06-19-2013, 09:51 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: somewhere in world Age: 37
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | Nokia 5130 after write back up(rpl and simlock) unable to read sp data < SOLVED > |
The Following User Says Thank You to sonualok For This Useful Post: |
06-19-2013, 11:02 | #3 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | sir pls check attached log file...and give me rply |
06-19-2013, 12:38 | #5 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | not done log is hear.... 17:05:04 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\RM-495.pm 17:05:04 : Start Uploading PM... 17:05:05 : 17:05:05 : ================================================ 17:05:05 : Basic Phone Information 17:05:05 : ================================================ 17:05:05 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:05:05 : IMEI Plain : 355212037429562 17:05:05 : IMEI Spare : A355212037429560 17:05:05 : IMEI SV : 33552120374295658F 17:05:05 : Phone Model: Nokia 5130c-2 17:05:05 : Category : Classic Phone 17:05:05 : Phone Type : RM-495 17:05:05 : 17:05:06 : 17:05:06 : Field : 1 Sub : 0 Byte(s): 12 - [Requires SX4] 17:05:06 : Field : 1 Sub : 1 Byte(s): 70 - [Requires SX4] 17:05:06 : Field : 1 Sub : 2 Byte(s): 70 - [Requires SX4] 17:05:06 : Field : 1 Sub : 3 Byte(s): 70 - [Requires SX4] 17:05:06 : Field : 1 Sub : 4 Byte(s): 70 - [Requires SX4] 17:05:06 : Field : 1 Sub : 5 Byte(s): 276 - [Requires SX4] 17:05:06 : Field : 1 Sub : 6 Byte(s): 276 - [Requires SX4] 17:05:06 : Field : 1 Sub : 7 Byte(s): 276 - [Requires SX4] 17:05:06 : Field : 1 Sub : 8 Byte(s): 276 - [Requires SX4] 17:05:06 : Field : 1 Sub : 9 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 10 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 11 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 12 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 13 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 14 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 15 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 16 Byte(s): 384 - [Requires SX4] 17:05:07 : Field : 1 Sub : 17 Byte(s): 32 - [Requires SX4] 17:05:07 : Field : 1 Sub : 19 Byte(s): 16 - [Requires SX4] 17:05:07 : Field : 1 Sub : 20 Byte(s): 32 - [Requires SX4] 17:05:07 : Field : 2 Sub : 0 Byte(s): 440 - Ok 17:05:08 : Field : 4 Sub : 1 Byte(s): 800 - Ok 17:05:08 : Field : 4 Sub : 3 Byte(s): 10 - Ok 17:05:08 : Field : 4 Sub : 4 Byte(s): 8 - Ok 17:05:08 : Field : 4 Sub : 5 Byte(s): 8 - Ok 17:05:08 : Field : 4 Sub : 6 Byte(s): 8 - Ok 17:05:08 : Field : 4 Sub : 9 Byte(s): 5 - Ok 17:05:08 : Field : 4 Sub : 18 Byte(s): 80 - Ok 17:05:08 : Field : 4 Sub : 19 Byte(s): 4 - Ok 17:05:08 : Field : 4 Sub : 28 Byte(s): 2 - Ok 17:05:08 : Field : 8 Sub : 0 Byte(s): 2 - Ok 17:05:08 : Field : 8 Sub : 1 Byte(s): 16 - Ok 17:05:08 : Field : 8 Sub : 2 Byte(s): 16 - Ok 17:05:08 : Field : 8 Sub : 3 Byte(s): 128 - Ok 17:05:08 : Field : 8 Sub : 4 Byte(s): 128 - Ok 17:05:08 : Field : 8 Sub : 5 Byte(s): 8 - Ok 17:05:09 : Field : 8 Sub : 7 Byte(s): 4 - Ok 17:05:09 : Field : 8 Sub : 8 Byte(s): 8 - Ok 17:05:09 : Field : 8 Sub : 9 Byte(s): 8 - Ok 17:05:09 : Field : 8 Sub : 10 Byte(s): 24 - Ok 17:05:09 : Field : 11 Sub : 0 Byte(s): 4 - Ok 17:05:09 : Field : 11 Sub : 1 Byte(s): 4 - Ok 17:05:09 : Field : 11 Sub : 2 Byte(s): 4 - Ok 17:05:09 : Field : 11 Sub : 3 Byte(s): 4 - Ok 17:05:09 : Field : 11 Sub : 4 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 5 Byte(s): 6 - Ok 17:05:09 : Field : 11 Sub : 6 Byte(s): 2 - Ok 17:05:09 : Field : 11 Sub : 7 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 8 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 9 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 10 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 11 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 12 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 13 Byte(s): 1 - Ok 17:05:09 : Field : 11 Sub : 14 Byte(s): 2 - Ok 17:05:09 : Field : 11 Sub : 15 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 16 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 17 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 18 Byte(s): 16 - Ok 17:05:10 : Field : 11 Sub : 19 Byte(s): 32 - Ok 17:05:10 : Field : 11 Sub : 20 Byte(s): 32 - Ok 17:05:10 : Field : 11 Sub : 21 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 22 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 23 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 24 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 25 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 26 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 27 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 28 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 29 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 30 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 31 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 32 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 33 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 34 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 35 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 36 Byte(s): 2 - Ok 17:05:10 : Field : 11 Sub : 37 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 38 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 39 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 40 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 41 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 42 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 43 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 44 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 45 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 46 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 47 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 48 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 49 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 50 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 51 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 52 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 53 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 54 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 55 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 56 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 57 Byte(s): 2 - Ok 17:05:11 : Field : 11 Sub : 58 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 59 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 60 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 61 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 62 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 63 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 64 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 65 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 66 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 67 Byte(s): 1 - Ok 17:05:12 : Field : 11 Sub : 68 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 69 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 70 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 71 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 72 Byte(s): 16 - Ok 17:05:12 : Field : 11 Sub : 73 Byte(s): 4 - Ok 17:05:12 : Field : 11 Sub : 74 Byte(s): 2 - Ok 17:05:12 : Field : 11 Sub : 75 Byte(s): 13 - Ok 17:05:12 : Field : 12 Sub : 0 Byte(s): 102 - Ok 17:05:12 : Field : 13 Sub : 0 Byte(s): 1 - Ok 17:05:12 : Field : 13 Sub : 1 Byte(s): 2 - Ok 17:05:13 : Field : 13 Sub : 2 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 3 Byte(s): 2 - Ok 17:05:13 : Field : 13 Sub : 4 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 5 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 6 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 7 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 8 Byte(s): 2 - Ok 17:05:13 : Field : 13 Sub : 9 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 10 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 11 Byte(s): 48 - Ok 17:05:13 : Field : 13 Sub : 12 Byte(s): 4 - Ok 17:05:13 : Field : 13 Sub : 13 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 14 