2690 on usb took 09:33 mins And on ATF with FBUS took 06:38 mins See the speed of Advance Turbo Flasher FASTER THAN USB FLASH
2690 flash logs on usb cable Code:
Library version: 1.0.0.8018(17-04-2010), 1.0.0.12756(15-04-2010) Processing file: rm635__09.70.mcusw as MCU [BB5,BB5 ALGORITHM] size: 17.92 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 22CD5829 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 0840020C798D4950806CE00DA81F00A58938D410 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 2518388 [ADL] Verifying communication to device OK.
Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.625 s
CMT NOR area [000006C0-0001FFFF] erased in 0.657 s
CMT NOR area [00040000-000BFFFF] erased in 2.515 s
CMT NOR area [000C0000-0013FFFF] erased in 2.250 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 38.812 s
CMT NOR area [01380000-0151FFFF] erased in 8.797 s
Flash programming ...
CMT PAPUBKEYS: C6B9354E81AC464DED33FC7B90295086150F4539 (RAP Certificate v1 246) written.
Programming completed in 1 min 3.953 s Processing file: rm635__09.70.ppm_aa as PPM [BB5,BB5 ALGORITHM] size: 3.15 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 43.594 s
Programming completed in 11.500 s Processing file: rm635__09.70.image_aa_blue as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 7.51 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 22.672 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 17.047 s
Programming completed in 26.891 s [ADL] Pooling for ADL device
[ADL] Device found: nmwcdc\Nokia 2690 USB Generic, ID: 115F5C67 [ADL] Verifying communication to device OK. Flashing completed in 9 min 29.437 s
Phone Type: RM-635 (Nokia 2690) SW Version: V 09.70 08-02-10 RM-635 (c) Nokia Imei plain: 35826003618500-5 Product Code: 0592078
Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358260036185005 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 9 min 33.500 s
2960 flash logs on FBUS with ATF Code:
Reading Phone Information...
MCU: V 09.65 04-12-09 RM-635 (c) Nokia
IMEI: 358260036185005
Product code : 0592078
******** Reading SimLock ********
Simlock Version : SIMLOCK SERVER
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SL2 Phone Detected...
Certificate saved to : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 09.65 04-12-09 RM-635 (c) Nokia_358260036185005_Not Locked_44619.pm
Changing MODE : FLASH
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME START HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 0840020C
ID DWORD 1 : 798D4950
ID DWORD 2 : 806CE00D
ID DWORD 3 : A81F00A5
ID DWORD 4 : 8938D410
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C6
BootCodeLen : 61
SearchForBootstrap_DCT5..
CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 00400000 (4194304)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
START READING RPL DATA
Reading : NPC
OK
Reading : VARIANT
VARIANT : Empty
Reading : CCC
OK
Reading : HWC
OK
Reading : R&D
OK
FINISHED READING RPL DATA
RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\358260036185005\358260036185005_44642.rpl
FlashInfo.RestartMode : 2
Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-635\rm635__09.70.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
CMT Supported Hardwares :
> 010C192101013000
> 0103192101003000
> 030C192101033000
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 1161
Entry Point: 0x5047
Page Format : -1
MAX PAGE : 0x00004000
BootFlashMode_DCT5
BootFlashMode_DCT5
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
TIME START HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C6
BootCodeLen : 61
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
No partition info....
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0036 (54)
ERASE Blocks : 0x0001 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF00040000000BFFFF000C00000013FFFF001400000137FFFF013800000151FFFF32
Please wait ERASING.........
>> Time Elapsed 5 seconds
>> Time Elapsed 10 seconds
>> Time Elapsed 15 seconds
>> Time Elapsed 20 seconds
>> Time Elapsed 25 seconds
>> Time Elapsed 30 seconds
>> Time Elapsed 35 seconds
>> Time Elapsed 40 seconds
>> Time Elapsed 45 seconds
>> Time Elapsed 50 seconds
>> Time Elapsed 55 seconds
>> Time Elapsed 60 seconds
>> Time Elapsed 65 seconds
>> Time Elapsed 70 seconds
>> Time Elapsed 75 seconds
>> Time Elapsed 80 seconds
>> Time Elapsed 85 seconds
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:28
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDRand2TX
Is Flashing CLOCK AUTO : -1
Processing : rm635__09.70.mcusw
Total blocks to write : 1161
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:46
Making delay between files for 1500ms
Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-635\rm635__09.70.ppm_m_c
CMT Type : BB5
> 010C192101013000
> 0103192101003000
> 030C192101033000
Number of Blocks : 205
Entry Point: 0x00B6
Page Format : -1
BootFlashMode_DCT5
BootFlashMode_DCT5
VBATT OFF ...
VBATT ON
BootFlashMode_DCT5
TIME START HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C6
BootCodeLen : 61
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x000E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:16
Processing : rm635__09.70.ppm_m_c
Total blocks to write : 205
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:07
Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-635\rm635__09.70.image_m_c_black
CMT Type : BB5
> 010C192101013000
> 0103192101003000
> 030C192101033000
Number of Blocks : 408
Entry Point: 0x00C8
Page Format : -1
BootFlashMode_DCT5
BootFlashMode_DCT5
VBATT OFF ...
VBATT ON
BootFlashMode_DCT5
TIME START HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C6
BootCodeLen : 61
MessageID : C1
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0016 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
ERASE_REQUEST_BB5 : 5001121300000001DC00000215FFFF0216000003FBFFFFD3
>> Time Elapsed 90 seconds
>> Time Elapsed 95 seconds
>> Time Elapsed 100 seconds
>> Time Elapsed 105 seconds
>> Time Elapsed 110 seconds
>> Time Elapsed 115 seconds
>> Time Elapsed 120 seconds
>> Time Elapsed 125 seconds
>> Time Elapsed 130 seconds
>> Time Elapsed 135 seconds
>> Time Elapsed 140 seconds
>> Time Elapsed 145 seconds
>> Time Elapsed 150 seconds
>> Time Elapsed 155 seconds
>> Time Elapsed 160 seconds
>> Time Elapsed 165 seconds
>> Time Elapsed 170 seconds
>> Time Elapsed 175 seconds
>> Time Elapsed 180 seconds
>> Time Elapsed 185 seconds
>> Time Elapsed 190 seconds
>> Time Elapsed 195 seconds
>> Time Elapsed 200 seconds
>> Time Elapsed 205 seconds
>> Time Elapsed 210 seconds
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:03:31
Processing : rm635__09.70.image_m_c_black
Total blocks to write : 408
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:14
Total Flashing Time (Booting + Erase + Flashing) : 00:06:38 |
