04-11-2010, 10:50 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Malaysia Age: 41
Member: 44095 Status: Offline Thanks Meter: 38 | 2330,6600s and some model flashing problem but always show error, so and i use other product example mxkey or hwk it work and without error. if have user manual incase i wrong use this. 2nd problem how to login support area? thanks |
04-11-2010, 18:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @plentong It is possible that the errors are caused by improper istallation of drivers. MXKEY and HWK both use FTDI drivers. They both use very old not update drivers as well. When you install ATF and if it asks you to overwrite files, you better click "YES". MXKEY and HWK will not be affected when using the latest drivers because the latest drivers are still from FTDI. Also, it would help me figure out the problem if you post me some logs on where the ERROR is occuring. You can check here: C:\Program Files\AdvanceBox Turbo Flasher\Logs\ ATF software will save all the logs. B/R |
04-12-2010, 10:05 | #3 (permalink) |
Member: 44095 Status: Offline Thanks Meter: 38 | Log here 16:56:51 : Box Name : AdvanceBox Turbo 16:56:51 : Box Firmware : LogiCore 3.30.10 16:56:51 : Software Version : v4.70 16:56:51 : AdvanceBox SN : E5 16:56:51 : BOX Status : ACTIVATED 16:56:51 : INIT : OK 16:56:51 : 16:56:51 : VBATT OFF ... 16:56:54 : VBATT ON 16:56:55 : Setting VBATT Done!... 16:57:11 : Changing MODE : FLASH 16:57:11 : AdvanceFBox SendBootCodeEx 16:57:11 : InitialiseBootstrap_DCT5 DIR 16:57:11 : BootFlashMode_DCT5 16:57:11 : 16:57:11 : ************************************************** **** 16:57:11 : TIME START HERE 16:57:11 : ************************************************** **** 16:57:11 : 16:57:11 : BootFlashModeDCT5Ex Succeeded First Time 16:57:11 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 16:57:12 : Number of Sub Blocks 7 (0x07) 16:57:12 : 1 SYSTEM_ASIC_ID 01 16:57:12 : Block Length : 21 (15) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : ID DWORD 0 : 00000001 16:57:12 : ID DWORD 1 : 00000226 16:57:12 : ID DWORD 2 : 00010006 16:57:12 : ID DWORD 3 : 030C1921 16:57:12 : ID DWORD 4 : 01023000 16:57:12 : 2 ROM_ID 15 16:57:12 : Block Length : 5 (05) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : ID DWORD 0 : 00000295 16:57:12 : 3 ROM_ID 15 16:57:12 : Block Length : 5 (05) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : ID DWORD 0 : 00000B22 16:57:12 : 4 PUBLIC_ID 12 16:57:12 : Block Length : 21 (15) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : ID DWORD 0 : 1A900202 16:57:12 : ID DWORD 1 : 3A657D56 16:57:12 : ID DWORD 2 : D826DE43 16:57:12 : ID DWORD 3 : 1DB1296A 16:57:12 : ID DWORD 4 : E441973D 16:57:12 : 5 ASIC_MODE_ID 13 16:57:12 : Block Length : 2 (02) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : Mode Id : 00 16:57:12 : 6 ROOT_KEY_HASH 14 16:57:12 : Block Length : 17 (11) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 16:57:12 : 7 ROM_ID 15 16:57:12 : Block Length : 9 (09) 16:57:12 : BB ASIC Index : 0 (00) CMT 16:57:12 : CRC 0 : 273F6D55 16:57:12 : CRC 1 : DFAAF68F 16:57:12 : Checksum 0E 16:57:12 : BootCodeLen : 61 16:57:12 : SearchForBootstrap_DCT5.. 16:57:14 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg 16:57:14 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 16:57:16 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 16:57:16 : MCU_CONFIGURATION_RESPONSE_BB5: 16:57:21 : ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT 16:57:21 : ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT 16:57:21 : Process Done! 16:57:27 : 16:57:27 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-570\rm570__36.60.mcusw 16:57:29 : CMT Type : BB5 16:57:29 : CMT Algorithm : XSR 1.5 16:57:29 : CMT Supported Hardwares : 16:57:29 : > 0103192101003000 16:57:29 : > 010C192101003000 16:57:29 : > 030C192101023000 16:57:29 : Secondary Sending Speed : 3250000Hz 16:57:29 : Algorithm Sending Speed : 6500000Hz 16:57:29 : Program Sending Speed : 6500000Hz 16:57:29 : Message Reading Speed : 98000Hz 16:57:29 : Number of Blocks : 116 16:57:29 : Entry Point: 0x4563 16:57:29 : Page Format : -1 16:57:29 : MAX PAGE : 0x00040000 16:57:31 : 16:57:31 : VBATT OFF ... 