02-21-2014, 13:00 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | What's The Status Of Your Phone? 1st remove SD File 4GB If Phone Dead Unchecked Backup Simlock. WBR. Arsalan gsm2000. |
02-21-2014, 13:19 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, you are using an older version that does not support XG221 models flashing. You need to update your software to v11.00 and than update to v11.01 using AUTO UPDATE |
03-19-2015, 06:26 | #6 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2036550 Status: Offline Sonork: www.facebook.com/prashanj Thanks Meter: 1 | Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia USB Phonet]: Port opened OK! Failed to Create RPL from phone -> No target file chosen RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing 7CAE64B6_rm934_14.0.4.mcusw.fls (XGold2)... Checking 7CAE64B6_rm934_14.0.4.mcusw.fls... Flash file sorted Okay. 2 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to process Image File -> BootROM not detected! Failed to Process all Image files -> Failed to process Image File Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia USB Phonet]: Port opened OK! Failed to Create RPL from phone -> No target file chosen RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing 7CAE64B6_rm934_14.0.4.mcusw.fls (XGold2)... Checking 7CAE64B6_rm934_14.0.4.mcusw.fls... Flash file sorted Okay. 2 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to process Image File -> BootROM not detected! Failed to Process all Image files -> Failed to process Image File Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia USB Phonet]: Port opened OK! Failed to Create RPL from phone -> No target file chosen RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing 7CAE64B6_rm934_14.0.4.mcusw.fls (XGold2)... Checking 7CAE64B6_rm934_14.0.4.mcusw.fls... Flash file sorted Okay. 2 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to process Image File -> BootROM not detected! Failed to Process all Image files -> Failed to process Image File sir post any soluation.... |