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 15 Byte(s): 886 - Ok 17:05:13 : Field : 13 Sub : 16 Byte(s): 2 - Ok 17:05:13 : Field : 13 Sub : 17 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 18 Byte(s): 1 - Ok 17:05:13 : Field : 13 Sub : 19 Byte(s): 8 - Ok 17:05:14 : Field : 13 Sub : 20 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 21 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 22 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 23 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 24 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 25 Byte(s): 2 - Ok 17:05:14 : Field : 13 Sub : 26 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 27 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 28 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 29 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 30 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 31 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 32 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 33 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 34 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 35 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 36 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 37 Byte(s): 4 - Ok 17:05:14 : Field : 13 Sub : 38 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 39 Byte(s): 1 - Ok 17:05:14 : Field : 13 Sub : 40 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 41 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 42 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 43 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 44 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 45 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 46 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 47 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 48 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 49 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 50 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 51 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 52 Byte(s): 2 - Ok 17:05:15 : Field : 13 Sub : 53 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 54 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 55 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 56 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 57 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 58 Byte(s): 2 - Ok 17:05:15 : Field : 13 Sub : 59 Byte(s): 1 - Ok 17:05:15 : Field : 13 Sub : 60 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 61 Byte(s): 4 - Ok 17:05:15 : Field : 13 Sub : 62 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 63 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 64 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 65 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 66 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 67 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 68 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 69 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 70 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 71 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 72 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 73 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 74 Byte(s): 4 - Ok 17:05:16 : Field : 13 Sub : 75 Byte(s): 2 - Ok 17:05:16 : Field : 13 Sub : 76 Byte(s): 2 - Ok 17:05:16 : Field : 13 Sub : 77 Byte(s): 2 - Ok 17:05:16 : Field : 13 Sub : 78 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 79 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 80 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 81 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 82 Byte(s): 1 - Ok 17:05:16 : Field : 13 Sub : 83 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 84 Byte(s): 1 - Ok 17:05:17 : Field : 13 Sub : 85 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 86 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 87 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 88 Byte(s): 1 - Ok 17:05:17 : Field : 13 Sub : 89 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 90 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 91 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 92 Byte(s): 1 - Ok 17:05:17 : Field : 13 Sub : 93 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 94 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 95 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 96 Byte(s): 1 - Ok 17:05:17 : Field : 13 Sub : 97 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 98 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 99 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 100 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 101 Byte(s): 2 - Ok 17:05:17 : Field : 13 Sub : 102 Byte(s): 1 - Ok 17:05:17 : Field : 13 Sub : 103 Byte(s): 4 - Ok 17:05:17 : Field : 13 Sub : 104 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 105 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 106 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 107 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 108 Byte(s): 2 - Ok 17:05:18 : Field : 13 Sub : 109 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 110 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 111 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 112 Byte(s): 2 - Ok 17:05:18 : Field : 13 Sub : 113 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 114 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 115 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 116 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 117 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 118 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 119 Byte(s): 4 - Ok 17:05:18 : Field : 13 Sub : 120 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 121 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 122 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 123 Byte(s): 8 - Ok 17:05:18 : Field : 13 Sub : 124 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 125 Byte(s): 1 - Ok 17:05:18 : Field : 13 Sub : 126 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 127 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 128 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 129 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 130 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 131 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 132 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 133 Byte(s): 2 - Ok 17:05:19 : Field : 13 Sub : 134 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 135 Byte(s): 2 - Ok 17:05:19 : Field : 13 Sub : 136 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 137 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 138 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 139 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 140 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 141 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 142 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 143 Byte(s): 1 - Ok 17:05:19 : Field : 13 Sub : 144 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 145 Byte(s): 8 - Ok 17:05:19 : Field : 13 Sub : 146 Byte(s): 4 - Ok 17:05:19 : Field : 13 Sub : 147 Byte(s): 4 - Ok 17:05:20 : Field : 13 Sub : 148 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 149 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 150 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 151 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 152 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 153 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 154 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 155 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 156 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 157 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 158 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 159 Byte(s): 2 - Ok 17:05:20 : Field : 13 Sub : 160 Byte(s): 2 - Ok 17:05:20 : Field : 13 Sub : 161 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 162 