Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-22-2012, 15:32   #1 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
5130c2 Full erase for Downgrade (Problematic)
Hi ATF Team....
Hi must be Downgrade Another 5130 SL3 for Spanish version 7.95/96, but the Phone is back to life with 7.97 version...Tnks ATF, But....
I i Dont Touch Nothing, With The 7.97 Phone Version, Tick In Downgrade and Flash the Phone With 7.95/96/ Kill the Phone (no problem with bkp)
I Make Full erase, then Flash, Finish With DCC File Error and Unable SP data (i see a Guys sayng (need DCC FILE for XX Nokia Phone)
Well. I fight With This Nokia 5130, all is solved with PM Import Data Saved and SX4 .... I Back To Life SimLock and DCC File...
The curious thing about all this, i never Write a DCC File, And Dont Why is Unable to read SP Data when i Tick (Dowungrade)
ScreenShot
5130 downgrade.jpg - 4shared.com - photo sharing - download image
All problem is solved Bcoz before i save all data Phone
Log Process
ARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 10D00112
ID DWORD 1 : 2CBA0156
ID DWORD 2 : 48C0B3C7
ID DWORD 3 : 395BD1F3
ID DWORD 4 : 8B61A747
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C1
SearchForBootstrap_DCT5..
C:\ATF\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version 010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 03
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 8A31
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 51
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\ATF\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version 010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
PAPUB_KEYS_HASH_REQ_BB5
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
0C917F11196FDB7378C18EF7260698CA4489DCA0
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
PARTNERC : Empty
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 345130754978489
PRODUCT CODE : 059B3L5
BLUETOOTH ID : E0:A6:70F:2D:4E
PUBLIC_ID : 10D001122CBA015648C0B3C7395BD1F38B61A747
PAPUB_KEYS_HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
FINISHED READING RPL DATA
RPL saved to: C:\ATF\AdvanceBox Turbo Flasher\Nokia\backup\354317045794898\3543170457948 98_100255.rpl
Processing Image File :
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.95.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 6500000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 1178
Entry Point : 0x5057
Page Format : 128K
Maximum Page Size : 0x00004000
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C1
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
STATUS_REQUEST_BB5...
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:34
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing : rm495__07.95.mcusw
Total blocks to write : 1178
FBUS Cable RX2 PIN Diagnostics
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [0C917F11196FDB7378C18EF7260698CA4489DCA0]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:47
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.95.ppm_ua
CMT Type : BB5
Number of Blocks : 406
Entry Point : 0x00BE
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:42
Processing : rm495__07.95.ppm_ua
Total blocks to write : 406
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:15
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.95_008.image_ua_claro_cl_v3_26477
CMT Type : BB5
Number of Blocks : 720
Entry Point : 0x00D0
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:03:31
Processing : rm495__07.95_008.image_ua_claro_cl_v3_26477
Total blocks to write : 720
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:25
Total Flash Write Time (Flashing Only) : 00:01:28
Total Flashing Time (Booting + Erase + Flashing) : 00:07:16
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
KILLED.......KILLED.......KILLED.......KILLED..... ..KILLED.......KILLED.......KILLED.......
Full Erase
WARNING: SL3 Phone Detected !!!
StartErase_DCT5...
Device Index : 0x00
0 : 00000000-03FFFFFF
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
StartErase_DCT5...
Device Index : 0x00
Block Length : 01
BB ASIC Index : 00
Successfully erased..Successfully erased..Successfully erased..Successfully erased..
Reconnect your Cable Properly because RX2 PIN
is NOT getting any DATA from the Box!!!
Flashing FAILED
BB5_WRITE_FlashFile_0
Go to Settings -->
Nokia Settings -->
FBUS DDR&2TX Synchronization Timeout
Change the current value selected to a higher value
and Restart AdvanceBox.exe software to apply it
Operations Failed....
scan phone
Scanning Simlock Applet Type...
OK
SL1/SL2 Applet detected SL1/SL2 Applet detected SL1/SL2 Applet detected
Simlock Information
Unable to read SP Data..
SECURITY_TEST : PASSED
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : NIMMIIIIRRFF094B2F01
DCC Ver: XXXXXX
ERROR: DCC File Mismatched!ERROR: DCC File Mismatched!ERROR: DCC File Mismatched!ERROR: DCC File Mismatched!
Required DCC File: NIMMIIIIRRFF094B2F01
Write the correct DCC to Fix the Problem
Super Dongle RPL Stand Alone Edition
Generating Super Dongle RPL...
Sending Superdongle RPL...
OK: Super Dongle RPL Accepted
Successfully done.
Simlock Information
CONFIG KEY : 8000000000000000
PROVIDER KEY : 7223400000000000
NETWORK NAME : Telecom Personal S.A.;Argentina
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_CODE : ENCRYPTED
PHONE_MODE : TEST
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Open
SIMLOCK_TYPE : PA_SL3 PA_SL3PA_SL3PA_SL3(15-digit NCK)
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration FAIL FAIL
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)A_SL3 (15-digit NCK)
PHONE_MODE : TEST
DCC Ver: 002009
Status : OK Status : OKStatus : OKStatus : OK
SOLVED
Polaco
The Following User Says Thank You to el-polaco For This Useful Post:
Old 08-22-2012, 15:36   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
You r not a newbie , SL3 not allow 2 Downgrade . so B4 downgrade manually you should keep the backups 1st .
