10-24-2014, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | 1020 hvae problem Code: Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D424734574107BC0D4B808048 Flash Description: Samsung MBG4WA, 29.12 GiB, SN BC0D4B80, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6023 Op/Sec) FFU File Loaded: RM875_3051.50009.1424.0016_RETAIL_apac_sea_220_16_437825_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xBA8A0464 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x00005E6000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000976400...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004CC8000...Flash Write Error at 0x09C80000, Loader Error, Code 0x71 Code: Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D424734574107BC0D4B808048 Flash Description: Samsung MBG4WA, 29.12 GiB, SN BC0D4B80, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...Memory Read Error, Access to Memory Not Completed! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D424734574107BC0D4B808048 Flash Description: Samsung MBG4WA, 29.12 GiB, SN BC0D4B80, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3241 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x01304000, Loader Error, Code 0x71 |
10-24-2014, 16:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Do ffu flashing again. When it get error, rewrite only the partition where you get error. For example in your first logs, repeat only mmos. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
10-25-2014, 02:54 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
Code: Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D424734574107BC0D4B808048 Flash Description: Samsung MBG4WA, 29.12 GiB, SN BC0D4B80, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6022 Op/Sec) FFU File Loaded: RM875_3051.50009.1424.0016_RETAIL_apac_sea_220_16_437825_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xBA8A0464 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x00005E6000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000976400...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004CC8000...OK Completed in 0h 7m 13s. Code Download Speed 237 KiB/sec. | |
10-25-2014, 03:34 | #4 (permalink) | |
when connect phone show like this Code: Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x5AD909DA Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x706B40E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 3:42:00 PM ========================================================== Phone Type : Lumia 1020 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...Powered eMMC Not Found, Responce 0x00000000 | |
10-25-2014, 08:08 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @089999945 Why did you choose partition BOOT1 ? Lumia Phones DO NOT USE BOOT1. Disconnect Battery flex cable if it is still connected. Then perform FFU Flashing on USER partition which is selected by default. Please do not experiment, you will kill phone. |
10-26-2014, 09:28 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | No. Your emmc is not detected because you ask for help and you do not follow my instructions when I reply to you. It is not complicated, just follow what I say. |
10-27-2014, 03:23 | #8 (permalink) | |
im follow u ready 1 im remove battery flex and reconnect battey then i connect with box and click on Custom R/|W then it show like this Code: Detecting eMMC #1 ID...Powered eMMC Not Found, Responce 0x00000000 | |
10-27-2014, 08:34 | #9 (permalink) | |
now is ok with write FFU file in USER but phone still dead how to do more?pls help me Code: Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D424734574107BC0D4B808048 Flash Description: Samsung MBG4WA, 29.12 GiB, SN BC0D4B80, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6024 Op/Sec) FFU File Loaded: RM875_3051.50009.1424.0016_RETAIL_apac_sea_220_16_437825_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xBA8A0464 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x00005E6000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000976400...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004CC8000...OK Completed in 0h 7m 14s. Code Download Speed 237 KiB/sec. | |
10-27-2014, 15:32 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Desolder jtag wires Check battery voltage. If less than 3.70 v, then it means battery is totally discharged. Charge battery via an external charger, because a dead lumia phone cannot charge it's battery. If you do not have an external battery charger, then just use + and - connection of a USB cable and connect it directly to the + and - of the phone battery when it is NOT connected to the phone pcb. After battery has more than 3.70v, then flash phone via USB Cable with same ffu file you used to repair via jtag. If phone still dead, then it is hardware problem or maybe you did not follow intructions again... If you do not understand what I explained here, please give back phone to customer. |
11-02-2014, 04:30 | #11 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Lumia 1020 after refalsh fail cant' connect again with ATFJtag what problem?pls help me all user and supporter ATF Log Code: Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 357254053830958 Version: 1.1.1.3 Product Code: 059T9H3 Module Code: 0205303 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 :00241000 Block ID 0x02 :00240000 Block ID 0x03 :03A3E000 Block ID 0x05 :Nokia.MSM8960.P5217.3.2.1 Block ID 0x0D :0001 Block ID 0x0F :0301010100000101FF Block ID 0x10 :01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: 0CBD2EED6F62230571CBAB55B7DBC15F8A7DC7BB3F37C1E7E4E5ADC77152FBC2 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x21860000 Check your Flash File and Phone Connection ERROR: Flashing Failed! Code: Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x5AD909DA Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 3:44:00 PM ========================================================== Phone Type : Lumia 1320 CPU Type : Qualcomm MSM8230 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 3:42:00 PM ========================================================== Phone Type : Lumia 1020 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...Timeout During Operation! Resetting and Exploring JTAG chain...No Devices found in Chain! |