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 163 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 164 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 165 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 166 Byte(s): 1 - Ok 17:05:20 : Field : 13 Sub : 167 Byte(s): 8 - Ok 17:05:20 : Field : 13 Sub : 168 Byte(s): 4 - Ok 17:05:21 : Field : 13 Sub : 169 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 170 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 171 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 172 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 173 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 174 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 175 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 176 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 177 Byte(s): 4 - Ok 17:05:21 : Field : 13 Sub : 178 Byte(s): 2 - Ok 17:05:21 : Field : 13 Sub : 179 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 180 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 181 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 182 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 183 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 184 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 185 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 186 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 187 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 188 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 189 Byte(s): 1 - Ok 17:05:21 : Field : 13 Sub : 190 Byte(s): 4 - Ok 17:05:22 : Field : 13 Sub : 191 Byte(s): 2 - Ok 17:05:22 : Field : 13 Sub : 192 Byte(s): 1 - Ok 17:05:22 : Field : 13 Sub : 193 Byte(s): 4 - Ok 17:05:22 : Field : 13 Sub : 194 Byte(s): 1 - Ok 17:05:22 : Field : 13 Sub : 195 Byte(s): 1 - Ok 17:05:22 : Field : 13 Sub : 196 Byte(s): 10 - Ok 17:05:22 : Field : 31 Sub : 4 Byte(s): 14 - Ok 17:05:22 : Field : 42 Sub : 0 Byte(s): 2 - Ok 17:05:22 : Field : 42 Sub : 1 Byte(s): 12 - Ok 17:05:22 : Field : 42 Sub : 2 Byte(s): 36 - Ok 17:05:22 : Field : 42 Sub : 3 Byte(s): 36 - Ok 17:05:22 : Field : 42 Sub : 4 Byte(s): 36 - Ok 17:05:22 : Field : 42 Sub : 5 Byte(s): 36 - Ok 17:05:22 : Field : 42 Sub : 6 Byte(s): 36 - Ok 17:05:22 : Field : 42 Sub : 7 Byte(s): 40 - Ok 17:05:22 : Field : 42 Sub : 8 Byte(s): 40 - Ok 17:05:22 : Field : 42 Sub : 9 Byte(s): 40 - Ok 17:05:22 : Field : 42 Sub : 10 Byte(s): 40 - Ok 17:05:22 : Field : 42 Sub : 11 Byte(s): 40 - Ok 17:05:22 : Field : 42 Sub : 12 Byte(s): 40 - Ok 17:05:23 : Field : 42 Sub : 13 Byte(s): 40 - Ok 17:05:23 : Field : 42 Sub : 14 Byte(s): 40 - Ok 17:05:23 : Field : 44 Sub : 0 Byte(s): 1 - Ok 17:05:23 : Field : 50 Sub : 0 Byte(s): 2 - Ok 17:05:23 : Field : 50 Sub : 1 Byte(s): 26 - Ok 17:05:23 : Field : 50 Sub : 2 Byte(s): 26 - Ok 17:05:23 : Field : 54 Sub : 0 Byte(s): 2 - Ok 17:05:23 : Field : 54 Sub : 2 Byte(s): 24 - Ok 17:05:23 : Field : 58 Sub : 0 Byte(s): 32 - Ok 17:05:23 : Field : 58 Sub : 1 Byte(s): 39 - Ok 17:05:23 : Field : 58 Sub : 2 Byte(s): 35 - Ok 17:05:23 : Field : 58 Sub : 3 Byte(s): 36 - Ok 17:05:23 : Field : 58 Sub : 4 Byte(s): 32 - Ok 17:05:23 : Field : 58 Sub : 5 Byte(s): 14 - Ok 17:05:23 : Field : 58 Sub : 6 Byte(s): 27 - Ok 17:05:23 : Field : 58 Sub : 7 Byte(s): 32 - Ok 17:05:23 : Field : 58 Sub : 8 Byte(s): 32 - Ok 17:05:23 : Field : 58 Sub : 9 Byte(s): 54 - Ok 17:05:24 : Field : 58 Sub : 10 Byte(s): 46 - Ok 17:05:24 : Field : 58 Sub : 11 Byte(s): 32 - Ok 17:05:24 : Field : 58 Sub : 12 Byte(s): 36 - Ok 17:05:24 : Field : 58 Sub : 13 Byte(s): 31 - Ok 17:05:24 : Field : 58 Sub : 14 Byte(s): 27 - Ok 17:05:24 : Field : 58 Sub : 15 Byte(s): 30 - Ok 17:05:24 : Field : 58 Sub : 16 Byte(s): 30 - Ok 17:05:24 : Field : 58 Sub : 17 Byte(s): 30 - Ok 17:05:24 : Field : 58 Sub : 18 Byte(s): 33 - Ok 17:05:24 : Field : 58 Sub : 19 Byte(s): 33 - Ok 17:05:24 : Field : 58 Sub : 20 Byte(s): 37 - Ok 17:05:24 : Field : 58 Sub : 21 Byte(s): 38 - Ok 17:05:24 : Field : 58 Sub : 22 Byte(s): 38 - Ok 17:05:24 : Field : 58 Sub : 23 Byte(s): 32 - Ok 17:05:24 : Field : 58 Sub : 24 Byte(s): 28 - Ok 17:05:24 : Field : 58 Sub : 25 Byte(s): 30 - Ok 17:05:24 : Field : 58 Sub : 26 Byte(s): 36 - Ok 17:05:24 : Field : 58 Sub : 27 Byte(s): 30 - Ok 17:05:24 : Field : 58 Sub : 28 Byte(s): 28 - Ok 17:05:24 : Field : 58 Sub : 29 Byte(s): 51 - Ok 17:05:24 : Field : 58 Sub : 30 Byte(s): 28 - Ok 17:05:24 : Field : 58 Sub : 31 Byte(s): 28 - Ok 17:05:25 : Field : 58 Sub : 32 Byte(s): 36 - Ok 17:05:25 : Field : 58 Sub : 33 Byte(s): 30 - Ok 17:05:25 : Field : 58 Sub : 34 Byte(s): 38 - Ok 17:05:25 : Field : 58 Sub : 35 Byte(s): 46 - Ok 17:05:25 : Field : 58 Sub : 36 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 37 Byte(s): 38 - Ok 17:05:25 : Field : 58 Sub : 38 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 39 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 40 Byte(s): 30 - Ok 17:05:25 : Field : 58 Sub : 41 Byte(s): 32 - Ok 17:05:25 : Field : 58 Sub : 42 Byte(s): 36 - Ok 17:05:25 : Field : 58 Sub : 43 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 44 Byte(s): 36 - Ok 17:05:25 : Field : 58 Sub : 45 Byte(s): 46 - Ok 17:05:25 : Field : 58 Sub : 46 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 47 Byte(s): 32 - Ok 17:05:25 : Field : 58 Sub : 48 Byte(s): 26 - Ok 17:05:25 : Field : 58 Sub : 49 Byte(s): 32 - Ok 17:05:25 : Field : 58 Sub : 50 Byte(s): 38 - Ok 17:05:25 : Field : 58 Sub : 51 Byte(s): 34 - Ok 17:05:25 : Field : 58 Sub : 52 Byte(s): 32 - Ok 17:05:26 : Field : 58 Sub : 53 Byte(s): 34 - Ok 17:05:26 : Field : 58 Sub : 54 Byte(s): 39 - Ok 17:05:26 : Field : 58 Sub : 55 Byte(s): 30 - Ok 17:05:26 : Field : 58 Sub : 56 Byte(s): 30 - Ok 17:05:26 : Field : 58 Sub : 57 Byte(s): 32 - Ok 17:05:26 : Field : 58 Sub : 58 Byte(s): 35 - Ok 17:05:26 : Field : 58 Sub : 59 Byte(s): 34 - Ok 17:05:26 : Field : 58 Sub : 60 Byte(s): 39 - Ok 17:05:26 : Field : 58 Sub : 61 Byte(s): 34 - Ok 17:05:26 : Field : 58 Sub : 62 Byte(s): 46 - Ok 17:05:26 : Field : 58 Sub : 63 Byte(s): 31 - Ok 17:05:26 : Field : 58 Sub : 64 Byte(s): 33 - Ok 17:05:26 : Field : 58 Sub : 65 Byte(s): 53 - Ok 17:05:26 : Field : 58 Sub : 66 Byte(s): 15 - Ok 17:05:26 : Field : 58 Sub : 67 Byte(s): 32 - Ok 17:05:26 : Field : 58 Sub : 68 Byte(s): 31 - Ok 17:05:26 : Field : 58 Sub : 69 Byte(s): 41 - Ok 17:05:26 : Field : 58 Sub : 70 Byte(s): 34 - Ok 17:05:26 : Field : 58 Sub : 71 Byte(s): 29 - Ok 17:05:26 : Field : 58 Sub : 72 Byte(s): 36 - Ok 17:05:26 : Field : 58 Sub : 73 Byte(s): 31 - Ok 17:05:27 : Field : 58 Sub : 74 Byte(s): 32 - Ok 17:05:27 : Field : 58 Sub : 75 Byte(s): 39 - Ok 17:05:27 : Field : 58 Sub : 76 Byte(s): 39 - Ok 17:05:27 : Field : 58 Sub : 77 Byte(s): 45 - Ok 17:05:27 : Field : 58 Sub : 78 Byte(s): 41 - Ok 17:05:27 : Field : 58 Sub : 79 Byte(s): 57 - Ok 17:05:27 : Field : 58 Sub : 80 Byte(s): 39 - Ok 17:05:27 : Field : 58 Sub : 81 Byte(s): 41 - Ok 17:05:27 : Field : 58 Sub : 82 Byte(s): 15 - Ok 17:05:27 : Field : 58 Sub : 83 Byte(s): 45 - Ok 17:05:27 : Field : 58 Sub : 84 Byte(s): 55 - Ok 17:05:27 : Field : 58 Sub : 85 Byte(s): 30 - Ok 17:05:27 : Field : 58 Sub : 86 Byte(s): 35 - Ok 17:05:27 : Field : 59 Sub : 0 Byte(s): 62 - Ok 17:05:27 : Field : 59 Sub : 1 Byte(s): 74 - Ok 17:05:27 : Field : 59 Sub : 2 Byte(s): 62 - Ok 17:05:27 : Field : 59 Sub : 3 Byte(s): 49 - Ok 17:05:27 : Field : 59 Sub : 4 Byte(s): 70 - Ok 17:05:27 : Field : 59 Sub : 5 Byte(s): 53 - Ok 17:05:27 : Field : 59 Sub : 6 Byte(s): 36 - Ok 17:05:27 : Field : 59 Sub : 7 Byte(s): 77 - Ok 17:05:28 : Field : 59 Sub : 8 Byte(s): 36 - Ok 17:05:28 : Field : 59 Sub : 9 Byte(s): 35 - Ok 17:05:28 : Field : 59 Sub : 10 Byte(s): 78 - Ok 17:05:28 : Field : 59 Sub : 11 Byte(s): 116 - Ok 17:05:28 : Field : 59 Sub : 12 Byte(s): 35 - Ok 17:05:28 : Field : 59 Sub : 13 Byte(s): 58 - Ok 17:05:28 : Field : 59 Sub : 14 Byte(s): 71 - Ok 17:05:28 : Field : 59 Sub : 15 Byte(s): 48 - Ok 17:05:28 : Field : 59 Sub : 16 Byte(s): 32 - Ok 17:05:28 : Field : 59 Sub : 17 Byte(s): 85 - Ok 17:05:28 : Field : 59 Sub : 18 Byte(s): 35 - Ok 17:05:28 : Field : 59 Sub : 19 Byte(s): 157 - Ok 17:05:28 : Field : 60 Sub : 0 Byte(s): 27 - Ok 17:05:28 : Field : 60 Sub : 1 Byte(s): 27 - Ok 17:05:28 : Field : 60 