Br - srinibas
Old 08-22-2012, 15:53   #3 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Simlock3 Downgrade
Br - srinibas
Hello srinibas, i can show you with a old and forgeted tool, i can cross version, and is all ok, i cant Flash Diferent MCU/PPM/CNT with ATF bcoz Fail Too.-
Example: MCU 7.97 PPM. 7.95 CNT 7.97
w/o Problem....
For New User...Remember Save RPL in Tab RPL Section and Bkp Imp PM and all CRT data
anyway, the downgrade process is problematic, should be simple
I see the PM,Thnks for reply.- I never write DCC File Again. Solved with SX4 :?
Polaco
Old 08-22-2012, 23:36   #4 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
@EL-Polaco
I do not know if I understand what's happening .. sorry if i did wrong .. I'm still improving my English!
If your intention is only to revive it and change the language to Spanish, just use the version 7.97 and then use the 7.95 version without scoring the Options MCU PPM and CNT leaving just checked.
No need to mark downgrade.
I always do this here in order to revive ATF and put the language Portuguese-BR
Old 08-22-2012, 23:49   #5 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Originally Posted by Bruno Rafael View Post
@EL-Polaco
if you try to flash only PPM in 5130 with ATF (damage Phone)
If you try to flash MCU 7.97 PPM 7.95 And CNT 7.79 (damage the Phone)
I think, The Only way to downgrade w/o problem is with Full erasing, But Then Must write RPL/NPC data and SX4.
In Spanish
No te deja Crusar diferentes versiones como lo hace JAF. ATF lo deja dormido. No puedes Tildar Solo PPM que contenga espaņol (lo daņas)
No puedes tener Full flash, Untick a todo, dejar solo PPM y dar caņa (tambien lo daņas) si o si, hacer Bkp, y pasar por escribir toda la data again.-
Trata y comenta, con UFS Tambien creo me dejaria poner diferentes PPM dentro de una Flash sin fallas, pero trata con ATF y Dime.
Un saludo
Polaco
Old 08-23-2012, 00:10   #6 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
@EL-Polaco
Or Check Here....
5130 No Read SP Data With 8.10
Before Flash was Ok, Then solved, not problem.....Full Erase is recomended For DowNgrade with this RAP
Polaco
Old 08-23-2012, 03:11   #7 (permalink)
Member: 700706
Sonork: 100.1590381
I do it and not damage the phone ..... is strange what happens to your ....
Old 08-23-2012, 10:25   #8 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
In Spanish
Un saludo
Polaco
Hi,
It doesn't damage the phone...
MCU v 7.97
PPM v ANY you want
CNT v 7.97
And just simple flash.
Old 08-23-2012, 15:44   #9 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Originally Posted by ..::Angel::.. View Post
Hi,
MCU v 7.97
PPM v ANY you want
CNT v 7.97
is strange in You, how to have a Doubt in My Thread about 5130 Problematic, You Know and actiive ATF User and Like to Play with Nokiea Cell Phone......
Today I have no desire to play, you can never make it to a 5130 with just flash it.
If you search in this Forum (unable to read SP Data) there are phones looks damaged, and 70% are Nokeya 5130 (It always ends up fixing DCC Files / SP or Data)
Jfi
Polaco
Old 08-23-2012, 17:29   #10 (permalink)
Member: 643472
Sonork: 100.96901
Jfi
Polaco
Hi,
I don't know what are you talking about..
Here are the logs of what I was talking about:
MCU: 7.97
PPM: 7.95
CNT: 7.97
06:11:30 : ================================================
06:11:30 :             Basic Phone Information
06:11:30 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
06:11:30 : IMEI Plain : 353786045345912
06:11:30 : IMEI Spare : A353786045345910
06:11:30 : IMEI SV    : 33537860453459158F
06:11:30 : Phone Model: Nokia 5130c-2
06:11:31 : Category   : Classic Phone
06:11:31 : Phone Type : RM-495
06:11:31 :
06:11:31 : ================================================
06:11:31 :            Extended Phone Information
06:11:31 : Product Serial Number: HEJ542076
06:11:31 : Product Code         : 0581455
06:11:31 : Module Code          : 0204024
06:11:31 : Basic Production Code: 0578151
06:11:31 : Long Production SN   : 0
06:11:31 : PPM SW Version       : V 07.97 13-09-10 RM-495 (c) Nokia             MEN
06:11:31 : BT MCM Version       : 2222-302
06:11:32 : MCU SW Version       : V 07.97 13-09-10 RM-495 (c) Nokia
06:11:32 : HW Version           : 1003
06:11:32 : RFIC Version         : 06560601
06:11:32 : DSP Version          : ICPR72_10w01
06:11:32 : LCD Version          : SEIKO
06:11:33 : Content Pack Version : Content: mena_a1_bd_red V 07.97 13-09-10 RM-495 (c) Nokia
06:11:33 : AHNE Version         : 30
06:11:33 : RETU Version         : 16
06:11:33 : TAHVO Version        : 22
06:11:34 : Bluetooth ID         : D4:CB:AF:C6:31:29
06:11:34 : CS Type              : GSM850, GSM900, GSM1800, GSM1900
06:11:34 :
