J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010 |
05-18-2010, 12:17 | #16 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
for sl2 phones is needed to check the sl2 checkbox before calculate codes. i have tested it with many phones, all codes worked. also dont forget to restart jau after you already calculated a nck because there is some bug when one time code is calculated the next one is wrong. i seach the bug already, but dont have found it till now, but i try to fix is asap. | |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
05-18-2010, 12:47 | #17 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | 5800 unlocked successfully with jau using nck unlock methode (SL2): Code: Connecting to phone.. Reading... Model Type : NOKIA 5800 SW Version : V ICPR72_08w47 24-11-08 RM-356 (c) Nokia IMEI Plain : 35320503955**** Reading Backup.. Field: 308, Subblock: 1, Bytes: 8192 -> OK PM Backup saved as: C:\Programme\J.A.U_by_Harald_Kubovy\JAU\35320503955****_308_BACKUP.pm Done! in Time: 00:00:08 Backup Done! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 PROVIDER : T-Mobile ;Austria Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Switch JAF to Flashmode... FLASHMODE: OK! CMT Boot Data : Asic ID : 000000010000022600010006400C192101031103 Asic Mode ID : 00 Asic EM ID : 00000B22 Asic Public ID : 1620010727760052876D091C319CDC80B797C290 HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID : 4B9B75103E691FF8 CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.5 BB5ALGORITHM] Sending Loader (0x3AC0) 0x550200C03AFA00 CMT Boot Ready! SECONDARYBOOT v.01.30.00 Sending CMT Algo (0x02E4) CMT ALG Boot: OK! Sending CUSTOM LOADER (0x5E80) CL. sent: OK! NCK CODES: #pw+682715337926109+1# #pw+380327882142633+2# #pw+718710930778777+3# #pw+488256997731784+4# #pw+832138011438055+5# #pw+822482190877428+6# #pw+505119100247515+7# Connecting to phone.. Reading... Model Type : NOKIA 5800 SW Version : V ICPR72_08w47 24-11-08 RM-356 (c) Nokia IMEI Plain : 35320503955**** Sending NCK Level: 07 with F-Bus to Phone.. Unlock code accepted! Done! PLEASE WAIT! - Reading Simlock Status.. LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 PROVIDER : T-Mobile ;Austria Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: OPEN BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: OPEN Done! All Done! hari |
The Following 4 Users Say Thank You to oOXTCOo For This Useful Post: |
05-20-2010, 12:53 | #18 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Romania
Member: 342027 Status: Offline Thanks Meter: 75 | 7210 supernova config key 000000 Hi ! I have 7210 supernova with config key 00000. I dont know how to fix this problem, because when the program make backup at pm , 308 field is emty. Here the log : Connecting to phone.. Reading... Model Type : Nokia 7210 Supernova SW Version : V 07.23 17-07-09 RM-436 (c) Nokia IMEI Plain : 355743029612351 ST_SIM_LOCK_TEST : NOT TESTED! ST_SECURITY_TEST : PASSED! SUPERDONGLE DATA : INVALID! Secure Watchdog enabled! Phone will Restart randomly! Repair Superdongle Key LOCK STATUS SIMLOCK STATUS: FAIL! Can i repair this problem with jau? |
05-20-2010, 13:35 | #19 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Stavropol Rus www.lasdorf.info Age: 48
Member: 234549 Status: Offline Sonork: 100.107451 Thanks Meter: 413 | Quote:
For today you cannot restore it - SUPERDONGLE DATA : INVALID! by means of JAU. Use the Cyclone-box, MT-Box, UBox or *****. After that you can repair SIMLOCK STATUS: FAIL! with a JAU Last edited by oOXTCOo; 05-20-2010 at 22:36. | |