Sub : 2 Byte(s): 27 - Ok 17:05:28 : Field : 60 Sub : 3 Byte(s): 27 - Ok 17:05:28 : Field : 60 Sub : 4 Byte(s): 27 - Ok 17:05:28 : Field : 60 Sub : 5 Byte(s): 47 - Ok 17:05:28 : Field : 60 Sub : 6 Byte(s): 53 - Ok 17:05:29 : Field : 60 Sub : 7 Byte(s): 39 - Ok 17:05:29 : Field : 60 Sub : 8 Byte(s): 43 - Ok 17:05:29 : Field : 60 Sub : 9 Byte(s): 57 - Ok 17:05:29 : Field : 60 Sub : 10 Byte(s): 27 - Ok 17:05:29 : Field : 60 Sub : 11 Byte(s): 49 - Ok 17:05:29 : Field : 60 Sub : 12 Byte(s): 89 - Ok 17:05:29 : Field : 60 Sub : 13 Byte(s): 49 - Ok 17:05:29 : Field : 60 Sub : 14 Byte(s): 27 - Ok 17:05:29 : Field : 60 Sub : 15 Byte(s): 97 - Ok 17:05:29 : Field : 60 Sub : 16 Byte(s): 27 - Ok 17:05:29 : Field : 60 Sub : 17 Byte(s): 41 - Ok 17:05:29 : Field : 61 Sub : 0 Byte(s): 36 - Ok 17:05:29 : Field : 61 Sub : 1 Byte(s): 75 - Ok 17:05:29 : Field : 61 Sub : 2 Byte(s): 99 - Ok 17:05:29 : Field : 61 Sub : 3 Byte(s): 99 - Ok 17:05:29 : Field : 61 Sub : 4 Byte(s): 57 - Ok 17:05:29 : Field : 61 Sub : 5 Byte(s): 36 - Ok 17:05:29 : Field : 61 Sub : 6 Byte(s): 52 - Ok 17:05:29 : Field : 61 Sub : 7 Byte(s): 78 - Ok 17:05:29 : Field : 61 Sub : 8 Byte(s): 56 - Ok 17:05:30 : Field : 61 Sub : 9 Byte(s): 58 - Ok 17:05:30 : Field : 61 Sub : 10 Byte(s): 54 - Ok 17:05:30 : Field : 61 Sub : 11 Byte(s): 140 - Ok 17:05:30 : Field : 61 Sub : 12 Byte(s): 57 - Ok 17:05:30 : Field : 61 Sub : 13 Byte(s): 64 - Ok 17:05:30 : Field : 61 Sub : 14 Byte(s): 100 - Ok 17:05:30 : Field : 61 Sub : 15 Byte(s): 142 - Ok 17:05:30 : Field : 61 Sub : 16 Byte(s): 36 - Ok 17:05:30 : Field : 61 Sub : 17 Byte(s): 60 - Ok 17:05:30 : Field : 61 Sub : 18 Byte(s): 97 - Ok 17:05:30 : Field : 61 Sub : 19 Byte(s): 90 - Ok 17:05:30 : Field : 66 Sub : 0 Byte(s): 481 - Ok 17:05:30 : Field : 66 Sub : 1 Byte(s): 240 - Ok 17:05:30 : Field : 66 Sub : 2 Byte(s): 240 - Ok 17:05:31 : Field : 66 Sub : 3 Byte(s): 1 - Ok 17:05:31 : Field : 66 Sub : 4 Byte(s): 1 - Ok 17:05:31 : Field : 66 Sub : 5 Byte(s): 240 - Ok 17:05:31 : Field : 66 Sub : 6 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 7 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 8 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 9 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 10 Byte(s): 240 - Ok 17:05:31 : Field : 66 Sub : 11 Byte(s): 240 - Ok 17:05:31 : Field : 66 Sub : 12 Byte(s): 1 - Ok 17:05:31 : Field : 66 Sub : 16 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 18 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 20 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 22 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 24 Byte(s): 4 - Ok 17:05:31 : Field : 66 Sub : 26 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 28 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 30 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 32 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 35 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 36 Byte(s): 4 - Ok 17:05:32 : Field : 66 Sub : 39 Byte(s): 251 - Ok 17:05:32 : Field : 66 Sub : 43 Byte(s): 2 - Ok 17:05:32 : Field : 66 Sub : 54 Byte(s): 8 - Ok 17:05:32 : Field : 66 Sub : 55 Byte(s): 8 - Ok 17:05:32 : Field : 66 Sub : 56 Byte(s): 8 - Ok 17:05:32 : Field : 66 Sub : 57 Byte(s): 8 - Ok 17:05:32 : Field : 66 Sub : 58 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 59 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 60 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 61 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 62 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 63 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 64 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 65 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 66 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 67 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 68 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 69 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 71 Byte(s): 8 - Ok 17:05:33 : Field : 66 Sub : 72 Byte(s): 8 - Ok 17:05:38 : Field : 66 Sub : 73 Byte(s): 24016 - Ok 17:05:39 : Field : 66 Sub : 74 Byte(s): 6144 - Ok 17:05:39 : Field : 66 Sub : 75 Byte(s): 300 - Ok 17:05:39 : Field : 66 Sub : 76 Byte(s): 60 - Ok 17:05:39 : Field : 66 Sub : 79 Byte(s): 60000 - Skipped 17:05:39 : Field : 66 Sub : 81 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 82 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 83 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 85 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 86 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 87 Byte(s): 3 - Ok 17:05:39 : Field : 66 Sub : 88 Byte(s): 2 - Ok 17:05:39 : Field : 66 Sub : 89 Byte(s): 4 - Ok 17:05:40 : Field : 66 Sub : 91 Byte(s): 4 - Ok 17:05:40 : Field : 66 Sub : 92 Byte(s): 4 - Ok 17:05:40 : Field : 66 Sub : 94 Byte(s): 8 - Ok 17:05:40 : Field : 66 Sub : 97 Byte(s): 368 - Ok 17:05:40 : Field : 66 Sub : 98 Byte(s): 392 - Ok 17:05:40 : Field : 66 Sub : 99 Byte(s): 384 - Ok 17:05:40 : Field : 66 Sub : 100 Byte(s): 384 - Ok 17:05:40 : Field : 66 Sub : 101 Byte(s): 368 - Ok 17:05:40 : Field : 66 Sub : 102 Byte(s): 528 - Ok 17:05:40 : Field : 66 Sub : 103 Byte(s): 4 - Ok 17:05:41 : Field : 66 Sub : 104 Byte(s): 352 - Ok 17:05:41 : Field : 66 Sub : 106 Byte(s): 442 - Ok 17:05:41 : Field : 66 Sub : 107 Byte(s): 442 - Ok 17:05:41 : Field : 66 Sub : 111 Byte(s): 120 - Ok 17:05:41 : Field : 66 Sub : 112 Byte(s): 2 - Ok 17:05:41 : Field : 66 Sub : 114 Byte(s): 30 - Ok 17:05:41 : Field : 66 Sub : 115 Byte(s): 1 - Ok 17:05:41 : Field : 66 Sub : 116 Byte(s): 20 - Ok 17:05:41 : Field : 66 Sub : 118 Byte(s): 8 - Ok 17:05:41 : Field : 66 Sub : 119 Byte(s): 31 - Ok 17:05:41 : Field : 66 Sub : 120 Byte(s): 8 - Ok 17:05:41 : Field : 66 Sub : 122 Byte(s): 7 - Ok 17:05:41 : Field : 66 Sub : 123 Byte(s): 7 - Ok 17:05:41 : Field : 66 Sub : 124 Byte(s): 7 - Ok 17:05:41 : Field : 66 Sub : 125 Byte(s): 10 - Ok 17:05:46 : Field : 66 Sub : 126 Byte(s): 24246 - Ok 17:05:50 : Field : 66 Sub : 128 Byte(s): 24206 - Ok 17:05:53 : Field : 66 Sub : 130 Byte(s): 16246 - Ok 17:05:53 : Field : 88 Sub : 0 Byte(s): 36 - Ok 17:05:53 : Field : 96 Sub : 0 Byte(s): 2 - Ok 17:05:53 : Field : 96 Sub : 1 Byte(s): 20 - Ok 17:05:53 : Field : 107 Sub : 0 Byte(s): 21 - Ok 17:05:53 : Field : 107 Sub : 1 Byte(s): 89 - Ok 17:05:53 : Field : 107 Sub : 2 Byte(s): 69 - Ok 17:05:53 : Field : 107 Sub : 3 Byte(s): 70 - Ok 17:05:53 : Field : 107 Sub : 24 Byte(s): 88 - Ok 17:05:54 : Field : 107 Sub : 25 Byte(s): 132 - Ok 17:05:54 : Field : 107 Sub : 26 Byte(s): 12 - Ok 17:05:54 : Field : 116 Sub : 0 Byte(s): 2 - Ok 17:05:54 : Field : 116 Sub : 1 Byte(s): 12 - Ok 17:05:54 : Field : 116 Sub : 2 Byte(s): 36 - Ok 17:05:54 : Field : 116 Sub : 3 Byte(s): 36 - Ok 17:05:54 : Field : 116 Sub : 4 Byte(s): 36 - Ok 17:05:54 : Field : 116 Sub : 5 Byte(s): 36 - Ok 17:05:54 : Field : 116 Sub : 6 Byte(s): 36 - Ok 17:05:54 : Field : 116 Sub : 7 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 8 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 9 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 10 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 11 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 12 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 13 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 14 Byte(s): 40 - Ok 17:05:54 : Field : 116 Sub : 15 Byte(s): 40 - Ok 17:05:55 : Field : 116 Sub : 16 Byte(s): 40 - Ok 17:05:55 : Field : 117 Sub : 0 Byte(s): 4 - Ok 17:05:55 : Field : 117 Sub : 1 Byte(s): 3 - Ok 17:05:55 : Field : 117 Sub : 2 Byte(s): 6 - Ok 17:05:55 : Field : 117 Sub : 3 Byte(s): 1 - Ok 17:05:55 : Field : 117 Sub : 4 Byte(s): 9 - Ok 17:05:55 : Field : 117 Sub : 5 Byte(s): 10 - Ok 17:05:55 : Field : 117 Sub : 6 Byte(s): 8 - Ok 17:05:55 : Field : 117 Sub : 13 Byte(s): 3 - Ok 17:05:55 : Field : 117 Sub : 14 Byte(s): 3 - Ok 17:05:55 : Field : 117 Sub : 16 Byte(s): 40 - Ok 17:05:55 : Field : 120 Sub : 0 Byte(s): 944 - Ok 17:05:55 : Field : 120 Sub : 1 Byte(s): 160 - Ok 17:05:55 : Field : 120 Sub : 2 Byte(s): 130 - Ok 17:05:55 : Field : 120 Sub : 3 Byte(s): 112 - Ok 17:05:56 : Field : 153 Sub : 0 Byte(s): 68 - Ok 17:05:56 : Field : 153 Sub : 1 Byte(s): 68 - Ok 17:05:56 : Field : 153 Sub : 2 Byte(s): 68 - Ok 17:05:56 : Field : 153 Sub : 3 Byte(s): 68 - Ok 17:05:56 : Field : 153 Sub : 4 Byte(s): 68 - Ok 17:05:56 : Field : 153 Sub : 5 Byte(s): 68 - Ok 17:05:56 : Field : 163 Sub : 0 Byte(s): 8 - Ok 17:05:56 : Field : 193 Sub : 2 Byte(s): 8 - Ok 17:05:56 : Field : 193 Sub : 3 Byte(s): 32 - Ok 17:05:56 : Field : 193 Sub : 4 Byte(s): 32 - Ok 17:05:56 : Field : 193 Sub : 8 Byte(s): 228 - Ok 17:05:56 : Field : 193 Sub : 9 Byte(s): 64 - Ok 17:05:56 : Field : 202 Sub : 0 Byte(s): 1 - Ok 17:05:56 : Field : 202 Sub : 1 Byte(s): 780 - Ok 17:05:57 : Field : 217 Sub : 0 Byte(s): 32 - Ok 17:05:57 : Field : 218 Sub : 0 Byte(s): 2 - Ok 17:05:57 : Field : 232 Sub : 0 Byte(s): 20 - Ok 17:05:57 : Field : 232 Sub : 2 Byte(s): 1 - Ok 17:05:57 : Field : 232 Sub : 3 Byte(s): 1 - Ok 17:05:57 : Field : 238 Sub : 1 Byte(s): 1 - Ok 17:05:57 : Field : 239 Sub : 0 Byte(s): 2 - Ok 17:05:58 : Field : 239 Sub : 1 Byte(s): 3057 - Ok 17:05:58 : Field : 239 Sub : 2 Byte(s): 3057 - Ok 17:05:59 : Field : 239 Sub : 3 Byte(s): 3057 - Ok 17:05:59 : Field : 239 Sub : 4 Byte(s): 3057 - Ok 17:06:00 : Field : 239 Sub : 5 Byte(s): 3057 - Ok 17:06:01 : Field : 250 Sub : 1 Byte(s): 2156 - Ok 17:06:01 : Field : 250 Sub : 2 Byte(s): 128 - Ok 17:06:01 : Field : 250 Sub : 3 Byte(s): 752 - Ok 17:06:01 : Field : 250 Sub : 4 Byte(s): 40 - Ok 17:06:02 : Field : 297 Sub : 2 Byte(s): 2400 - Ok 17:06:02 : Field : 298 Sub : 0 Byte(s): 2 - Ok 17:06:02 : Field : 301 Sub : 0 Byte(s): 2 - Ok 17:06:02 : Field : 301 Sub : 1 Byte(s): 12 - Ok 17:06:02 : Field : 301 Sub : 2 Byte(s): 36 - Ok 17:06:02 : Field : 301 Sub : 3 Byte(s): 36 - Ok 17:06:02 : Field : 301 Sub : 4 Byte(s): 36 - Ok 17:06:02 : Field : 301 Sub : 5 Byte(s): 36 - Ok 17:06:02 : Field : 301 Sub : 6 Byte(s): 36 - Ok 17:06:02 : Field : 301 Sub : 7 Byte(s): 40 - Ok 17:06:02 : Field : 301 Sub : 8 Byte(s): 40 - Ok 17:06:02 : Field : 301 Sub : 9 Byte(s): 40 - Ok 17:06:02 : Field : 301 Sub : 10 Byte(s): 40 - Ok 17:06:02 : Field : 301 Sub : 11 Byte(s): 40 - Ok 17:06:02 : Field : 301 Sub : 12 Byte(s): 40 - Ok 17:06:03 : Field : 301 Sub : 13 Byte(s): 40 - Ok 17:06:03 : Field : 301 Sub : 14 Byte(s): 40 - Ok 17:06:03 : Field : 301 Sub : 15 Byte(s): 40 - Ok 17:06:03 : Field : 301 Sub : 16 Byte(s): 40 - Ok 17:06:03 : Field : 302 Sub : 0 Byte(s): 36 - Ok 17:06:03 : Field : 309 Sub : 0 Byte(s): 4 - [Requires SX4] 17:06:03 : Field : 309 Sub : 1 Byte(s): 2 - [Requires SX4] 17:06:03 : Field : 309 Sub : 2 Byte(s): 12 - [Requires SX4] 17:06:03 : Field : 309 Sub : 4 Byte(s): 12 - [Requires SX4] 17:06:03 : Field : 309 Sub : 5 Byte(s): 12 - [Requires SX4] 17:06:03 : Field : 309 Sub : 7 Byte(s): 12 - [Requires SX4] 17:06:04 : Field : 309 Sub : 8 Byte(s): 12 - [Requires SX4] 17:06:04 : Field : 309 Sub : 17 Byte(s): 12 - [Requires SX4] 17:06:04 : Field : 309 Sub : 22 Byte(s): 12 - [Requires SX4] 17:06:04 : Field : 319 Sub : 0 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 1 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 2 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 3 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 4 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 5 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 6 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 7 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 8 Byte(s): 148 - Ok 17:06:04 : Field : 319 Sub : 9 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 10 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 11 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 12 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 13 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 14 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 15 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 16 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 17 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 18 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 19 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 20 Byte(s): 148 - Ok 17:06:05 : Field : 319 Sub : 21 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 22 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 23 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 24 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 25 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 26 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 27 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 28 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 29 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 30 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 31 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 32 Byte(s): 148 - Ok 17:06:06 : Field : 319 Sub : 33 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 34 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 35 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 36 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 37 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 38 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 39 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 40 Byte(s): 148 - Ok 17:06:07 : Field : 319 Sub : 41 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 42 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 43 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 44 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 45 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 46 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 47 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 48 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 49 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 50 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 51 Byte(s): 148 - Ok 17:06:08 : Field : 319 Sub : 52 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 53 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 54 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 55 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 56 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 57 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 58 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 59 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 60 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 61 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 62 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 63 Byte(s): 148 - Ok 17:06:09 : Field : 319 Sub : 64 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 65 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 66 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 67 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 68 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 69 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 70 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 71 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 72 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 73 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 74 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 75 Byte(s): 148 - Ok 17:06:10 : Field : 319 Sub : 76 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 77 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 78 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 79 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 80 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 81 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 82 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 83 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 84 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 85 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 86 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 87 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 88 Byte(s): 148 - Ok 17:06:11 : Field : 319 Sub : 89 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 90 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 91 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 92 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 93 