, but need some more work because i try my best to make it as secure as possible... hehe yes i learned from the past | |
The Following 11 Users Say Thank You to oOXTCOo For This Useful Post: |
03-10-2010, 04:53 | #4 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: KENYA
Member: 1175158 Status: Offline Thanks Meter: 653 | Quote:
The Following User Says Thank You to larrycarlkeya For This Useful Post: |
03-15-2010, 23:58 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Unlock world
Member: 242469 Status: Offline Thanks Meter: 503 | Quote:
you can try with this attached file I test with E176 and reset counter and unlock same time B.R | |
The Following 2 Users Say Thank You to octavyus For This Useful Post: |
03-16-2010, 01:55 | #6 (permalink) | |
Insane Poster Join Date: Oct 2009
Member: 1141799 Status: Offline Sonork: pokalay Thanks Meter: 20 | Quote:
Found modem : E1552 Model : Huawei E1552 IMEI : 353143036491984 Firmware : 11.608.13.10.158 Dashboard version : UTPS11.300.05.10.158_MAC11.301.06.03.158 SIM Lock status : Locked (customized firmware) Wrong codes entered : 10 (unlock attempts left : 0) I tried your software but no good. Do you still have one good software? Thanks you! -br | |
The Following User Says Thank You to pokalay For This Useful Post: |
03-16-2010, 17:35 | #7 (permalink) | |
your modem maybe from kievstar provider ukraine? this modems cant be unlock per code, only patch unlock is working till now. | |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
12-06-2010, 11:53 | #11 (permalink) |
Junior Member Join Date: Apr 2006
Member: 260051 Status: Offline Thanks Meter: 1 | hI... well same problem herre i need to reset my Huawei E169G i mean reset counter if you can... cuz i m not able to install huawei direct that you have attached ... so are ya able to reset conter via IMEI.. then here is the detail given below.... Modem No :- E169G IMEI No :- 353058023054472 SN No :- D65TAB1852003658 Thankz in advance... |
12-22-2010, 11:21 | #12 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1124385 Status: Offline Thanks Meter: 0 | anyone know how to rest counter for e160 Hi I have huawei E160 T-Mobile from UK , But there is some one put wrong code 10 times , now I want to rest the counter , so any one can help me with this problem Thanks in advance |
03-11-2011, 19:15 | #13 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1534490 Status: Offline Sonork: [email protected] Thanks Meter: 0 | |
03-11-2011, 19:35 | #14 (permalink) |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | Put here your JAU username, IMEI and i'll give you reset string. You must enter this reset string using Terminal program or DC unlocker (simply enter string inside window where text appears, also works as a temrinal). As with any other unlocking software, it's recommended to run in Win XP! |
8110 MEP unlock counter reset?? | mpm07 | BlackBerry (RIM) | 0 | 01-12-2009 23:12 |
How to do Unlock Counter reset for N95 and N73 | zenadia | Nokia Base Band 5 ( BB-5 ) | 17 | 08-31-2007 16:19 |
nec 616v any solution for unlock counter reset | mas comm | FuriouS II | 7 | 12-22-2004 23:29 |
nec 616v any solution for unlock counter reset | mas comm | NEC | 4 | 12-22-2004 12:40 |