05-21-2010, 14:55 | #20 (permalink) |
Member: 342027 Status: Offline Thanks Meter: 75 | 5800 unlock or not Hi ! I try to unlock 5800 . Here is the log : Code: Connecting to phone.. Reading... Model Type : <čU* SW Version : V ICPR72_09w20.12 10-09-09 RM-356 (c) Nokia IMEI Plain : 35201204368xxxx ST_SIM_LOCK_TEST : PASSED! ST_SECURITY_TEST : PASSED! SUPERDONGLE DATA : VALID! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2140700000000000 PROVIDER : Movistar (DCT3/4;Spain Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! When i press unlock sl2 : Switch JAF to Flashmode... FLASHMODE: OK! CMT Boot Data : Asic ID : 000000010000022600010006400C192101031103 Asic Mode ID : 00 Asic EM ID : 00000B22 Asic Public ID : 12D00010EF8D0052BAD082736066CEB6119E59E0 HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID : 4B9B75103E691FF8 CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.6 BB5ALGORITHM] 0x550200C03AFA00 CMT Boot Ready! SECONDARYBOOT v.01.30.00 Sending Algo... CMT ALG Boot: OK! Sending Initial PM... Initial PM 308 sent: OK! Sending Phone Cert. 0x134 (0x2000) Cert. 0x134 sent: OK! Phone ack: 0x5502 Sending Simlock Cert. (0x0190) Phone ack: 0x5502 SL Cert. Sent: OK! Sending Rap Certificate 21 v1.0 (0x1931) Phone ack: 0x5502 Rap Cert. sent: OK! Requesting Unlocked SL_Buffer.. Unlocked SL-Buffer received! De-Crypt SL-Buffer... SL buffer De-Crypted: OK! Building Unlocked PM Field [0x78], [0x134] [ERROR] - SECTOR NOT FOUND! ABORT! Last edited by moldovan; 05-28-2010 at 22:30. Reason: [code] |
05-21-2010, 15:07 | #21 (permalink) | |
5800 is not supported by pm patch unlock. | |
05-21-2010, 15:19 | #22 (permalink) |
Member: 342027 Status: Offline Thanks Meter: 75 | i try but no luck : Code: SW Version : V ICPR72_09w20.12 10-09-09 RM-356 (c) Nokia IMEI Plain : 35201204368xxxx Reading Backup.. Field: 308, Subblock: 1, Bytes: 8192 -> OK Skip saving, Backups allready exists! Done! in Time: 12:00:08 AM Backup Done! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2140700000000000 PROVIDER : Movistar (DCT3/4;Spain Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Switch JAF to Flashmode... FLASHMODE: OK! CMT Boot Data : Asic ID : 000000010000022600010006400C192101031103 Asic Mode ID : 00 Asic EM ID : 00000B22 Asic Public ID : 12D00010EF8D0052BAD082736066CEB6119E59E0 HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID : 4B9B75103E691FF8 CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.5 BB5ALGORITHM] Sending Loader (0x3AC0) 0x550200C03AFA00 CMT Boot Ready! SECONDARYBOOT v.01.30.00 Sending CMT Algo (0x02E4) CMT ALG Boot: OK! Sending CUSTOM LOADER (0x5E80) CL. sent: OK! Connecting to phone.. Reading... Model Type : <čU* SW Version : V ICPR72_09w20.12 10-09-09 RM-356 (c) Nokia IMEI Plain : 35201204368xxxx Sending NCK Level: 07 with F-Bus to Phone.. Error 0x2 Done! PLEASE WAIT! - Reading Simlock Status.. LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2140700000000000 PROVIDER : Movistar (DCT3/4;Spain Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Last edited by moldovan; 05-28-2010 at 22:28. Reason: [code] |
05-25-2010, 13:16 | #24 (permalink) |