06:11:34 : ================================================
06:11:34 :               Simlock Information
06:11:35 : CONFIG KEY    :  0000000000000000
06:11:35 : PROVIDER KEY  :  2440700000000000
06:11:35 : NETWORK NAME  :  Nokia Default;Finland
06:11:35 : LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
06:11:35 : SIMLOCK TABLE :
06:11:35 :    Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 :    Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
06:11:35 : SIMLOCK STATE :  Not Locked
06:11:35 :
06:11:35 : SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
06:11:35 : SIMLOCK_TEST             : PASSED
06:11:35 : SECURITY_TEST           : PASSED
06:11:35 : SECURITY_CODE          : 12345
06:11:36 : PHONE_MODE              : TEST
06:11:37 :
06:11:37 : ================================================
06:11:37 :           Dynamic Camera Configuration
06:11:37 : DCC ID  : NIMMIIIIRRFF094B2F01
06:11:37 : DCC Ver: 002014
06:11:37 : Status   : OK
06:11:37 :
06:11:37 :
06:11:37 : ======================================================
06:11:37 : Selected VPL File:
06:11:37 : RM495_0571948_07.97_033.vpl
06:11:37 : Variant Details     : SEAP-S, Stroke, BLUE
06:11:37 : Software Version : 07.97
06:11:37 : Product Type       : RM-495
06:11:37 : Product Code      : 0571948
06:11:37 : Variant Version    : 033
06:11:37 :
06:11:37 :
06:11:37 : RM495_0581455_07.97_033.vpl
06:11:37 : Variant Details     : SEAP-MENA_A1 BD, ARABIC, RED
06:11:37 : Product Code      : 0581455
06:11:37 :
06:11:43 :
06:11:43 : ======================================================
06:11:43 : Selected VPL File:
06:11:43 : RM495_0572166_07.95_027.vpl
06:11:43 : Variant Details     : MENA_B-URDU, Urdu, RED
06:11:43 : Software Version : 07.95
06:11:43 : Product Type       : RM-495
06:11:43 : Product Code      : 0572166
06:11:43 : Variant Version    : 027
06:11:43 :
06:11:46 :
06:11:46 : ======================================================
06:11:46 : Selected VPL File:
06:11:46 : RM495_0581455_07.97_033.vpl
06:11:46 : Variant Details     : SEAP-MENA_A1 BD, ARABIC, RED
06:11:46 : Software Version : 07.97
06:11:46 : Product Type       : RM-495
06:11:46 : Product Code      : 0581455
06:11:46 : Variant Version    : 033
06:11:46 :
06:13:03 : ATF Software Version v8.95
06:13:03 : ATF Box FBUS Flash Started...
06:13:03 :
06:13:03 : Number of Image Files: 3
06:13:04 :
06:13:04 : ================================================
06:13:04 :             Basic Phone Information
06:13:04 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
06:13:04 : IMEI Plain : 353786045345912
06:13:04 : IMEI Spare : A353786045345910
06:13:04 : IMEI SV    : 33537860453459158F
06:13:04 : Phone Model: Nokia 5130c-2
06:13:05 : Category   : Classic Phone
06:13:05 : Phone Type : RM-495
06:13:05 :
06:13:05 :
06:13:09 : PM 120 Found...
06:13:10 : PM 308 Found...
06:13:11 : Simlock Data Saved to :  C:\AdvanceBox Turbo Flasher\Nokia\Backup\353786045345912\SL3_certificate_V 07.97 13-09-10 RM-495 (c) Nokia_353786045345912_Not Locked_61305.pm
06:13:11 : Changing MODE : FLASH
06:13:12 : Booting Phone via FBUS...
06:13:12 :
06:13:12 :
06:13:12 : AdvanceBox SendBootCodeEx
06:13:12 : InitialiseBootstrap_DCT5 DIR
06:13:12 : BootFlashMode_DCT5
06:13:12 :
06:13:12 : ******************************************************
06:13:12 :                  TIME STARTS HERE
06:13:12 :
06:13:12 : BootFlashModeDCT5Ex Succeeded First Time
06:13:12 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
06:13:12 : Number of Sub Blocks 7  (0x07)
06:13:12 :   1  SYSTEM_ASIC_ID 01
06:13:12 :      Block Length  : 21  (15)
06:13:12 :      BB ASIC Index : 0  (00)  CMT
06:13:12 :      ID DWORD    0 : 00000001
06:13:12 :      ID DWORD    1 : 00000226
06:13:12 :      ID DWORD    2 : 00010006
06:13:12 :      ID DWORD    3 : 030C1921
06:13:12 :      ID DWORD    4 : 01033000
06:13:12 :   2  EM_ASIC_ID 02
06:13:12 :      Block Length  : 5  (05)
06:13:12 :      ID DWORD    0 : 00000296
06:13:12 :   3  EM_ASIC_ID 02
06:13:12 :      ID DWORD    0 : 00000B22
06:13:12 :   4  PUBLIC_ID 12
06:13:12 :      ID DWORD    0 : 0F800110
06:13:12 :      ID DWORD    1 : AD205150
06:13:12 :      ID DWORD    2 : 6E63FC66
06:13:12 :      ID DWORD    3 : B6E16172
06:13:12 :      ID DWORD    4 : C16D3D8F
06:13:12 :   5  ASIC_MODE_ID 13
06:13:12 :      Block Length  : 2  (02)
06:13:12 :      Mode Id       : 00
06:13:12 :   6  ROOT_KEY_HASH 14
06:13:12 :      Block Length  : 17  (11)
06:13:12 :      Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
06:13:12 :   7  ROM_ID 15
06:13:12 :      Block Length  : 9  (09)
06:13:12 :      CRC         0 : 273F6D55
06:13:12 :      CRC         1 : DFAAF68F
06:13:12 : Checksum           00
06:13:12 :
06:13:12 : SearchForBootstrap_DCT5..
