Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > J.A.U - Box (c) Just Another Unlocker
J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010
Old 10-16-2010, 00:55   #1 (permalink)
Member: 5861
software keeps crashing
i am trying ti run this software but most of the times it closes when i make connect with ufs ...
its the last version and i tested with windows 7 both x64 and x86 version ...
anyone with the same problem ...
Old 10-16-2010, 02:57   #2 (permalink)
oOXTCOo's Avatar
Member: 2878
it will close for this reasons:
1.) if you are not logged in and you press any buttons
2.) if you have debugger or sniffer or something like that running
The Following User Says Thank You to oOXTCOo For This Useful Post:
Old 10-16-2010, 12:37   #3 (permalink)
mrnazam's Avatar
Member: 1001269
Sonork: IphoneIMEI goo,gl/NA7ui
This not a problem boss this system of JAU
Old 10-16-2010, 15:20   #4 (permalink)
Member: 5861
i think its the first option i have no account .. i thought there was a free version that no needed login..
do you think this software is worth the investment..???
Hwk original software is losing terrain in nokia area ... i need a substitute...
Old 10-16-2010, 15:45   #5 (permalink)
buds1's Avatar
Member: 1002500
the cost for a account is very less. if you unlock 5 phones or
modems for your customers, you reach the return of investment ;-)
look for a reseller and buy :-)
Old 10-16-2010, 23:37   #6 (permalink)
oOXTCOo's Avatar
Member: 2878
what investment? 20€? this is more a "symbolic" payment
i tell you what you can not do with jau:
.) you can not make simlock rpl files
.) you can not flash (for now, i dont know if i will ever have time to make something in this direction, iam interessted to do, but time is to small)
.) you can not so superdongle repair
what you can do:
.) unlock / relock / repair or write any custom simlock.bin all SL1 phones per NCK and per patch is supported.
.) you can create simlock.bin files direct in software and use this to write it into sl1 phone in any state (locked or unlocked) 1,2,4,7 blocks...
.) SL2 unlocking via NCK calculation or pm patch
.) SX4 authorisation and automatic security test fail repair (you dont need pm files, it will be auto downloaded from server)
.) you can unlock with jau also phones like N95, N95 8gb and so on witch have big problems in getting stable local mode, thanks to the "manual local mode" you have full controll when jau should start and finish the unlocking process. (you press OK button when you see that phone is in local mode witouth resetting).
other tools give you timeout and you are not able to unlock it witouth special cables or something on box tuning... with jau it is no problem.
.) you can unlock / lock / repair all dct4++ phones in seconds (i think its the best dct4++ unlocker)
.) you can do some standart funktions like reading security code, reading and writing full pm, security tests, if you have local sx4 card you also can use this instead of server.
.) you can calculate codes for ZTE / SFR / Vodafone phones via imei
.) you can unlock Verykool VK Mobile and LG KG110 codes via imei
.) you can unlock huawei modems like E220 (ALL firmware versions witouth flashing) E960.) E970, B960, B970.
.) for the other HUAWEI modems it also exists a 2nd tab where you can calculate unlock codes.)
.) you can relock huawei modems
.) you can counter reset huawei modems.
.) you can enable or disable virtual drive and also repair 2g network.
.) you can manual enter unlock code to modem and also manual select comports in case if autodetection not or wrong detect the ports (if another modem is already connected)
.) you can unlock ALL Novatel Merlin modems / datacards / moduls
.) you can unlock option gio225 usb modem
.) you can work with jaf or ufs as interface for nokia
.) it works with all firmware versions of jaf box.
.) you can up or downgrade your jaf box firmware to 01.B1, 01.B2, 01.B2 Patched, 01,B4
.) for lg you can use any ftdi based box as interface...
.) you can unlock LG INFINEON based modells...
and in short time also the new infineon lg models with encrypted nck codes like GS290, GS290go, GS500, GS500go, GD510 and many many more...
br.
hari
The Following 4 Users Say Thank You to oOXTCOo For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 74 Today 08:53
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 21:31
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.40307 seconds with 11 queries
