Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-20-2011, 09:09   #1 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
Thanks Meter: 55
2700c Camera On Stand By....!!
Hi,
I Need This Dcc File For Nokia 2700c Rm-561......
          Dynamic Camera Configuration
DCC ID  : NIMMIIIIRRFF01035424
DCC Ver: XXXXXX
ERROR: DCC File Mismatched!
Required DCC File: NIMMIIIIRRFF01035424
Write the correct DCC to Fix the Problem
If Someone Have It Plz Share It........
Old 01-20-2011, 09:16   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,488
Hello!
All Nokia DCC files are available here: C:\AdvanceBox Turbo Flasher\Nokia\DCC
Old 01-20-2011, 09:23   #3 (permalink)
Member: 618626
Sonork: 100.1592779
Thanks Meter: 55
Originally Posted by ..::Angel::.. View Post
Hello!
My Required Dcc File Is Not There.....
Old 01-20-2011, 09:25   #4 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
Than install latest file, v9.98 - It should be in RM-xxx folder in *.dcc format. ATF supports both format to upload..
Old 01-20-2011, 10:25   #5 (permalink)
Member: 618626
Sonork: 100.1592779
Thanks Meter: 55
Hello!
I Have Installed Latest File 9.98 But My Required Dcc File Is Also Not There In Latest Files.......
Old 01-20-2011, 11:01   #6 (permalink)
Member: 643472
Sonork: 100.96901
Hello, Yes i checked there is no DCC file of this version.
Camera on standby - sometime also a HW problem - check it.
Old 01-20-2011, 11:15   #7 (permalink)
Member: 618626
Sonork: 100.1592779
Thanks Meter: 55
Ok, I Will Check Its HW Then.......
Thanks For Your Help........
Old 01-20-2011, 11:38   #8 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1659400
Thanks Meter: 858
sometimes is lcd problem try to change the lcd
Old 01-20-2011, 11:42   #9 (permalink)
Member: 643472
Sonork: 100.96901
Hello, camera on standby is a LCD problem? You sure what are you talking?
Old 01-25-2011, 18:24   #10 (permalink)
Member: 1279062
Sonork: gsm master
Thanks Meter: 12
brother i have nokia 2700c
when we start the camera its resatart
when we start blue tooth its restart
when we attach handfree its restart
when we on the radio its restart
i flash it to time but result is same
have any one solution ?????????????????????????
Old 01-26-2011, 10:20   #11 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
Is HW problem. Check in HardWare repair section.
Old 01-26-2011, 16:02   #12 (permalink)
Member: 201238
Thanks Meter: 15
its blue tooth i.c problem bro chek that re hot or replace
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.35762 seconds with 8 queries