06:13:13 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
06:13:13 : Boot File - Version  010.042.00
06:13:13 : Boot File - Revision 0x0000 (0)
06:13:13 : eBB5ProtocolType == Original
06:13:13 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
06:13:13 : Secondary Loader Sent...
06:13:13 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
06:13:13 : MCU_CONFIGURATION_RESPONSE_BB5:
06:13:13 :  MessageID  : 03
06:13:13 :  SubBlocks  : 03
06:13:13 :  1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
06:13:13 :    Block Length      : 0B
06:13:13 :    BB ASIC Index     : CMT  00
06:13:13 :    Device Type       : NOR  00
06:13:13 :    Device Index      : 00
06:13:13 :    Manufacturer Code : 0089 ->
06:13:13 :    Device ID         : 8982 -> NU48F512
06:13:13 :    Extended/Fixed ID : 0000
06:13:13 :    Revision ID       : 8A31
06:13:13 :  2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
06:13:13 :    Block Length      : 13
06:13:13 :    Device Contents   : 00000000000000000000
06:13:13 :  3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
06:13:13 :    Device Type       : MMC  04
06:13:13 :    Manufacturer Code : FFFF -> Flash
06:13:13 :    Device ID         : 0000 -> BAD FLASH TYPE
06:13:13 :    Revision ID       : 0000
06:13:13 :  Checksum   : 51
06:13:13 : FLS1SendAlgoCodeEx..
06:13:13 : SendAlgoCode_DCT5..
06:13:13 : SearchForAlgorithm_DCT5..
06:13:14 : Looking for ALL Devices...
06:13:14 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
06:13:14 : Flash Descriptor
06:13:14 :    Manufacturer Code : 0089
06:13:14 :    Device ID         : 8982
06:13:14 :    Extended/Fixed ID : 0000
06:13:14 :    Revision ID       : 0000
06:13:14 :    Size              : 04000000 (64 MB)
06:13:14 :    VPP Info          : 0009
06:13:14 :    Erase10s          : 28
06:13:14 :    Block1s           : 64
06:13:14 :    BErase1s          : 02
06:13:14 :    Reserved0         : 00
06:13:14 :    Reserved1         : 00
06:13:14 :    Reserved2         : 00
06:13:14 : VPPInfo :   VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
06:13:14 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
06:13:14 : Algorithm File - Version  010.040.00
06:13:14 : Algorithm File - Revision 0x0000 (0)
06:13:14 : eBB5ProtocolType == Original
06:13:14 : SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
06:13:14 : TransmissionTypeRequest_DCT5...
06:13:14 : SuggestedType  : 01 16BIT
06:13:14 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
06:13:14 : ReturnedType : 01 16BIT
06:13:14 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
06:13:14 :
06:13:14 : Uploading ALGO File...
06:13:14 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
06:13:14 : Pabub KEY Request
06:13:14 : PhoneInfoRequest_BB5 (Asic Index 00 )
06:13:14 : PHONE_INFO_RESPONSE_BB5
06:13:14 :    PAPUB_KEYS_HASH_RESP_BB5 2A
06:13:14 :    BB Asic Index   : 00
06:13:14 : CMT PAPUBKEYS HASH:
06:13:14 : 0C917F11196FDB7378C18EF7260698CA4489DCA0
06:13:14 :
06:13:14 : START READING RPL DATA
06:13:14 : Reading : NPC (CMT)
06:13:17 : OK
06:13:18 : Reading : VARIANT (CMT)
06:13:18 : VARIANT :  Empty
06:13:18 : Reading : CCC (CMT)
06:13:21 : OK
06:13:22 : Reading : HWC (CMT)
06:13:24 : OK
06:13:24 : Reading : R&D (CMT)
06:13:27 : OK
06:13:28 : Reading : PARTNERC (CMT)
06:13:28 : PARTNERC :  Empty
06:13:28 : Reading : MDM_KEYS (CMT)
06:13:28 : MDM_KEYS :  Empty
06:13:28 : FINISHED READING RPL DATA
06:13:28 : RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353786045345912\353786045345912_61328.rpl
06:13:28 :
06:13:28 : Processing Image File :
06:13:28 : F:\Nokia\Products\rm-495\rm495__07.97.mcusw
06:13:29 : CMT Type                   :  BB5
06:13:29 : CMT Algorithm              :  BB5 ALGORITHM
06:13:29 : Secondary Sending Speed    :  3250000 Hz
06:13:29 : Algorithm Sending Speed    :  6500000 Hz
06:13:29 : Program Sending Speed      :  6500000 Hz
06:13:29 : Message Reading Speed      :  98000 Hz
06:13:29 : Number of Blocks           :  1178
06:13:29 : Entry Point                :  0x5057
06:13:29 : Page Format                :  128K
06:13:29 : Maximum Page Size          :  0x00004000
06:13:29 :
06:13:29 : Changing MODE : FLASH
06:13:29 : Booting Phone via FBUS...
