Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: CASTELLI - BS.AS - ARGENTINA
Member: 1057178 Status: Online Sonork: UseGooGle Thanks: 252
| Hi Paste your log with a process (dct4 phones) use a last version & last update 9.51 flash phone (use search in 4shared) like this video 1202 RH-112 Flashing with ATF ver 5.00 - YouTube Br Polaco |
| | #4 (permalink) |
| No problem for read or flash dct4, but this example 1600 not supported for unlock (error simlock table) for asic 2 MSID: 844F9684414DB981B20B27532A DecodedMSID: 843E4EBAE9008336E0AA000000 EncodedFAID: 9E80285D5D64920E535C61B8 Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 5.03 04-21-06 RH-65 (c) NMP IMEI: 011404004853413 Product Serial Number: RCT483482 Product Code : 0532448 Module Code : 0202592 Basic Production Code: 0520756 PPM SW Version : V 5.03 04-21-06 RH-65 (c) NMP UB ADSP Version : p1V 5.03\n04-21-06\nRH-65\n(c) NMP\nN1600B\nub_lta MCU SW Version : V 5.03 04-21-06 RH-65 (c) NMP HW Version : 0529 UEM Version : 1328 UPP Version : 8705 RFIC Version : 0500 DSP Version : P05w06.v34 LCD Version : SDI:LD184v89 ********** SIMLOCK INFO ********** CONFIG_DATA : 7220700000000000 PROFILE_BITS : 0000000000020002 ASIC : 2 PROVIDER : Telefonica Móviles Argentina SA;Argentina [GSM] Block [1] 1:Close Block [2] 1:Close Block [3] 1:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : ˙ MASTER_CODE : 1742655633 PHONE_MODE : LOCAL ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++ Done! MCU: V 5.03 04-21-06 RH-65 (c) NMP IMEI: 011404004853413 Product Serial Number: RCT483482 Product Code : 0532448 Module Code : 0202592 Basic Production Code: 0520756 PPM SW Version : V 5.03 04-21-06 RH-65 (c) NMP UB ADSP Version : p1V 5.03\n04-21-06\nRH-65\n(c) NMP\nN1600B\nub_lta MCU SW Version : V 5.03 04-21-06 RH-65 (c) NMP HW Version : 0529 UEM Version : 1328 UPP Version : 8705 RFIC Version : 0500 DSP Version : P05w06.v34 LCD Version : SDI:LD184v89 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000020002 ASIC : 2 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : ˙ MASTER_CODE : 1742655633 PHONE_MODE : LOCAL boot dct4 is fine and Tested Br Polaco |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: sl3 Age: 32
Member: 182134 Status: Offline Thanks: 0
| bro i flash 1000 of dct4 before but yet no flash other tool also only bus check ok scan phone info ok but not flash tooo... but in this box no boot not buscheck no scan no flash.... why this model not booting... cable ok |
| | #6 (permalink) | |
| Quote:
I you are a advance user, must be know, without log, the supporter cant help you. for many reason Br Polaco | |
| | #7 (permalink) |
| 1202 r112 loader error logs No Boot file found, check Loader Path SearchForBootstrap_DCT4 : Flashing FAILED... Flashing ERROR i update box update files no work for me |
| | #8 (permalink) |
| ImageFile:C:\Program Files\Nokia\Phoenix\Products\RH-111\rh111_03.040 PhoneType : Algorithm : Supported Hardwares : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 0 Entry Point: 0x0000 Is128k: False Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 93 ------------------------------------- Boot OK No Boot file found, check Loader Path SearchForBootstrap_DCT4 : Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 93 ------------------------------------- Boot OK No Boot file found, check Loader Path SearchForBootstrap_DCT4 : Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 93 ------------------------------------- Boot OK No Boot file found, check Loader Path SearchForBootstrap_DCT4 : Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 93 ------------------------------------- Boot OK No Boot file found, check Loader Path SearchForBootstrap_DCT4 : Flashing FAILED... Flashing ERROR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