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 94 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 95 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 96 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 97 Byte(s): 148 - Ok 17:06:12 : Field : 319 Sub : 98 Byte(s): 148 - Ok 17:06:12 : Field : 320 Sub : 0 Byte(s): 148 - Ok 17:06:12 : Field : 320 Sub : 1 Byte(s): 148 - Ok 17:06:12 : Field : 320 Sub : 2 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 3 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 4 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 5 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 6 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 7 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 8 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 9 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 10 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 11 Byte(s): 148 - Ok 17:06:13 : Field : 320 Sub : 12 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 13 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 14 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 15 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 16 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 17 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 18 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 19 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 20 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 21 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 22 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 23 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 24 Byte(s): 148 - Ok 17:06:14 : Field : 320 Sub : 25 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 26 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 27 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 28 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 29 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 30 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 31 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 32 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 33 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 34 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 35 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 36 Byte(s): 148 - Ok 17:06:15 : Field : 320 Sub : 37 Byte(s): 148 - Ok 17:06:16 : Field : 320 Sub : 38 Byte(s): 148 - Ok 17:06:16 : Field : 322 Sub : 0 Byte(s): 1 - Ok 17:06:16 : Field : 325 Sub : 0 Byte(s): 95 - Ok 17:06:16 : Field : 325 Sub : 1 Byte(s): 49 - Ok 17:06:16 : Field : 325 Sub : 2 Byte(s): 101 - Ok 17:06:16 : Field : 325 Sub : 3 Byte(s): 45 - Ok 17:06:16 : Field : 325 Sub : 4 Byte(s): 120 - Ok 17:06:16 : Field : 325 Sub : 5 Byte(s): 53 - Ok 17:06:16 : Field : 325 Sub : 6 Byte(s): 58 - Ok 17:06:16 : Field : 325 Sub : 7 Byte(s): 48 - Ok 17:06:16 : Field : 325 Sub : 8 Byte(s): 41 - Ok 17:06:17 : Field : 325 Sub : 9 Byte(s): 73 - Ok 17:06:17 : Field : 325 Sub : 10 Byte(s): 65 - Ok 17:06:17 : Field : 325 Sub : 11 Byte(s): 87 - Ok 17:06:17 : Field : 325 Sub : 12 Byte(s): 72 - Ok 17:06:17 : Field : 325 Sub : 13 Byte(s): 58 - Ok 17:06:17 : Field : 325 Sub : 14 Byte(s): 113 - Ok 17:06:17 : Field : 325 Sub : 15 Byte(s): 59 - Ok 17:06:17 : Field : 325 Sub : 16 Byte(s): 40 - Ok 17:06:17 : Field : 325 Sub : 17 Byte(s): 67 - Ok 17:06:17 : Field : 325 Sub : 18 Byte(s): 45 - Ok 17:06:17 : Field : 325 Sub : 19 Byte(s): 39 - Ok 17:06:17 : Field : 334 Sub : 0 Byte(s): 1 - Ok 17:06:18 : Field : 339 Sub : 0 Byte(s): 511 - Ok 17:06:18 : Field : 339 Sub : 1 Byte(s): 511 - Ok 17:06:18 : Field : 341 Sub : 0 Byte(s): 1 - Ok 17:06:18 : Field : 341 Sub : 3 Byte(s): 4 - Ok 17:06:19 : Field : 341 Sub : 4 Byte(s): 4424 - Ok 17:06:19 : Field : 345 Sub : 0 Byte(s): 12 - Ok 17:06:19 : Field : 354 Sub : 0 Byte(s): 33 - Ok 17:06:19 : Field : 355 Sub : 1 Byte(s): 2028 - Ok 17:06:20 : Field : 356 Sub : 0 Byte(s): 2 - Ok 17:06:20 : Field : 362 Sub : 0 Byte(s): 1 - Ok 17:06:20 : Field : 362 Sub : 1 Byte(s): 120 - Ok 17:06:20 : Field : 364 Sub : 0 Byte(s): 2 - Ok 17:06:20 : Field : 364 Sub : 1 Byte(s): 12 - Ok 17:06:20 : Field : 364 Sub : 2 Byte(s): 36 - Ok 17:06:20 : Field : 364 Sub : 3 Byte(s): 36 - Ok 17:06:20 : Field : 364 Sub : 4 Byte(s): 36 - Ok 17:06:20 : Field : 364 Sub : 5 Byte(s): 36 - Ok 17:06:20 : Field : 364 Sub : 6 Byte(s): 36 - Ok 17:06:20 : Field : 364 Sub : 7 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 8 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 9 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 10 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 11 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 12 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 13 Byte(s): 40 - Ok 17:06:20 : Field : 364 Sub : 14 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 0 Byte(s): 2 - Ok 17:06:21 : Field : 365 Sub : 1 Byte(s): 12 - Ok 17:06:21 : Field : 365 Sub : 2 Byte(s): 36 - Ok 17:06:21 : Field : 365 Sub : 3 Byte(s): 36 - Ok 17:06:21 : Field : 365 Sub : 4 Byte(s): 36 - Ok 17:06:21 : Field : 365 Sub : 5 Byte(s): 36 - Ok 17:06:21 : Field : 365 Sub : 6 Byte(s): 36 - Ok 17:06:21 : Field : 365 Sub : 7 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 8 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 9 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 10 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 11 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 12 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 13 Byte(s): 40 - Ok 17:06:21 : Field : 365 Sub : 14 Byte(s): 40 - Ok 17:06:21 : PM Upload Done!... 17:07:02 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355212037429562\SL3_certifica te_V 07.97 13-09-10 RM-495 (c) Nokia_355212037429562__113430.pm 17:07:02 : Start Uploading PM... 17:07:03 : 17:07:03 : ================================================ 17:07:03 : Basic Phone Information 17:07:03 : ================================================ 17:07:03 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:03 : IMEI Plain : 355212037429562 17:07:03 : IMEI Spare : A355212037429560 17:07:03 : IMEI SV : 33552120374295658F 17:07:03 : Phone Model: Nokia 5130c-2 17:07:03 : Category : Classic Phone 17:07:03 : Phone Type : RM-495 17:07:03 : 17:07:03 : 17:07:03 : Field : 120 Sub : 0 Byte(s): 944 - Ok 17:07:03 : Field : 120 Sub : 1 Byte(s): 160 - Ok 17:07:04 : Field : 120 Sub : 2 Byte(s): 132 - Ok 17:07:04 : Field : 120 Sub : 3 Byte(s): 112 - Ok 17:07:05 : Field : 308 Sub : 1 Super Dongle Key Found 17:07:07 : Field : 308 Sub : 1 Write Super Dongle Key - OK 17:07:07 : Field : 308 Sub : 1 CMLA Key Found 17:07:08 : Field : 308 Sub : 1 Write CMLA Key - Failed 17:07:08 : PM Upload Done!... 17:07:14 : 17:07:14 : FACTORY SET TO : Full Factory Set 17:07:15 : (Backing Up MMC Password...) 17:07:15 : Saved MMC Password to: 17:07:15 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\355212037429562\MMC_PASSWORD_ 355212037429562_50715.pm 17:07:17 : OK 17:07:17 : FACTORY SET TO : User Data 17:07:17 : OK 17:07:17 : FACTORY SET TO : Leave Factory 17:07:17 : OK 17:07:17 : FACTORY SET TO : Service Center 17:07:17 : OK 17:07:17 : FACTORY SET TO : Software Upgrade 17:07:17 : OK 17:07:17 : FACTORY SET TO : Production Tune 17:07:17 : OK 17:07:19 : 17:07:19 : 17:07:19 : ================================================ 17:07:19 : Basic Phone Information 17:07:19 : ================================================ 17:07:19 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:19 : IMEI Plain : 355212037429562 17:07:19 : IMEI Spare : A355212037429560 17:07:19 : IMEI SV : 33552120374295658F 17:07:20 : Phone Model: Nokia 5130c-2 17:07:20 : Category : Classic Phone 17:07:20 : Phone Type : RM-495 17:07:20 : 17:07:20 : ================================================ 17:07:20 : Extended Phone Information 17:07:20 : ================================================ 17:07:20 : Product Serial Number: IBX011802 17:07:20 : Product Code : 0578115 17:07:20 : Module Code : 0204024 17:07:20 : Basic Production Code: 0567772 17:07:20 : Long Production SN : 0 17:07:20 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:07:20 : BT MCM Version : 2222-302 17:07:21 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:07:21 : HW Version : 2000 17:07:21 : RFIC Version : 06540601 17:07:21 : DSP Version : ICPR72_10w01 17:07:21 : LCD Version : SEIKO 17:07:21 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:07:21 : AHNE Version : 30 17:07:22 : RETU Version : 16 17:07:22 : TAHVO Version : 22 17:07:22 : Bluetooth ID : 00:25:CF:A38:18 17:07:22 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:07:22 : 17:07:22 : ================================================ 17:07:22 : Simlock Information 17:07:22 : ================================================ 17:07:22 : Unable to read SP Data.. 17:07:26 : 17:07:26 : ================================================ 17:07:26 : Basic Phone Information 17:07:26 : ================================================ 17:07:26 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:26 : IMEI Plain : 355212037429562 17:07:26 : IMEI Spare : A355212037429560 17:07:26 : IMEI SV : 33552120374295658F 17:07:26 : Phone Model: Nokia 5130c-2 17:07:26 : Category : Classic Phone 17:07:26 : Phone Type : RM-495 17:07:26 : 17:07:26 : ================================================ 17:07:26 : Extended Phone Information 17:07:26 : ================================================ 17:07:26 : Product Serial Number: IBX011802 17:07:26 : Product Code : 0578115 17:07:26 : Module Code : 0204024 17:07:26 : Basic Production Code: 0567772 17:07:27 : Long Production SN : 0 17:07:27 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:07:27 : BT MCM Version : 2222-302 17:07:27 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:07:27 : HW Version : 2000 17:07:27 : RFIC Version : 06540601 17:07:27 : DSP Version : ICPR72_10w01 17:07:27 : LCD Version : SEIKO 17:07:28 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:07:28 : AHNE Version : 30 17:07:28 : RETU Version : 16 17:07:28 : TAHVO Version : 22 17:07:28 : Bluetooth ID : 00:25:CF:A38:18 17:07:29 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:07:29 : 17:07:29 : ================================================ 17:07:29 : Simlock Information 17:07:29 : ================================================ 17:07:29 : Unable to read SP Data.. 17:07:29 : SECURITY_TEST : PASSED 17:07:29 : SECURITY_CODE : 12345 17:07:29 : PHONE_MODE : TEST 17:07:29 : 17:07:30 : 17:07:30 : ================================================== ==== 17:07:30 : Selected VPL File: 17:07:30 : RM495_0571965_07.97_033.vpl 17:07:30 : ================================================== ==== 17:07:30 : Variant Details : INDIA-MH, HINDI, RED 17:07:30 : Software Version : 07.97 17:07:30 : Product Type : RM-495 17:07:30 : Product Code : 0571965 17:07:30 : Variant Version : 033 17:07:30 : 17:07:40 : 17:07:40 : ================================================ 17:07:40 : Basic Phone Information 17:07:40 : ================================================ 17:07:40 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:40 : IMEI Plain : 355212037429562 17:07:40 : IMEI Spare : A355212037429560 17:07:40 : IMEI SV : 33552120374295658F 17:07:40 : Phone Model: Nokia 5130c-2 17:07:40 : Category : Classic Phone 17:07:40 : Phone Type : RM-495 17:07:40 : 17:07:40 : 17:07:40 : 17:07:40 : ================================================ 17:07:40 : CMLA KEY RPL Stand Alone Edition 17:07:40 : ================================================ 17:07:40 : Generating CMLA KEY RPL... 17:07:40 : Sending CMLA Key RPL... 17:07:41 : OK: CMLA Key RPL Accepted 17:07:41 : 17:07:41 : Successfully done. 17:07:47 : 17:07:47 : FACTORY SET TO : Full Factory Set 17:07:48 : OK 17:07:48 : FACTORY SET TO : User Data 17:07:48 : OK 17:07:48 : FACTORY SET TO : Leave Factory 17:07:48 : OK 17:07:48 : FACTORY SET TO : Service Center 17:07:48 : OK 17:07:48 : FACTORY SET TO : Software Upgrade 17:07:48 : OK 17:07:48 : FACTORY SET TO : Production Tune 17:07:48 : OK 17:07:51 : 17:07:52 : 17:07:52 : ================================================ 17:07:52 : Basic Phone Information 17:07:52 : ================================================ 17:07:52 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:52 : IMEI Plain : 355212037429562 17:07:52 : IMEI Spare : A355212037429560 17:07:52 : IMEI SV : 33552120374295658F 17:07:52 : Phone Model: Nokia 5130c-2 17:07:52 : Category : Classic Phone 17:07:52 : Phone Type : RM-495 17:07:52 : 17:07:52 : ================================================ 17:07:52 : Extended Phone Information 17:07:52 : ================================================ 17:07:52 : Product Serial Number: IBX011802 17:07:52 : Product Code : 0578115 17:07:52 : Module Code : 0204024 17:07:52 : Basic Production Code: 0567772 17:07:53 : Long Production SN : 0 17:07:53 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:07:53 : BT MCM Version : 2222-302 17:07:53 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:07:53 : HW Version : 2000 17:07:53 : RFIC Version : 06540601 17:07:53 : DSP Version : ICPR72_10w01 17:07:53 : LCD Version : SEIKO 17:07:54 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:07:54 : AHNE Version : 30 17:07:54 : RETU Version : 16 17:07:54 : TAHVO Version : 22 17:07:54 : Bluetooth ID : 00:25:CF:A38:18 17:07:55 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:07:55 : 17:07:55 : ================================================ 17:07:55 : Simlock Information 17:07:55 : ================================================ 17:07:55 : Unable to read SP Data.. 17:07:58 : 17:07:58 : ================================================ 17:07:58 : Basic Phone Information 17:07:58 : ================================================ 17:07:58 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:07:58 : IMEI Plain : 355212037429562 17:07:59 : IMEI Spare : A355212037429560 17:07:59 : IMEI SV : 33552120374295658F 17:07:59 : Phone Model: Nokia 5130c-2 17:07:59 : Category : Classic Phone 17:07:59 : Phone Type : RM-495 17:07:59 : 17:07:59 : ================================================ 17:07:59 : Extended Phone Information 17:07:59 : ================================================ 17:07:59 : Product Serial Number: IBX011802 17:07:59 : Product Code : 0578115 17:07:59 : Module Code : 0204024 17:07:59 : Basic Production Code: 0567772 17:07:59 : Long Production SN : 0 17:07:59 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:07:59 : BT MCM Version : 2222-302 17:08:00 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:08:00 : HW Version : 2000 17:08:00 : RFIC Version : 06540601 17:08:00 : DSP Version : ICPR72_10w01 17:08:00 : LCD Version : SEIKO 17:08:00 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:08:00 : AHNE Version : 30 17:08:01 : RETU Version : 16 17:08:01 : TAHVO Version : 22 17:08:01 : Bluetooth ID : 00:25:CF:A38:18 17:08:01 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:08:01 : 17:08:01 : ================================================ 17:08:01 : Simlock Information 17:08:01 : ================================================ 17:08:01 : Unable to read SP Data.. 17:08:01 : SECURITY_TEST : PASSED 17:08:01 : SECURITY_CODE : 12345 17:08:02 : PHONE_MODE : TEST 17:08:02 : 17:08:02 : 17:08:02 : ================================================== ==== 17:08:02 : Selected VPL File: 17:08:02 : RM495_0571965_07.97_033.vpl 17:08:02 : ================================================== ==== 17:08:02 : Variant Details : INDIA-MH, HINDI, RED 17:08:02 : Software Version : 07.97 17:08:02 : Product Type : RM-495 17:08:02 : Product Code : 0571965 17:08:02 : Variant Version : 033 17:08:02 : 17:08:20 : 17:08:20 : 17:08:20 : *************************************** 17:08:20 : Connecting to : 59.148.208.118 17:08:22 : SX4 IS IN USE, TRY AGAIN!!! 17:08:22 : 17:08:22 : *************************************** 17:08:22 : Connecting to : 59.148.208.118 17:08:24 : >> Connect timed out. 17:08:24 : 17:08:24 : 17:08:40 : 17:08:40 : 17:08:40 : *************************************** 17:08:40 : Connecting to : 59.148.208.118 17:08:41 : 17:08:41 : Welcome to ATF SX4 Server v1.50 17:08:41 : >> Connection accepted 17:08:43 : 17:08:43 : ================================================ 17:08:43 : Basic Phone Information 17:08:43 : ================================================ 17:08:43 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:08:43 : IMEI Plain : 355212037429562 17:08:43 : IMEI Spare : A355212037429560 17:08:43 : IMEI SV : 33552120374295658F 17:08:44 : Phone Model: Nokia 5130c-2 17:08:44 : Category : Classic Phone 17:08:44 : Phone Type : RM-495 17:08:44 : 17:08:44 : 17:08:44 : STEP 1... 