06:13:29 :
06:13:30 : VBATT Powering Down <<<<
06:13:35 : VBATT Powering Up   >>>>
06:13:35 : SET VCCIO Level Done
06:13:35 : SET BSI Load Done
06:13:35 :
06:13:35 : AdvanceBox SendBootCodeEx
06:13:35 : InitialiseBootstrap_DCT5 DIR
06:13:35 : BootFlashMode_DCT5
06:13:35 :
06:13:35 : ******************************************************
06:13:35 :                  TIME STARTS HERE
06:13:35 :
06:13:35 : BootFlashModeDCT5Ex Succeeded after 3 Attempts
06:13:35 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
06:13:35 : Number of Sub Blocks 7  (0x07)
06:13:35 :   1  SYSTEM_ASIC_ID 01
06:13:35 :      Block Length  : 21  (15)
06:13:35 :      BB ASIC Index : 0  (00)  CMT
06:13:35 :      ID DWORD    0 : 00000001
06:13:35 :      ID DWORD    1 : 00000226
06:13:35 :      ID DWORD    2 : 00010006
06:13:35 :      ID DWORD    3 : 030C1921
06:13:35 :      ID DWORD    4 : 01033000
06:13:35 :   2  EM_ASIC_ID 02
06:13:35 :      Block Length  : 5  (05)
06:13:36 :      BB ASIC Index : 0  (00)  CMT
06:13:36 :      ID DWORD    0 : 00000296
06:13:36 :   3  EM_ASIC_ID 02
06:13:36 :      Block Length  : 5  (05)
06:13:36 :      ID DWORD    0 : 00000B22
06:13:36 :   4  PUBLIC_ID 12
06:13:36 :      Block Length  : 21  (15)
06:13:36 :      ID DWORD    0 : 0F800110
06:13:36 :      ID DWORD    1 : AD205150
06:13:36 :      ID DWORD    2 : 6E63FC66
06:13:36 :      ID DWORD    3 : B6E16172
06:13:36 :      ID DWORD    4 : C16D3D8F
06:13:36 :   5  ASIC_MODE_ID 13
06:13:36 :      Block Length  : 2  (02)
06:13:36 :      Mode Id       : 00
06:13:36 :   6  ROOT_KEY_HASH 14
06:13:36 :      Block Length  : 17  (11)
06:13:36 :      Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
06:13:36 :   7  ROM_ID 15
06:13:36 :      Block Length  : 9  (09)
06:13:36 :      CRC         0 : 273F6D55
06:13:36 :      CRC         1 : DFAAF68F
06:13:36 : Checksum           00
06:13:36 :
06:13:36 : SearchForBootstrap_DCT5..
06:13:36 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
06:13:36 : Boot File - Version  010.042.00
06:13:36 : Boot File - Revision 0x0000 (0)
06:13:36 : eBB5ProtocolType == Original
06:13:36 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
06:13:36 : Secondary Loader Sent...
06:13:36 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
06:13:36 : MCU_CONFIGURATION_RESPONSE_BB5:
06:13:36 :  MessageID  : 03
06:13:36 :  SubBlocks  : 03
06:13:36 :  1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
06:13:37 :    Block Length      : 0B
06:13:37 :    BB ASIC Index     : CMT  00
06:13:37 :    Device Type       : NOR  00
06:13:37 :    Device Index      : 00
06:13:37 :    Manufacturer Code : 0089 ->
06:13:37 :    Device ID         : 8982 -> NU48F512
06:13:37 :    Extended/Fixed ID : 0000
06:13:37 :    Revision ID       : 8A31
06:13:37 :  2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
06:13:37 :    Block Length      : 13
06:13:37 :    Device Contents   : 00000000000000000000
06:13:37 :  3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
06:13:37 :    Device Type       : MMC  04
06:13:37 :    Manufacturer Code : FFFF -> Flash
06:13:37 :    Device ID         : 0000 -> BAD FLASH TYPE
06:13:37 :    Revision ID       : 0000
06:13:37 :  Checksum   : 51
06:13:37 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
06:13:37 : FLS1SendAlgoCodeEx..
06:13:37 : SendAlgoCode_DCT5..
06:13:37 : SearchForAlgorithm_DCT5..
06:13:37 : Looking for ALL Devices...
06:13:37 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
06:13:37 : Flash Descriptor
06:13:37 :    Size              : 04000000 (64 MB)
06:13:37 :    VPP Info          : 0009
06:13:37 :    Erase10s          : 28
06:13:37 :    Block1s           : 64
06:13:37 :    BErase1s          : 02
06:13:37 :    Reserved0         : 00
06:13:37 :    Reserved1         : 00
06:13:37 :    Reserved2         : 00
06:13:37 : VPPInfo :   VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
06:13:37 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
06:13:37 : Algorithm File - Version  010.040.00
06:13:37 : Algorithm File - Revision 0x0000 (0)
06:13:37 : eBB5ProtocolType == Original
06:13:37 : SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
06:13:37 : TransmissionTypeRequest_DCT5...
06:13:37 : SuggestedType  : 01 16BIT
06:13:37 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
06:13:37 : ReturnedType : 01 16BIT
06:13:37 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
06:13:37 :
06:13:37 : Uploading ALGO File...
