Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > J.A.U - Box (c) Just Another Unlocker
J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010
Old 08-02-2010, 19:08   #31 (permalink)
Member: 99073
Thanks Meter: 91
So no more access to jau right ??
Old 08-02-2010, 19:09   #32 (permalink)
DieArmeSau's Avatar
Member: 175700
Thanks Meter: 756
at the moment not, wait for oOXTCOo reply.
The Following User Says Thank You to DieArmeSau For This Useful Post:
Old 08-02-2010, 20:44   #33 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
i have unblocked you.
from time to time i look at server logs and watch out what user have done fror a block...
if it is 1st time a user get a block, then i unblock him automtically, but if a user get more then 3 times blocked, i dont remove the block again.
some nice features waiting for the next update and i need to protect it, sorry.
br.
hari
The Following 3 Users Say Thank You to oOXTCOo For This Useful Post:
Old 08-02-2010, 21:16   #34 (permalink)
Member: 99073
Thanks Meter: 91
ok no problem with that .
So i need to unstail the usbtrace from my computer before use again jau right ??
Thanks and all the best .
Old 08-02-2010, 21:25   #35 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
you can have it installed no problem.
but dont start it after or in same when using jau...
if you already started sniffer, then you need to restart your pc, because
drivers are still loaded if you not restart.
jau detect the softwares in different ways...
but just installed software is no problem...
the only software witch makes problem ist the network sharing clients, because mostly it is started with the system...
The Following 2 Users Say Thank You to oOXTCOo For This Useful Post:
Old 08-25-2010, 18:58   #36 (permalink)
Member: 178272
Thanks Meter: 93
Why today does not work SX4?
Could not pass sx4 not on not the working device, not on absolutely serviceable phone!
Old 08-25-2010, 19:12   #37 (permalink)
moldovan's Avatar
Member: 23684
Sonork: 1582723
Thanks Meter: 684
This is temporary problem, will fixed ASAP.
WBR!
Old 08-25-2010, 19:59   #38 (permalink)
Member: 178272
Thanks Meter: 93
WBR!
а какого хрена тут нигде не пишут о проблемах ?
Why the author does not write about it?
Old 09-28-2010, 13:41   #39 (permalink)
eletrico's Avatar
Member: 729325
Sonork: 1581738
Thanks Meter: 890
Exclamation
After upgrading to 3.0.0
Account Locked
Login:srbbraga
Old 09-28-2010, 19:11   #40 (permalink)
eletrico's Avatar
Member: 729325
Sonork: 1581738
Thanks Meter: 890
Account Locked
Login:srbbraga
Problem Solved
thanks
Old 10-11-2010, 18:06   #41 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
Hi
Do i need an account to use JAU ?
When i wont to use any function on main tab in JAU program it switch off - just click connect ufs/jaf or calc pm120 - the program switch off - and when I'm on tab settings wonts to go to main its switch off too...
Whats that problem?
Windows XP Avast - no alerts... ??
Old 10-11-2010, 18:38   #42 (permalink)
moldovan's Avatar
Member: 23684
Sonork: 1582723
Thanks Meter: 684
Originally Posted by piracik View Post
Hi
Whats that problem?
Sure You need buy account for use JAU fullfunctional.
Sticky: Official J.A.U Reseller
WBR!
Old 10-11-2010, 18:43   #43 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
WBR!
Thanks for quick replay... I was thinking that some nokia functions are enabled for free w/o account... as it was in older version
Old 11-26-2010, 11:22   #44 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Not unlock GS290 via USB
[26.11.2010/14:01:53] Searching Phone..
[26.11.2010/14:01:59] Connect Powered OFF Phone witouth Batterie to USB Cable!
[26.11.2010/14:01:59] Searching Phone..OK! Phone detected!
[26.11.2010/14:02:00] =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
[26.11.2010/14:02:00] Booting..
[26.11.2010/14:02:00] Selected Model : GS290 via USB
[26.11.2010/14:02:00] Working.
[26.11.2010/14:02:00] Working..
[26.11.2010/14:02:01] Selected Model : GS290 via USB
[26.11.2010/14:02:01] Working...
[26.11.2010/14:02:01] Working....
[26.11.2010/14:02:01] Working.....
[26.11.2010/14:02:02] Working......
[26.11.2010/14:02:02] Selected Model : GS290 via USB
[26.11.2010/14:02:03] Working.......
[26.11.2010/14:02:03] Selected Model : GS290 via USB
[26.11.2010/14:02:03] Working........
[26.11.2010/14:02:03] Working.........
[26.11.2010/14:02:03] Working..........
[26.11.2010/14:02:05] Selected Model : GS290 via USB
[26.11.2010/14:02:05] Working...........
[26.11.2010/14:02:05] [ERROR] - Unable to read from USB!
Old 11-27-2010, 15:03   #45 (permalink)
Member: 878925
Sonork: ;-)
Thanks Meter: 786
you must install the right driver and you can find the driver in jau folder .
try and report .
The Following 2 Users Say Thank You to digiphone For This Useful Post:
Post here any problem about Nokia keypad - key, and let me give you the solution stefani Nokia Repair Guide and FAQ 850 08-22-2013 12:05
Hello....Post here any problem about Nokia dharmdev Nokia Hardware & Hardware Repair 3 08-17-2013 06:07
Post Here Any Problem About Advance Cdma.. ch mobiles Advance Cdma Products 1 03-06-2010 15:26
bugs and things to do pls post here any problem on 1.28 shoktong MSS Box II 1 12-08-2009 01:26
Post here any problem with Nsdongle v3.11.6 the new NSPRO 95 04-27-2006 20:06
Page generated in 0.25340 seconds with 10 queries