Member: 342027 Status: Offline Thanks Meter: 75 | When i tick sl2 and bb5 nck unlock : Code: Reading Backup.. Field: 308, Subblock: 1, Bytes: 8192 -> OK Skip saving, Backups allready exists! Done! in Time: 12:00:08 AM Backup Done! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2140700000000000 PROVIDER : Movistar (DCT3/4;Spain Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Switch JAF to Flashmode... FLASHMODE: OK! CMT Boot Data : Asic ID : 000000010000022600010006400C192101031103 Asic Mode ID : 00 Asic EM ID : 00000B22 Asic Public ID : 12D00010EF8D0052BAD082736066CEB6119E59E0 HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID : 4B9B75103E691FF8 CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.5 BB5ALGORITHM] Sending Loader (0x3AC0) 0x550200C03AFA00 CMT Boot Ready! SECONDARYBOOT v.01.30.00 Sending CMT Algo (0x02E4) CMT ALG Boot: OK! Sending CUSTOM LOADER (0x5E80) CL. sent: OK! All Done! After that , info log : ST_SIM_LOCK_TEST : PASSED! ST_SECURITY_TEST : PASSED! SUPERDONGLE DATA : VALID! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 8000000000000000 PROVIDER KEY : 2140700000000000 PROVIDER : Movistar (DCT3/4;Spain Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Last edited by moldovan; 05-28-2010 at 22:29. Reason: [code] |
05-25-2010, 23:29 | #25 (permalink) | |
if so please try another computer if possible. please provide me with more details per email... what phones (all? or some models?) what system you are using and so on... we need to find out way you get no codes displayed... but please per email, lets hold the tread clean. | |
05-27-2010, 15:11 | #26 (permalink) |
Insane Poster Join Date: Mar 2007 Location: my house
Member: 468581 Status: Offline Thanks Meter: 4,294,967,293 | 6131 Code: Connecting to phone.. Reading... Model Type : Nokia 6131 SW Version : V 06.10 16-02-07 RM-115 IMEI Plain : 356432017xxxxxx Reading Backup.. Field: 308, Subblock: 1, Bytes: 8192 -> OK Skip saving, Backups allready exists! Done! in Time: 00:00:08 Backup Done! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER VERSION 63 CONFIG KEY : 8000000000000006 PROVIDER KEY : 2320300000000000 PROVIDER : T-Mobile ;Austria Blocks : 1 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: CLOSED Done! Switch JAF to Flashmode... FLASHMODE: OK! CMT Boot Data : Asic ID : 000000010000022600010006010C192101001101 Asic Mode ID : 00 Asic EM ID : 00000353 Asic Public ID : 1010020ED0396E565892890277176E0146C9DEA6 HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID : 191EC665DFAAF68F CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.5 BB5ALGORITHM] Sending Loader (0x3D00) 0x550200003D3D00 CMT Boot Ready! SECONDARYBOOT v.01.30.00 Sending CMT Algo (0x02E4) CMT ALG Boot: OK! Sending CUSTOM LOADER (0x5970) CL. sent: OK! NCK CODES: #pw+929958568362315+1# #pw+429116835093737+2# #pw+558149442569979+3# #pw+421141690184353+4# #pw+806538098061557+5# #pw+361018410975485+6# #pw+039581631473646+7# Connecting to phone.. Reading... Model Type : Nokia 6131 SW Version : V 06.10 16-02-07 RM-115 IMEI Plain : 356432017515953 Sending NCK Level: 07 with F-Bus to Phone.. Unlock code accepted! Done! PLEASE WAIT! - Reading Simlock Status.. LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER VERSION 63 CONFIG KEY : 8000000000000006 PROVIDER KEY : 2320300000000000 PROVIDER : T-Mobile ;Austria Blocks : 1 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC (USIM) STATUS: OPEN Done! All Done! |
The Following User Says Thank You to disskar2 For This Useful Post: |
05-28-2010, 10:09 | #27 (permalink) |