06:13:38 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
06:13:38 : Pabub KEY Request
06:13:38 : PhoneInfoRequest_BB5 (Asic Index 00 )
06:13:38 : PHONE_INFO_RESPONSE_BB5
06:13:38 :    PAPUB_KEYS_HASH_RESP_BB5 2A
06:13:38 :    BB Asic Index   : 00
06:13:38 : CMT PAPUBKEYS HASH:
06:13:38 : 0C917F11196FDB7378C18EF7260698CA4489DCA0
06:13:38 :
06:13:38 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
06:13:38 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
06:13:38 : Certificate 1
06:13:38 :   Name        : NPC
06:13:38 :   ASIC Index  : CMT  0
06:13:38 : Certificate 2
06:13:38 :   Name        : VARIANT
06:13:38 : Certificate 3
06:13:38 :   Name        : R&D
06:13:38 : Certificate 4
06:13:38 :   Name        : CCC
06:13:38 : Certificate 5
06:13:38 :   Name        : HWC
06:13:38 : STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
06:13:38 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
06:13:38 : VPP Enabled by Software
06:13:38 : Using Internal VPP
06:13:38 : StartErase_DCT5...
06:13:38 : BlockLength  :  0x36  (54)
06:13:38 : ERASE Blocks :  0x01  (1)
06:13:38 :      0   ERASE_AREA_BB5 0x12
06:13:38 :             Block Length     : 0x33 (51)
06:13:38 :             BB ASIC Index    : 0x00 CMT
06:13:38 :             Device Type      : 0x00 NOR
06:13:38 :             Device Index     : 0x00
06:13:38 :                0             : 00000000-000006BF
06:13:38 :                1             : 000006C0-0001FFFF
06:13:38 :                2             : 00040000-000BFFFF
06:13:38 :                3             : 000C0000-0013FFFF
06:13:38 :                4             : 00140000-0137FFFF
06:13:38 :                5             : 01380000-0151FFFF
06:13:38 :
06:13:38 : Erase_SendEraseBlock_BB5_NOR
06:13:38 : Task in Progress... Please Wait...
06:15:27 : STATUS_REQUEST_BB5...
06:15:27 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:15:27 :            Block Length      : 01
06:15:27 :            BB ASIC Index     : 00
06:15:27 :
06:15:27 : Successfully erased..
06:15:27 : Time Taken to Erase : 00:01:48
06:15:27 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
06:15:27 : ReturnedType : 04 DDR & 2TX
06:15:27 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
06:15:27 :
06:15:27 : Flashing Speed: 15.00 Mhz
06:15:27 : Processing  : rm495__07.97.mcusw
06:15:27 : Total blocks to write : 1178
06:15:27 : ================================================
06:15:27 :          FBUS Cable RX2 PIN Diagnostics
06:15:32 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:15:32 :            Block Length      : 01
06:15:32 :            BB ASIC Index     : 00
06:15:32 : ================================================
06:15:32 : INFO: RX2 PIN is OK
06:15:32 : >>  CMT Rootkey Hash CERT :  NOLO
06:15:34 : >>  CMT Rootkey Hash CERT :  KEYS
06:15:34 : >>  CMT Rootkey Hash CERT :  PRIMAPP
06:15:34 : >>  CMT Rootkey Hash CERT :  PASUBTOC
06:15:38 : >>  CMT Rootkey Hash CERT :  PAPUBKEYS
06:15:38 : >>  CMT Rootkey Hash CERT :  UPDAPP
06:15:39 : >>  CMT Rootkey Hash CERT :  DSP0
06:15:43 : >>  CMT Rootkey Hash CERT :  MCUSW
06:16:33 : ContinueFlash_DCT5 Complete
06:16:33 : STATUS_REQUEST_BB5...
06:16:33 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:16:33 :            Block Length      : 01
06:16:33 :            BB ASIC Index     : 00
06:16:33 : Continue Flash Complete :  : No Error - 0 (0x00)
06:16:33 : Time Taken to Flash  : 00:01:05
06:16:33 :
06:16:33 : Processing Image File :
06:16:33 : F:\Nokia\Products\rm-495\rm495__07.95.ppm_mena_b06:16:33 : CMT Type                   :  BB5
06:16:33 : CMT Algorithm              :  BB5 ALGORITHM
06:16:33 : Secondary Sending Speed    :  3250000 Hz
06:16:33 : Algorithm Sending Speed    :  6500000 Hz
06:16:33 : Program Sending Speed      :  6500000 Hz
06:16:33 : Message Reading Speed      :  98000 Hz
06:16:33 : Number of Blocks           :  404
06:16:33 : Entry Point                :  0x00BE
06:16:33 : Page Format                :  128K
06:16:33 : Maximum Page Size          :  0x00004000
06:16:33 :
06:16:33 : VPP Enabled by Software
06:16:33 : Using Internal VPP
06:16:33 : StartErase_DCT5...
06:16:33 : BlockLength  :  0x0E  (14)
06:16:33 : ERASE Blocks :  0x01  (1)
06:16:33 :      0   ERASE_AREA_BB5 0x12
06:16:33 :             Block Length     : 0x0B (11)
06:16:33 :             BB ASIC Index    : 0x00 CMT
06:16:33 :             Device Type      : 0x00 NOR
06:16:33 :             Device Index     : 0x00
06:16:33 :                0             : 01520000-01DBFFFF
06:16:33 :
06:16:34 : Erase_SendEraseBlock_BB5_NOR
06:16:34 : Task in Progress... Please Wait...