17:08:45 : STEP 2... 17:08:48 : STEP 3... 17:08:48 : 17:08:48 : PM Authorize Successful! 17:08:48 : 17:08:48 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355212037429562\SL3_certifica te_V 07.97 13-09-10 RM-495 (c) Nokia_355212037429562__113430.pm 17:08:48 : Start Uploading PM... 17:08:48 : Field : 120 Sub : 0 Byte(s): 944 - Ok 17:08:48 : Field : 120 Sub : 1 Byte(s): 160 - Ok 17:08:48 : Field : 120 Sub : 2 Byte(s): 132 - Ok 17:08:48 : Field : 120 Sub : 3 Byte(s): 112 - Ok 17:08:50 : Field : 308 Sub : 1 Super Dongle Key Found 17:08:52 : Field : 308 Sub : 1 Write Super Dongle Key - OK 17:08:52 : Field : 308 Sub : 1 CMLA Key Found 17:08:53 : Field : 308 Sub : 1 Write CMLA Key - Failed 17:08:53 : PM Upload Done!... 17:09:00 : 17:09:00 : FACTORY SET TO : Full Factory Set 17:09:01 : OK 17:09:01 : FACTORY SET TO : User Data 17:09:01 : OK 17:09:01 : FACTORY SET TO : Leave Factory 17:09:01 : OK 17:09:01 : FACTORY SET TO : Service Center 17:09:01 : OK 17:09:01 : FACTORY SET TO : Software Upgrade 17:09:01 : OK 17:09:01 : FACTORY SET TO : Production Tune 17:09:01 : OK 17:09:03 : 17:09:04 : 17:09:04 : ================================================ 17:09:04 : Basic Phone Information 17:09:04 : ================================================ 17:09:04 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:09:04 : IMEI Plain : 355212037429562 17:09:04 : IMEI Spare : A355212037429560 17:09:04 : IMEI SV : 33552120374295658F 17:09:04 : Phone Model: Nokia 5130c-2 17:09:04 : Category : Classic Phone 17:09:04 : Phone Type : RM-495 17:09:04 : 17:09:04 : ================================================ 17:09:04 : Extended Phone Information 17:09:04 : ================================================ 17:09:04 : Product Serial Number: IBX011802 17:09:04 : Product Code : 0578115 17:09:04 : Module Code : 0204024 17:09:04 : Basic Production Code: 0567772 17:09:05 : Long Production SN : 0 17:09:05 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:09:05 : BT MCM Version : 2222-302 17:09:05 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:09:05 : HW Version : 2000 17:09:05 : RFIC Version : 06540601 17:09:06 : DSP Version : ICPR72_10w01 17:09:06 : LCD Version : SEIKO 17:09:06 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:09:06 : AHNE Version : 30 17:09:06 : RETU Version : 16 17:09:06 : TAHVO Version : 22 17:09:06 : Bluetooth ID : 00:25:CF:A38:18 17:09:07 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:09:07 : 17:09:07 : ================================================ 17:09:07 : Simlock Information 17:09:07 : ================================================ 17:09:07 : Unable to read SP Data.. 17:09:10 : 17:09:10 : ================================================ 17:09:10 : Basic Phone Information 17:09:10 : ================================================ 17:09:10 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia 17:09:10 : IMEI Plain : 355212037429562 17:09:11 : IMEI Spare : A355212037429560 17:09:11 : IMEI SV : 33552120374295658F 17:09:11 : Phone Model: Nokia 5130c-2 17:09:11 : Category : Classic Phone 17:09:11 : Phone Type : RM-495 17:09:11 : 17:09:11 : ================================================ 17:09:11 : Extended Phone Information 17:09:11 : ================================================ 17:09:11 : Product Serial Number: IBX011802 17:09:11 : Product Code : 0578115 17:09:11 : Module Code : 0204024 17:09:11 : Basic Production Code: 0567772 17:09:11 : Long Production SN : 0 17:09:11 : PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH 17:09:11 : BT MCM Version : 2222-302 17:09:12 : MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia 17:09:12 : HW Version : 2000 17:09:12 : RFIC Version : 06540601 17:09:12 : DSP Version : ICPR72_10w01 17:09:12 : LCD Version : SEIKO 17:09:12 : Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia 17:09:12 : AHNE Version : 30 17:09:13 : RETU Version : 16 17:09:13 : TAHVO Version : 22 17:09:13 : Bluetooth ID : 00:25:CF:A38:18 17:09:13 : CS Type : GSM850, GSM900, GSM1800, GSM1900 17:09:13 : 17:09:13 : ================================================ 17:09:13 : Simlock Information 17:09:13 : ================================================ 17:09:13 : Unable to read SP Data.. 17:09:13 : SECURITY_TEST : PASSED 17:09:13 : SECURITY_CODE : 12345 17:09:14 : PHONE_MODE : TEST 17:09:14 : 17:09:14 : 17:09:14 : ================================================== ==== 17:09:14 : Selected VPL File: 17:09:14 : RM495_0571965_07.97_033.vpl 17:09:14 : ================================================== ==== 17:09:14 : Variant Details : INDIA-MH, HINDI, RED 17:09:14 : Software Version : 07.97 17:09:14 : Product Type : RM-495 17:09:14 : Product Code : 0571965 17:09:14 : Variant Version : 033 17:09:14 : |
06-19-2013, 14:47 | #7 (permalink) |
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | same problem sir.... Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0E100118 ID DWORD 1 : 026C7D56 ID DWORD 2 : B48912F0 ID DWORD 3 : 16B3D952 ID DWORD 4 : 11715279 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum AD SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 =========================================== PHONE FIRMWARE VERSION: V 07.97 13-09-10 RM-495 (c) Nokia =========================================== VPP Enabled by Software Using Internal VPP TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Write Certificates OK! Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia IMEI Plain : 355212037429562 IMEI Spare : A355212037429560 IMEI SV : 33552120374295658F Phone Model: Nokia 5130c-2 Category : Classic Phone Phone Type : RM-495 Writing: SIMLOCK_DATA + SIMLOCK_KEY_DATA ERROR: SIMLOCK_DATA NOT ACCEPTED RPL Upload Finished!!! FACTORY SET TO : Full Factory Set OK Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia IMEI Plain : 355212037429562 IMEI Spare : A355212037429560 IMEI SV : 33552120374295658F Phone Model: Nokia 5130c-2 Category : Classic Phone Phone Type : RM-495 ================================================ Extended Phone Information ================================================ Product Serial Number: IBX011802 Product Code : 0578115 Module Code : 0204024 Basic Production Code: 0567772 Long Production SN : 0 PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH BT MCM Version : 2222-302 MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_10w01 LCD Version : SEIKO Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia AHNE Version : 30 RETU Version : 16 TAHVO Version : 22 Bluetooth ID : 00:25:CF:A38:18 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ Unable to read SP Data.. Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia IMEI Plain : 355212037429562 IMEI Spare : A355212037429560 IMEI SV : 33552120374295658F Phone Model: Nokia 5130c-2 Category : Classic Phone Phone Type : RM-495 ================================================ Extended Phone Information ================================================ Product Serial Number: IBX011802 Product Code : 0578115 Module Code : 0204024 Basic Production Code: 0567772 Long Production SN : 0 PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH BT MCM Version : 2222-302 MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_10w01 LCD Version : SEIKO Content Pack Version : Content: mh_red V 07.97 13-09-10 RM-495 (c) Nokia AHNE Version : 30 RETU Version : 16 TAHVO Version : 22 Bluetooth ID : 00:25:CF:A38:18 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================== ==== Selected VPL File: RM495_0571965_07.97_033.vpl ================================================== ==== Variant Details : INDIA-MH, HINDI, RED Software Version : 07.97 Product Type : RM-495 Product Code : 0571965 Variant Version : 033 |
06-20-2013, 06:40 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Not same problem - RPL not write Quote:
Br - srinibas | |