16:57:35 : VBATT ON 16:57:35 : Setting VBATT Done!... 16:57:36 : AdvanceFBox SendBootCodeEx 16:57:36 : InitialiseBootstrap_DCT5 DIR 16:57:36 : BootFlashMode_DCT5 16:57:36 : 16:57:36 : ************************************************** **** 16:57:36 : TIME START HERE 16:57:36 : ************************************************** **** 16:57:36 : 16:57:36 : BootFlashModeDCT5Ex Succeeded First Time 16:57:36 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 16:57:36 : Number of Sub Blocks 7 (0x07) 16:57:36 : 1 SYSTEM_ASIC_ID 01 16:57:36 : Block Length : 21 (15) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : ID DWORD 0 : 00000001 16:57:36 : ID DWORD 1 : 00000226 16:57:36 : ID DWORD 2 : 00010006 16:57:36 : ID DWORD 3 : 030C1921 16:57:36 : ID DWORD 4 : 01023000 16:57:36 : 2 ROM_ID 15 16:57:36 : Block Length : 5 (05) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : ID DWORD 0 : 00000295 16:57:36 : 3 ROM_ID 15 16:57:36 : Block Length : 5 (05) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : ID DWORD 0 : 00000B22 16:57:36 : 4 PUBLIC_ID 12 16:57:36 : Block Length : 21 (15) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : ID DWORD 0 : 1A900202 16:57:36 : ID DWORD 1 : 3A657D56 16:57:36 : ID DWORD 2 : D826DE43 16:57:36 : ID DWORD 3 : 1DB1296A 16:57:36 : ID DWORD 4 : E441973D 16:57:36 : 5 ASIC_MODE_ID 13 16:57:36 : Block Length : 2 (02) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : Mode Id : 00 16:57:36 : 6 ROOT_KEY_HASH 14 16:57:36 : Block Length : 17 (11) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 16:57:36 : 7 ROM_ID 15 16:57:36 : Block Length : 9 (09) 16:57:36 : BB ASIC Index : 0 (00) CMT 16:57:36 : CRC 0 : 273F6D55 16:57:36 : CRC 1 : DFAAF68F 16:57:36 : Checksum 0E 16:57:36 : BootCodeLen : 61 16:57:36 : SearchForBootstrap_DCT5.. 16:57:37 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg 16:57:37 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 16:57:40 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 16:57:40 : MCU_CONFIGURATION_RESPONSE_BB5: 16:57:45 : ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT 16:57:45 : ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT 16:57:45 : Operations Failed.... 16:58:30 : Boot Check, Please wait... 16:59:23 : DCT4 Failed to BOOT 16:59:23 : BUSCheck FAILED 17:00:07 : Boot Check, Please wait... 17:01:01 : DCT4 Failed to BOOT 17:01:01 : BUSCheck FAILED |
04-12-2010, 11:05 | #4 (permalink) |
Member: 44095 Status: Offline Thanks Meter: 38 | Successful flash by hwk nokia 2323 1st Boot: Ok, DCT4, UPP: 3168 [Rm-543] [2.1.0.1] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x02FFFFFF,00898981,Int NU48F256 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 8493770412F29BCE8CAAE5C9C2 Decoded MSID: 2C40BAE9-009D5EFE-A8000000 Encoded FAID: DD555A31-383FC035-AECB04F9 IMAGE: rm543__09.55.mcusw Area1: 0x01000000-0x0101FFFF Erased, Time: 00:00 Area2: 0x01020000-0x01CFFFFF Erased, Time: 01:22 MCU Flashing Completed, Time: 13:55 Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 128k IMAGE: rm543__09.55.image_mr_bla Area1: 0x02180000-0x02E7FFFF Erased, Time: 01:56 Area2: 0x02E80000-0x02FBFFFF Erased, Time: 00:10 CNT Flashing Completed, Time: 04:35 Running: Nokia File Server Contents Package Extracting Ok, Time: 00:07 1st Boot: Ok, DCT4, UPP: 3168 [Rm-543] [2.1.0.1] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x02FFFFFF,00898981,Int NU48F256 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 84655ABC4EF6C802713384DFE8 Decoded MSID: 3E4EBAE9-009D5EFE-A9000000 Encoded FAID: 0287718B-CF6E0755-2D4ED6C9 IMAGE: rm543__09.55.ppm_mr Area1: 0x01D00000-0x0217FFFF Erased, Time: 00:19 PPM Flashing Completed, Time: 02:22 Flashing Completed, Rebooting Mobile please help me fix the problem thanks |
04-12-2010, 11:19 | #5 (permalink) |