06:17:10 : STATUS_REQUEST_BB5...
06:17:10 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:17:10 :            Block Length      : 01
06:17:10 :            BB ASIC Index     : 00
06:17:10 :
06:17:10 : Successfully erased..
06:17:10 : Time Taken to Erase : 00:00:36
06:17:10 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
06:17:10 : ReturnedType : 04 DDR & 2TX
06:17:10 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
06:17:10 :
06:17:10 : Flashing Speed: 15.00 Mhz
06:17:10 : Processing  : rm495__07.95.ppm_mena_b
06:17:10 : Total blocks to write : 404
06:17:29 : ContinueFlash_DCT5 Complete
06:17:29 : STATUS_REQUEST_BB5...
06:17:29 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:17:29 :            Block Length      : 01
06:17:29 :            BB ASIC Index     : 00
06:17:29 : Continue Flash Complete :  : No Error - 0 (0x00)
06:17:29 : Time Taken to Flash  : 00:00:19
06:17:29 :
06:17:29 : Processing Image File :
06:17:29 : F:\Nokia\Products\rm-495\rm495__07.97.image_mena_a1_red
06:17:29 : CMT Type                   :  BB5
06:17:29 : CMT Algorithm              :  BB5 ALGORITHM
06:17:29 : Secondary Sending Speed    :  3250000 Hz
06:17:29 : Algorithm Sending Speed    :  6500000 Hz
06:17:29 : Program Sending Speed      :  6500000 Hz
06:17:29 : Message Reading Speed      :  98000 Hz
06:17:29 : Number of Blocks           :  656
06:17:29 : Entry Point                :  0x00D0
06:17:29 : Page Format                :  128K
06:17:29 : Maximum Page Size          :  0x00004000
06:17:29 :
06:17:29 : VPP Enabled by Software
06:17:29 : Using Internal VPP
06:17:29 : StartErase_DCT5...
06:17:29 : BlockLength  :  0x16  (22)
06:17:29 : ERASE Blocks :  0x01  (1)
06:17:29 :      0   ERASE_AREA_BB5 0x12
06:17:29 :             Block Length     : 0x13 (19)
06:17:29 :             BB ASIC Index    : 0x00 CMT
06:17:30 :             Device Type      : 0x00 NOR
06:17:30 :             Device Index     : 0x00
06:17:30 :                0             : 01DC0000-0215FFFF
06:17:30 :                1             : 02160000-03FBFFFF
06:17:30 :
06:17:30 : Erase_SendEraseBlock_BB5_NOR
06:17:30 : Task in Progress... Please Wait...
06:22:23 : STATUS_REQUEST_BB5...
06:22:23 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:22:23 :            Block Length      : 01
06:22:23 :            BB ASIC Index     : 00
06:22:23 :
06:22:23 : Successfully erased..
06:22:23 : Time Taken to Erase : 00:04:53
06:22:23 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
06:22:23 : ReturnedType : 04 DDR & 2TX
06:22:23 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
06:22:23 :
06:22:23 : Flashing Speed: 15.00 Mhz
06:22:24 : Processing  : rm495__07.97.image_mena_a1_red
06:22:24 : Total blocks to write : 656
06:23:04 : ContinueFlash_DCT5 Complete
06:23:04 : STATUS_REQUEST_BB5...
06:23:10 :     1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
06:23:10 :            Block Length      : 01
06:23:10 :            BB ASIC Index     : 00
06:23:10 : Continue Flash Complete :  : No Error - 0 (0x00)
06:23:10 : Time Taken to Flash  : 00:00:46
06:23:11 :
06:23:11 : Total Flash Write Time (Flashing Only) : 00:02:11
06:23:11 : Total Flashing Time (Booting + Erase + Flashing) : 00:09:31
06:23:11 :
06:23:22 :
06:23:22 : Waiting for Phone to Go Online...