Member: 342027 Status: Offline Thanks Meter: 75 | E65 unlock ok with blocked counter I try with a few programs to unlock nokia e65 whit counter blocked caused by usage of xsim but no luck and this programs works perfect ! Here is the log : Model Type : Nokia E65 Code: [20/05/2010/5:10:17 PM] SW Version : V 4.0615.2 05-06-08 RM-208 [20/05/2010/5:10:17 PM] IMEI Plain : 354832017798875 [20/05/2010/5:10:17 PM] [20/05/2010/5:10:17 PM] Reading Backup.. [20/05/2010/5:10:17 PM] Field: 308, Subblock: 1, Bytes: 8192 -> [20/05/2010/5:10:25 PM] Reading Backup.. [20/05/2010/5:10:25 PM] Field: 308, Subblock: 1, Bytes: 8192 -> OK [20/05/2010/5:10:25 PM] Files\J.A.U_by_Harald_Kubovy\JAU\354832017798875_308_BACKUP.pm [20/05/2010/5:10:25 PM] Done! in Time: 12:00:08 AM [20/05/2010/5:10:25 PM] Backup Done! [20/05/2010/5:10:26 PM] [20/05/2010/5:10:26 PM] LOCK STATUS [20/05/2010/5:10:26 PM] SIMLOCK STATUS: OK! [20/05/2010/5:10:26 PM] SIMLOCK SERVER: SIMLOCK SERVER VERSION 63 [20/05/2010/5:10:26 PM] CONFIG KEY : 0100000000000000 [20/05/2010/5:10:26 PM] PROVIDER KEY : 2140100000000000 [20/05/2010/5:10:26 PM] PROVIDER : Vodafone / Airtel Movil;Spain [20/05/2010/5:10:26 PM] Blocks : 2 [20/05/2010/5:10:26 PM] Key Counter : 3/3 [20/05/2010/5:10:26 PM] F-Bus Counter : 10/10 [20/05/2010/5:10:26 PM] [20/05/2010/5:10:26 PM] BLOCK 1: [20/05/2010/5:10:26 PM] LOCK 1: MCC+MNC STATUS: CLOSED [20/05/2010/5:10:26 PM] BLOCK 2: [20/05/2010/5:10:26 PM] LOCK 2: MCC+MNC (USIM) STATUS: CLOSED [20/05/2010/5:10:26 PM] [20/05/2010/5:10:26 PM] Done! [20/05/2010/5:10:26 PM] Switch JAF to Flashmode... [20/05/2010/5:10:27 PM] FLASHMODE: OK! [20/05/2010/5:10:30 PM] FLASHMODE: OK! [20/05/2010/5:10:30 PM] APE Boot Data : [20/05/2010/5:10:30 PM] Asic ID : 17100708 [20/05/2010/5:10:30 PM] Asic Mode ID : 00 [20/05/2010/5:10:30 PM] Asic Public ID : 26792DB01D0CF3FEE78E881F1293787DBF17D7C9 [20/05/2010/5:10:30 PM] HASH : 49A97E826B93BA20B7ED0B082475C005 [20/05/2010/5:10:30 PM] ROM ID : 1DFD66132C872FD4 [20/05/2010/5:10:30 PM] [20/05/2010/5:10:30 PM] CMT Boot Data : [20/05/2010/5:10:30 PM] Asic ID : 000000010000022600010006010C192101003000 [20/05/2010/5:10:30 PM] Asic Mode ID : 00 [20/05/2010/5:10:30 PM] Asic EM ID : 00000B22 [20/05/2010/5:10:30 PM] Asic Public ID : 0E8000095FE90154888A5E81ADAB51DDE2EFB356 [20/05/2010/5:10:30 PM] HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 [20/05/2010/5:10:30 PM] ROM ID : 273F6D55DFAAF68F [20/05/2010/5:10:30 PM] CMT 1st Boot : OK! [20/05/2010/5:10:30 PM] [20/05/2010/5:10:30 PM] HASH SUPPORTED FOR UNLOCK! [20/05/2010/5:10:30 PM] ROM SUPPORTED FOR UNLOCK! [20/05/2010/5:10:30 PM] BOOT [XSR1.5 BB5ALGORITHM] [20/05/2010/5:10:31 PM] 0x550200003D3D [20/05/2010/5:10:31 PM] CMT Boot Ready! [20/05/2010/5:10:31 PM] SECONDARYBOOT v.01.30.00 [20/05/2010/5:10:31 PM] Sending Algo... [20/05/2010/5:10:31 PM] CMT ALG Boot: OK! [20/05/2010/5:10:31 PM] Sending ROM (0x3948) [20/05/2010/5:10:33 PM] ROM sent: OK! [20/05/2010/5:10:33 PM] HELLO [20/05/2010/5:10:34 PM] ok [20/05/2010/5:10:34 PM] Crypt ID: <DF9E69411948A2DE> [20/05/2010/5:10:35 PM] Sending Custom Loader (0x50B0) [20/05/2010/5:10:36 PM] Phone ack: 0x5502 [20/05/2010/5:10:36 PM] Custom Loader Sent: OK! [20/05/2010/5:10:37 PM] HELLO [20/05/2010/5:10:37 PM] Sending Phone Cert. 0x134 (0x2000) [20/05/2010/5:10:39 PM] Cert. 0x134 sent: OK! [20/05/2010/5:10:39 PM] Phone ack: 0x5502 [20/05/2010/5:10:39 PM] HELLO [20/05/2010/5:10:40 PM] Calculating Simlock Data.. [20/05/2010/5:10:40 PM] Using simlock.bin as Simlock Table.. [20/05/2010/5:10:40 PM] HINT: (you can change this file with any