05-24-2011, 08:48 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | No ATF Box Found(Solution Here) Go to device manager Box Eeprom Damaged Go This Root Folder Open Mprog(Careful Dont Connect any Other boxs(ONLY ATF) |
The Following 8 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
05-24-2011, 08:49 | #2 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Go This Root(C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\Templates) And Select This New Eeprom File After Update Eeprom Open ATF Exe (Look Here) Aft Said Need To Update New Atf Driver!!!! Go To Device Manager Then Update Ur Atf Driver C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS After Make Update Driver We Must Restart Ur Pc.Now Box Ready To Use And Serial Number Restored |
The Following 11 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
05-24-2011, 09:04 | #7 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 715596 Status: Offline Thanks Meter: 244 | Quote:
plz i hav problem locke this pics http://www.img.gem-flash.com/images/...9670573374.jpg | |
The Following User Says Thank You to driss_dz For This Useful Post: |
05-24-2011, 09:12 | #8 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote: dont worry! go this root D:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers Run Remove_ATF_Drivers.bat Wait 5 Seconds Now Atf Box Driver Removed Ur Pc Reconnect Box Now Show Update Driver U Can Select Driver In This Root D:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS | |
05-24-2011, 09:35 | #9 (permalink) | |
Machine worked 100/100 A thank my brother Greetings to a team Advance http://www.img.gem-flash.com/images/...4242845685.jpg | |
05-24-2011, 11:11 | #12 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1476674 Status: Offline Thanks Meter: 23 | IN THIS step can i rename the advace turbo flasher in the product discription for example the name of owr shope for security purposed |
The Following User Says Thank You to gadgetxxpert For This Useful Post: |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
New Nokia BOX for you!!! | gsmEsteve | Main Sales Section | 0 | 11-18-2000 17:09 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
