08-30-2014, 15:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629694 Status: Offline Thanks Meter: 50 | 114 security test failed Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 010009 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set |
08-31-2014, 19:31 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
1. Backup full PM of this phone 2. Read full PM from other SAME PHONE and edit/remove PM120 fields. 3. Write edited PM to your damaged phone and make factory set Scan Phone afterwards, security test should be PASSED. | |