other simlock.bin file). [20/05/2010/5:10:40 PM] Sending Simlock Binary (0x0038) [20/05/2010/5:10:40 PM] Phone ack: 0x5502 [20/05/2010/5:10:40 PM] Simlock Binary Sent: OK! [20/05/2010/5:10:41 PM] HELLO [20/05/2010/5:10:42 PM] Test call... [20/05/2010/5:10:42 PM] cpsr - 0x0000001F [20/05/2010/5:10:43 PM] p15_1 - 0x0005307F [20/05/2010/5:10:43 PM] p15_2 - 0x0005117F [20/05/2010/5:10:44 PM] p15_3 - 0x0005317F [20/05/2010/5:10:44 PM] esn_init ret - 0x00000001, <tmp_buff2> - 0x00000027 [20/05/2010/5:10:45 PM] esn_read ret - 0x00000001, <tmp_buff2> - 0x00000022 [20/05/2010/5:10:45 PM] Normal BB5 found - 0x000D20E0 [20/05/2010/5:10:46 PM] LR - FFFF3698, param - 0x03, size - 0x00 [20/05/2010/5:10:46 PM] UpdSLock - 0x00000001 [20/05/2010/5:10:46 PM] ret - 0x01, <tmp_buff2> - 0x23 [20/05/2010/5:10:47 PM] PM_308 CRC - 0x000D0E7E [20/05/2010/5:10:47 PM] Requesting Unlocked SL_Buffer.. (0x2000) [20/05/2010/5:11:06 PM] Unlocked SL-Buffer received! [20/05/2010/5:11:07 PM] Building Unlocked PM Field 308 [0x134] [20/05/2010/5:11:07 PM] Unlocked PM build: OK! [20/05/2010/5:11:07 PM] Files\J.A.U_by_Harald_Kubovy\JAU\354832017798875_Created_Unlocked.pm [20/05/2010/5:11:13 PM] Unlocked PM saved as: C:\Program [20/05/2010/5:11:13 PM] Unlocked PM build: OK! [20/05/2010/5:11:13 PM] Connecting to phone. [20/05/2010/5:11:13 PM] Unlocked PM build: OK! [20/05/2010/5:11:13 PM] Connecting to phone.. [20/05/2010/5:11:14 PM] [20/05/2010/5:11:14 PM] Reading... [20/05/2010/5:11:14 PM] [20/05/2010/5:11:14 PM] Model Type : Nokia E65 [20/05/2010/5:11:14 PM] SW Version : V 4.0615.2 05-06-08 RM-208 [20/05/2010/5:11:14 PM] IMEI Plain : 354832017798875 [20/05/2010/5:11:14 PM] [20/05/2010/5:11:14 PM] UNLOCKING... [20/05/2010/5:11:14 PM] Field: 308, Subblock: 1, Bytes: 8192 -> [20/05/2010/5:11:15 PM] UNLOCKING... [20/05/2010/5:11:15 PM] Field: 308, Subblock: 1, Bytes: 8192 -> OK [20/05/2010/5:11:15 PM] Done! Time: 12:00:01 AM [20/05/2010/5:11:15 PM] PLEASE WAIT! - Reading Simlock Status.. [20/05/2010/5:11:25 PM] Done! Time: 12:00:01 AM [20/05/2010/5:11:25 PM] Field: 308, Subblock: 1, Bytes: 8192 -> OK [20/05/2010/5:11:25 PM] Connecting to phone. [20/05/2010/5:11:25 PM] Field: 308, Subblock: 1, Bytes: 8192 -> OK [20/05/2010/5:11:25 PM] Connecting to phone.. [20/05/2010/5:11:26 PM] [20/05/2010/5:11:26 PM] Reading... [20/05/2010/5:11:26 PM] [20/05/2010/5:11:26 PM] Model Type : Nokia E65 [20/05/2010/5:11:26 PM] SW Version : V 4.0615.2 05-06-08 RM-208 [20/05/2010/5:11:26 PM] IMEI Plain : 354832017798875 [20/05/2010/5:11:26 PM] [20/05/2010/5:11:26 PM] [20/05/2010/5:11:26 PM] ST_SIM_LOCK_TEST : PASSED! [20/05/2010/5:11:26 PM] ST_SECURITY_TEST : PASSED! [20/05/2010/5:11:35 PM] SUPERDONGLE DATA : VALID! [20/05/2010/5:11:35 PM] [20/05/2010/5:11:35 PM] LOCK STATUS [20/05/2010/5:11:35 PM] SIMLOCK STATUS: OK! [20/05/2010/5:11:35 PM] SIMLOCK SERVER: SIMLOCK SERVER VERSION 63 [20/05/2010/5:11:35 PM] CONFIG KEY : 8000000000000000 [20/05/2010/5:11:35 PM] PROVIDER KEY : 0010100000000000 [20/05/2010/5:11:35 PM] PROVIDER : Default Test Operator [20/05/2010/5:11:35 PM] Blocks : 1 [20/05/2010/5:11:35 PM] Key Counter : 0/3 [20/05/2010/5:11:35 PM] F-Bus Counter : 0/10 [20/05/2010/5:11:35 PM] [20/05/2010/5:11:35 PM] BLOCK 1: [20/05/2010/5:11:35 PM] LOCK 1: MCC+MNC (USIM) STATUS: OPEN [20/05/2010/5:11:35 PM] [20/05/2010/5:11:35 PM] Done! [20/05/2010/5:11:37 PM] All Done! Last edited by moldovan; 05-28-2010 at 22:28. Reason: [code] |
05-28-2010, 10:13 | #28 (permalink) |
