Post here all Sucessfull unlocked MODEM using J.A.U Just Another Unlock if Mr. ooxtcoo permits will be posted here all repair and unlock log made by the major program.... ;););););););)... ================================================== ========= UNLOCK MODEM HUAWEI E156B Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35511202180794 Code: 63468935 Done! ================================================== ========= ================================================== ========= UNLOCK MODEM HUAWEI E156B Contacting Server... Done! Calculating Code.. Your Unlock Code Calculated Successfully!!! Imei: 35387102617206 Code: 47771257 ================================================== ========= |
lets make this for huawei and merlin, option modems and datacards... for lg and nokia exists already sticky treads. E160 Unlocked by JAU: Code: YOUR MODEM MUST BE DISCONNECTED!!! E169 UNLOCKED BY JAU: Code: YOUR MODEM MUST BE DISCONNECTED!!! |
MERLIN XU870 DATACARD UNLOCKED BY JAU: Code: =========================================================== |
MERLIN U740 UNLOCKED BY JAU: Code: =========================================================== |
HUAWEI E220 WITH OLD FIRMWARE UNLOCKED BY JAU: this is the firmware with is not supported by most other unlockers it need some more time for unlock but you dont need to flash it. newer firmware versions of this modem are unlocked in 3 seconds by jau. this unocking technic uses reading complete efs and extract the code. newer ones read direct from nv ram, this is mutch faster and dont need resett. Code: YOUR MODEM MUST BE DISCONNECTED!!! |
B970 Router Unlocked with JAU from a user how sendet me the log file: (thanks to peter) Code: YOUR MODEM MUST BE DISCONNECTED!!! |
Unlock Modem Huawei E1756 Using J.A.U 2.8.9 Code: =========================================================== Code: =========================================================== Code: =========================================================== Code: =========================================================== Code: =========================================================== congratulations to the truth so fast service is delayed more you write the imei that the server or the program calculates the nck code that faster service Br :):) |
new modem huawei e1556 of comcel (colombia) unlock done ================================================== ========= Calculating Codes... Your Unlock Code Calculated Successfully!!! Imei: 355848030XXXXXX Unlock Code: 64320728 Flash Code: 58205964 Done! ================================================== ========= |
Unlocked E 160 modem Code: USING MANUAL SET PORT |
E220 done by jau USING MANUAL SET PORT PLEASE WAIT! Baudrate : 115200 Connecting... Connected Successfully! Reading Info... ================================================== ========= Vendor : HUAWEI Model : E220 Version : 11.117.10.00.00 IMEI : 355083017825941 SIMLOCK : LOCKED! CARDLOCK : ACTIVE! ================================================== ========= ENTER DIAG MODE... DIAG MODE: OK! Firmware Supported for fast Unlock! Reading unlock code... ================================================== ========= UNLOCKING.. Reading Info... ================================================== ========= Vendor : huawei Model : E220 Version : 11.117.10.00.00 IMEI : 355083017825941 SIMLOCK : UNLOCKED! CARDLOCK : NOT ACTIVE! ================================================== ========= Done! NOW DISCONNECT YOUR DEVICE! |
huawei e1556 unlock done ================================================== ========= Calculating Codes... Your Unlock Code Calculated Successfully!!! Imei: 355844020XXXXXX Unlock Code: 74313726 Flash Code: 57106954 Done! ================================================== ========= |
Code: USING MANUAL SET PORT br: 2net2 |
E162 Code: YOUR MODEM MUST BE DISCONNECTED!!! |
huawei e1552 globe tattoo need unlock help!! any news for e1552 globe tattoo unlock!plz help!! |
Huawei E220 Successful unlock DISCONNECTED!!! PLEASE CONNECT YOUR DEVICE NOW AND WAIT! DETECTING DEVICE... PLEASE WAIT! HUAWEI Mobile Connect - 3G PC UI Interface Device Detected! On port : COM5 PLEASE WAIT... Baudrate : 115200 Connecting... Connected Successfully! Reading Info... ================================================== ========= Vendor : HUAWEI Model : E220 Version : 11.117.04.00.00 IMEI : 358193018478405 SIMLOCK : LOCKED! CARDLOCK : ACTIVE! ================================================== ========= ENTER DIAG MODE... DIAG MODE: OK! Firmware Supported for fast Unlock! Reading unlock code... ================================================== ========= UNLOCKING.. Reading Info... ================================================== ========= Vendor : huawei Model : E220 Version : 11.117.04.00.00 IMEI : 358193018478405 SIMLOCK : UNLOCKED! CARDLOCK : NOT ACTIVE! ================================================== ========= Done! NOW DISCONNECT YOUR DEVICE! |