Member: 44095 Status: Offline Thanks Meter: 38 | 8800 rm-233 flashing error Reading Phone Information... MCU: V 10.00 28-04-09 RM-233 (c) Nokia IMEI: 358645011504552 Product code : 0552268 ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER CONFIG KEY: 8000000000000002 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SL2 Phone Detected... Certificate saved to : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 10.00 28-04-09 RM-233 (c) Nokia_358645011504552_Not Locked_60907.pm Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C700111 ID DWORD 1 : E56D0254 ID DWORD 2 : 11115E4B ID DWORD 3 : 4A477B88 ID DWORD 4 : 8F18CFBF 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 17 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) START READING RPL DATA Reading : NPC OK Reading : VARIANT VARIANT : Empty Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\358645011504552\3586450115045 52_60941.rpl FlashInfo.RestartMode : 2 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-233\rm233__10.00.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 > 030C192101023000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1227 Entry Point: 0x4FFB Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C700111 ID DWORD 1 : E56D0254 ID DWORD 2 : 11115E4B ID DWORD 3 : 4A477B88 ID DWORD 4 : 8F18CFBF 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 17 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x002E (46) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00040000-000BFFFF 2 : 000C0000-0013FFFF 3 : 013C0000-0153FFFF 4 : 00140000-013BFFFF ERASE_REQUEST_BB5 : 5001122B000000000000000001FFFF00040000000BFFFF000C 00000013FFFF013C00000153FFFF00140000013BFFFFBB Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds >> Time Elapsed 20 seconds >> Time Elapsed 25 seconds >> Time Elapsed 30 seconds >> Time Elapsed 35 seconds >> Time Elapsed 40 seconds >> Time Elapsed 45 seconds >> Time Elapsed 50 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:54 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm233__10.00.mcusw Total blocks to write : 1227 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:48 Making delay between files for 1500ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-233\rm233__10.00.ppm_s CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 > 030C192101023000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 383 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C700111 ID DWORD 1 : E56D0254 ID DWORD 2 : 11115E4B ID DWORD 3 : 4A477B88 ID DWORD 4 : 8F18CFBF 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 17 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01540000-01BBFFFF ERASE_REQUEST_BB5 : 5001120B0000000154000001BBFFFFD2 Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:18 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm233__10.00.ppm_s Total blocks to write : 383 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:36 Making delay between files for 1500ms Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-233\rm233__10.00_ISM_002.image_s_gold CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 0103192101003000 > 010C192101003000 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 2622 Entry Point: 0x01AE Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C700111 ID DWORD 1 : E56D0254 ID DWORD 2 : 11115E4B ID DWORD 3 : 4A477B88 ID DWORD 4 : 8F18CFBF 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 17 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo_xsr15.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01EC0000-03F9FFFF 1 : 01BC0000-01EBFFFF ERASE_REQUEST_BB5 : 5001121300000001EC000003F9FFFF01BC000001EBFFFF4B Please wait ERASING......... >> Time Elapsed 5 seconds >> Time Elapsed 10 seconds >> Time Elapsed 15 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:17 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm233__10.00_ISM_002.image_s_gold Total blocks to write : 2622 Flashing FAILED Operations Failed.... |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