Member: 342027 Status: Offline Thanks Meter: 75 | 6555 unlock ok Model Type : Nokia 6555 Code: [25/05/2010/9:26:16 AM] SW Version : V 03.43 04-03-08 RM-271 (c) Nokia [25/05/2010/9:26:16 AM] IMEI Plain : 359325020368765 [25/05/2010/9:26:16 AM] [25/05/2010/9:26:16 AM] [25/05/2010/9:26:16 AM] ST_SIM_LOCK_TEST : PASSED! [25/05/2010/9:26:16 AM] ST_SECURITY_TEST : PASSED! [25/05/2010/9:26:24 AM] SUPERDONGLE DATA : VALID! [25/05/2010/9:26:25 AM] [25/05/2010/9:26:25 AM] LOCK STATUS [25/05/2010/9:26:25 AM] SIMLOCK STATUS: OK! [25/05/2010/9:26:25 AM] SIMLOCK SERVER: SIMLOCK SERVER [25/05/2010/9:26:25 AM] CONFIG KEY : 8000000000000000 [25/05/2010/9:26:25 AM] PROVIDER KEY : 2140700000000000 [25/05/2010/9:26:25 AM] PROVIDER : Movistar (DCT3/4;Spain [25/05/2010/9:26:25 AM] Blocks : 2 [25/05/2010/9:26:25 AM] Key Counter : 0/3 [25/05/2010/9:26:25 AM] F-Bus Counter : 0/10 [25/05/2010/9:26:25 AM] [25/05/2010/9:26:25 AM] BLOCK 1: [25/05/2010/9:26:25 AM] LOCK 1: MCC+MNC (USIM) STATUS: CLOSED [25/05/2010/9:26:25 AM] BLOCK 2: [25/05/2010/9:26:25 AM] LOCK 2: MCC+MNC (USIM) STATUS: CLOSED [25/05/2010/9:26:25 AM] [25/05/2010/9:26:25 AM] Done! [25/05/2010/9:26:40 AM] Connecting to phone. [25/05/2010/9:26:41 AM] [25/05/2010/9:26:41 AM] Connecting to phone.. [25/05/2010/9:26:41 AM] [25/05/2010/9:26:41 AM] Reading... [25/05/2010/9:26:41 AM] [25/05/2010/9:26:41 AM] Model Type : Nokia 6555 [25/05/2010/9:26:41 AM] SW Version : V 03.43 04-03-08 RM-271 (c) Nokia [25/05/2010/9:26:42 AM] IMEI Plain : 359325020368765 [25/05/2010/9:26:42 AM] [25/05/2010/9:26:42 AM] Reading Backup.. [25/05/2010/9:26:42 AM] Field: 308, Subblock: 1, Bytes: 8192 -> [25/05/2010/9:26:50 AM] Reading Backup.. [25/05/2010/9:26:50 AM] Field: 308, Subblock: 1, Bytes: 8192 -> OK [25/05/2010/9:26:50 AM] Skip saving, Backups allready exists! [25/05/2010/9:26:50 AM] Done! in Time: 12:00:08 AM [25/05/2010/9:26:50 AM] Backup Done! [25/05/2010/9:26:50 AM] [25/05/2010/9:26:50 AM] LOCK STATUS [25/05/2010/9:26:50 AM] SIMLOCK STATUS: OK! [25/05/2010/9:26:50 AM] SIMLOCK SERVER: SIMLOCK SERVER [25/05/2010/9:26:50 AM] CONFIG KEY : 8000000000000000 [25/05/2010/9:26:50 AM] PROVIDER KEY : 2140700000000000 [25/05/2010/9:26:50 AM] PROVIDER : Movistar (DCT3/4;Spain [25/05/2010/9:26:50 AM] Blocks : 2 [25/05/2010/9:26:50 AM] Key Counter : 0/3 [25/05/2010/9:26:50 AM] F-Bus Counter : 0/10 [25/05/2010/9:26:50 AM] [25/05/2010/9:26:51 AM] BLOCK 1: [25/05/2010/9:26:51 AM] LOCK 1: MCC+MNC (USIM) STATUS: CLOSED [25/05/2010/9:26:51 AM] BLOCK 2: [25/05/2010/9:26:51 AM] LOCK 2: MCC+MNC (USIM) STATUS: CLOSED [25/05/2010/9:26:51 AM] [25/05/2010/9:26:51 AM] Done! [25/05/2010/9:26:51 AM] Switch JAF to Flashmode... [25/05/2010/9:26:52 AM] FLASHMODE: OK! [25/05/2010/9:26:55 AM] FLASHMODE: OK! [25/05/2010/9:26:55 AM] CMT Boot Data : [25/05/2010/9:26:55 AM] Asic ID : 000000010000022600010006010C192101003000 [25/05/2010/9:26:55 AM] Asic Mode ID : 00 [25/05/2010/9:26:55 AM] Asic EM ID : 00000B22 [25/05/2010/9:26:55 AM] Asic Public ID : 19800017F2BA7C562D2F2C5BAA1584391AB27B11 [25/05/2010/9:26:55 AM] HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 [25/05/2010/9:26:55 AM] ROM ID : 273F6D55DFAAF68F [25/05/2010/9:26:55 AM] CMT 1st Boot : OK! [25/05/2010/9:26:55 AM] [25/05/2010/9:26:55 AM] HASH SUPPORTED FOR UNLOCK! [25/05/2010/9:26:55 AM] BOOT [XSR1.5 BB5ALGORITHM] [25/05/2010/9:26:55 AM] Sending Loader (0x3D00) [25/05/2010/9:26:55 AM] 0x550200003D3D00 [25/05/2010/9:26:55 AM] CMT Boot Ready! [25/05/2010/9:26:55 AM] SECONDARYBOOT v.01.30.00 [25/05/2010/9:26:56 AM] Sending CMT Algo (0x02E4) [25/05/2010/9:26:56 AM] CMT ALG Boot: OK! [25/05/2010/9:26:56 AM] Sending CUSTOM LOADER (0x5970) [25/05/2010/9:26:58 AM] CL. sent: OK! [25/05/2010/9:26:59 AM] [25/05/2010/9:26:59 AM] NCK CODES: [25/05/2010/9:26:59 AM] #pw+488147238183829+1# [25/05/2010/9:26:59 AM] #pw+755304096380369+2# [25/05/2010/9:26:59 AM] #pw+405055440874152+3# [25/05/2010/9:26:59 AM] #pw+413007418543428+4# [25/05/2010/9:26:59 AM] #pw+629345408205310+5# [25/05/2010/9:26:59 AM] #pw+267050418586272+6# [25/05/2010/9:26:59 AM] #pw+918380720726000+7# [25/05/2010/9:26:59 AM] [25/05/2010/9:26:59 AM] [25/05/2010/9:26:59 AM] [25/05/2010/9:27:05 AM] [25/05/2010/9:27:05 AM] [25/05/2010/9:27:05 AM] Connecting to phone. [25/05/2010/9:27:06 AM] [25/05/2010/9:27:06 AM] Connecting to phone.. [25/05/2010/9:27:06 AM] [25/05/2010/9:27:06 AM] Reading... [25/05/2010/9:27:06 AM] [25/05/2010/9:27:06 AM] Model Type : Nokia 6555 [25/05/2010/9:27:06 AM] SW Version : V 03.43 04-03-08 RM-271 (c) Nokia [25/05/2010/9:27:07 AM] IMEI Plain : 359325020368765 [25/05/2010/9:27:07 AM] [25/05/2010/9:27:07 AM] Sending NCK Level: 07 with F-Bus to Phone.. [25/05/2010/9:27:07 AM] Unlock code accepted! [25/05/2010/9:27:07 AM] Done! [25/05/2010/9:27:07 AM] [25/05/2010/9:27:07 AM] PLEASE WAIT! - Reading Simlock Status.. [25/05/2010/9:27:07 AM] [25/05/2010/9:27:07 AM] LOCK STATUS [25/05/2010/9:27:07 AM] SIMLOCK STATUS: OK! [25/05/2010/9:27:07 AM] SIMLOCK SERVER: SIMLOCK SERVER [25/05/2010/9:27:07 AM] CONFIG KEY : 8000000000000000 [25/05/2010/9:27:07 AM] PROVIDER KEY : 2140700000000000 [25/05/2010/9:27:07 AM] PROVIDER : Movistar (DCT3/4;Spain [25/05/2010/9:27:07 AM] Blocks : 2 [25/05/2010/9:27:07 AM] Key Counter : 0/3 [25/05/2010/9:27:07 AM] F-Bus Counter : 0/10 [25/05/2010/9:27:07 AM] [25/05/2010/9:27:07 AM] BLOCK 1: [25/05/2010/9:27:07 AM] LOCK 1: MCC+MNC (USIM) STATUS: OPEN [25/05/2010/9:27:07 AM] BLOCK 2: [25/05/2010/9:27:07 AM] LOCK 2: MCC+MNC (USIM) STATUS: OPEN [25/05/2010/9:27:07 AM] [25/05/2010/9:27:07 AM] Done! [25/05/2010/9:27:09 AM] [25/05/2010/9:27:09 AM] All Done! [25/05/2010/9:27:12 AM] JAF DISCONNECTED! Last edited by moldovan; 05-28-2010 at 22:27. Reason: [code] |
06-06-2010, 14:36 | #29 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | 3110 contect service repair ok Code: Reading... Model Type : Nokia 3110c SW Version : V 07.21 05-11-08 RM-237 IMEI Plain : 353************ Connecting to J.A.U SX4 Server: ooxtcoo.dontexist.net [JAU_Version: v2.9.4] [12:15:10 06.06.2010] *** Welcome to J.A.U SX4 Server v1.0.30 *** [SERVER STATE: OK!] Start SX4 Authorization... Step1: OK! Step2: OK! Step3: OK! SX4 Authorized Successfull! File not local saved, downloading from Server.. File found on server. Connecting to Server.. Start Downloading... DOWNLOAD FINISHED! Writing PM from Server... Field: 1, Subblock: 0, Packets: 2 Bytes: 114 -> OK Field: 1, Subblock: 2, Packets: 1 Bytes: 98 -> OK Field: 1, Subblock: 4, Packets: 2 Bytes: 110 -> OK Field: 1, Subblock: 6, Packets: 1 Bytes: 98 -> OK Field: 1, Subblock: 8, Packets: 2 Bytes: 110 -> OK Field: 1, Subblock: 13, Packets: 1 Bytes: 98 -> OK Field: 1, Subblock: 16, Packets: 1 Bytes: 86 -> OK Field: 1, Subblock: 18, Packets: 1 Bytes: 86 -> OK Field: 1, Subblock: 20, Packets: 1 Bytes: 86 -> OK Field: 1, Subblock: 25, Packets: 1 Bytes: 4 -> OK Field: 1, Subblock: 29, Packets: 1 Bytes: 6 -> OK Field: 1, Subblock: 34, Packets: 1 Bytes: 80 -> OK Field: 309, Subblock: 0, Packets: 1 Bytes: 4 -> OK Field: 309, Subblock: 1, Packets: 1 Bytes: 2 -> OK Field: 309, Subblock: 2, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 4, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 5, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 7, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 8, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 17, Packets: 1 Bytes: 12 -> OK Field: 309, Subblock: 22, Packets: 1 Bytes: 12 -> OK Done! Time: 12:00:02 AM Model Type : Nokia 3110c SW Version : V 07.21 05-11-08 RM-237 IMEI Plain : 353************ ST_SIM_LOCK_TEST : PASSED! ST_SECURITY_TEST : PASSED! SUPERDONGLE DATA : VALID! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER VERSION 63 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 PROVIDER : Nokia Test Operator;Finnland Blocks : 7 Key Counter : 0/3 F-Bus Counter : 0/10 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! {ahmadge} |
06-07-2010, 21:59 | #30 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | here successfully unlocked N95 8GB with NCK methode: (need to set manual local mode option, because its realy messi to get this phone into stable local mode): Code: Connecting to phone.... Reading... Model Type : Nokia N95 8GB SW Version : V 06wk41v51.3 13-02-08 RM-320 (c) Nokia IMEI Plain : 356983017028322 Reading Backup.. Field: 308, Subblock: 1, Bytes: 8192 -> OK Skip saving, Backups allready exists! Done! in Time: 00:00:09 Backup Done! LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 0000000000000000 PROVIDER KEY : 2320100000000000 PROVIDER : Mobilkom Austria ;Austria Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC STATUS: CLOSED BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: CLOSED Done! Switch UFS to flashmode... FLASH MODE: OK! Asic Mode ID : 00 Asic Public ID : F509DCC05CA0FDDBDEF37562FB6C1AEC78504C99 HASH : BA8710A7E1CD5A2909B9A875DB27AA24 CMT Boot Data : Asic ID : 000000010000022600010006400C192101021103 Asic Mode ID : 00 Asic EM ID : 00000B22 Asic Public ID : 06B0001932800058D1A2DB0B97812AD752C709DE HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID : A8C1D6713E691FF8 CMT 1st Boot : OK! HASH SUPPORTED FOR UNLOCK! BOOT [XSR1.5 BB5ALGORITHM] Sending Loader (0x3AC0) CMT Boot Ready! SECONDARYBOOT v.01.30.00 0x0000000000F172 Sending CMT Algo (0x02E4) CMT ALG Boot: OK! Sending CUSTOM LOADER (0x5E80) CL. Send: OK! NCK CODES: #pw+202368156782864+1# #pw+886668245584231+2# #pw+875283401981066+3# #pw+637900327199492+4# #pw+489138846300401+5# #pw+882732116032419+6# #pw+534249872849497+7# Switch to F-BUS Mode: OK! Connecting to phone.... Reading... Model Type : Nokia N95 8GB SW Version : V 06wk41v51.3 13-02-08 RM-320 (c) Nokia IMEI Plain : 356983017028322 Sending NCK Level: 07 with F-Bus to Phone.. Unlock code accepted! Done! PLEASE WAIT! - Reading Simlock Status.. LOCK STATUS SIMLOCK STATUS: OK! SIMLOCK SERVER: SIMLOCK SERVER CONFIG KEY : 0000000000000000 PROVIDER KEY : 2320100000000000 PROVIDER : Mobilkom Austria ;Austria Blocks : 2 Key Counter : 0/3 F-Bus Counter : 0/10 BLOCK 1: LOCK 1: MCC+MNC STATUS: OPEN BLOCK 2: LOCK 2: MCC+MNC (USIM) STATUS: OPEN Done! All Done! |
★★★ Sucessfull unlocked/repaired phones using PolarBox ★★★ | The_Gorr | PolarBox 3 | 10589 | 07-03-2017 13:28 |
>>>Post here all Sucessfull unlocked/repaired phones using T-BOX | GSMHEART | T-BOX Products | 7 | 05-10-2010 13:46 |