06:23:23 : Elapsed Time: 1s
06:23:24 : Elapsed Time: 2s
06:23:25 : Elapsed Time: 3s
06:23:26 : Elapsed Time: 4s
06:23:27 : Elapsed Time: 5s
06:23:28 : Elapsed Time: 6s
06:23:29 : Elapsed Time: 7s
06:23:30 : Elapsed Time: 8s
06:23:31 : Elapsed Time: 9s
06:23:32 : Elapsed Time: 10s
06:23:32 :
06:23:32 : ================================================
06:23:32 :             Basic Phone Information
06:23:32 : MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
06:23:32 : IMEI Plain : 353786045345912
06:23:32 : IMEI Spare : A353786045345910
06:23:33 : IMEI SV    : 33537860453459158F
06:23:33 : Phone Model: Nokia 5130c-2
06:23:33 : Category   : Classic Phone
06:23:33 : Phone Type : RM-495
06:23:33 :
06:23:33 : ================================================
06:23:33 :            Extended Phone Information
06:23:33 : Product Serial Number: HEJ542076
06:23:33 : Product Code         : 0581455
06:23:33 : Module Code          : 0204024
06:23:33 : Basic Production Code: 0578151
06:23:33 : Long Production SN   : 0
06:23:33 : PPM SW Version       : V 07.95 03-02-10 RM-495 (c) Nokia             MEN06:23:33 : BT MCM Version       : 2222-302
06:23:34 : MCU SW Version       : V 07.97 13-09-10 RM-495 (c) Nokia
06:23:34 : HW Version           : 1003
06:23:34 : RFIC Version         : 06560601
06:23:34 : DSP Version          : ICPR72_10w01
06:23:34 : LCD Version          : SEIKO
06:23:35 : Content Pack Version : Content: mena_a1_bd_red V 07.97 13-09-10 RM-495 (c) Nokia
06:23:35 : AHNE Version         : 30
06:23:35 : RETU Version         : 16
06:23:36 : TAHVO Version        : 22
06:23:36 : Bluetooth ID         : D4:CB:AF:C6:31:29
06:23:37 : CS Type              : GSM850, GSM900, GSM1800, GSM1900
06:23:37 :
06:23:37 : ================================================
06:23:37 :               Simlock Information
06:23:38 : CONFIG KEY    :  0000000000000000
06:23:38 : PROVIDER KEY  :  2440700000000000
06:23:38 : NETWORK NAME  :  Nokia Default;Finland
06:23:38 : LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
06:23:38 : SIMLOCK TABLE :
06:23:38 :    Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 :    Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
06:23:38 : SIMLOCK STATE :  Not Locked
06:23:38 :
06:23:38 : SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
06:23:38 : SIMLOCK_TEST             : PASSED
06:23:38 : SECURITY_TEST           : PASSED
06:23:39 : SECURITY_CODE          : 12345
06:23:39 : PHONE_MODE              : TEST
06:23:40 :
06:23:40 : ================================================
06:23:40 :           Dynamic Camera Configuration
06:23:40 : DCC ID  : NIMMIIIIRRFF094B2F01
06:23:40 : DCC Ver: 002014
06:23:40 : Status   : OK
06:23:40 :
06:23:41 :
06:23:41 : FACTORY SET TO : Full Factory Set
06:23:41 : OK
06:23:41 : FACTORY SET TO : User Data
06:23:41 : OK
06:23:41 : FACTORY SET TO : Leave Factory
06:23:42 : OK
06:23:42 : FACTORY SET TO : Service Center
06:23:42 : OK
06:23:42 : FACTORY SET TO : Software Upgrade
06:23:42 : OK
06:23:42 : FACTORY SET TO : Production Tune
06:23:42 : OK
06:23:42 :
06:23:43 :
06:23:43 : RESET LIFE TIMER TO : 0000:00
Old 08-23-2012, 23:47   #11 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
YEs, No Need Erase For Downgrade PPM Version
I Make full Upgrade and then Flash Only one File PPM select, and Ok..
Surprise For me.-
http://www.4shared.com/photo/z9dVO6a...l?refurl=d1url
Product Serial Number: IBX011802
Product Code : 0578115
Basic Production Code: 0567772
PPM SW Version : V 07.95 03-02-10 RM-495 (c) Nokia UA
MCU SW Version : V 07.95 03-02-10 RM-495 (c) Nokia
HW Version : 2000
RFIC Version : 06540601
LCD Version : SEIKO
Content Pack Version : Content: ctv HN V 07.95 03-02-10 RM-495 (c) Nokia
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Bluetooth ID : E0:A6:70F:2D:4E
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Open
Upgrade Full //////////////////////////// For 7.97 version w/o spanish
ATF Software Version v9.02
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
CMT Type : BB5
Page Format : 128K
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C1
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
Using Internal VPP
StartErase_DCT5...
Device Index : 0x00
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:01:43
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5
Block Length : 0F
BB ASIC Index : 00
Error Type : 05
Error Spec : 08
Of*****ng Address : 00930400
Expected Content : 0000D58A
Detected Content : 0000D5C2
Reconnect your Cable Properly because RX2 PIN///////////////////////////
is NOT getting any DATA from the Box!!! //////////////////////////
Flashing FAILED///////////////////////////////////////////////////
BB5_WRITE_FlashFile_0/////////////////////////////////
Go to Settings --> ///////////////////////
Nokia Settings -->
WDF i try again, without touch nothing tell me what happen here ?? I sure is a Unknown Stupid Problem....common error..
Here Full Log....I not change cable data! and process is Ok (upgrade 2 7.97
CMT Type : BB5
Page Format : 128K
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum C1
MessageID : 03
SubBlocks : 03
Block Length : 0B
Device Index : 00
Revision ID : 8A31
Block Length : 13
Device Index : 00
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 51
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 8982
Revision ID : 0000
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
Using Internal VPP
StartErase_DCT5...
Device Index : 0x00
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:01:45
Block Length : 01
BB ASIC Index : 00
INFO: RX2 PIN is OK
Block Length : 01
BB ASIC Index : 00
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_s
CMT Type : BB5
Number of Blocks : 513
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
Device Index : 0x00
Block Length : 01
BB ASIC Index : 00
Processing : rm495__07.97.ppm_s
Total blocks to write : 513
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:18
C:\Archivos de programa\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_s_blu
CMT Type : BB5
Number of Blocks : 832
Page Format : 128K
Using Internal VPP
StartErase_DCT5...
Device Index : 0x00
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:03:35
Processing : rm495__07.97.image_s_blu
Total blocks to write : 832
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:28
Total Flash Write Time (Flashing Only) : 00:01:35
Total Flashing Time (Booting + Erase + Flashing) : 00:07:31
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
IMEI Plain : 354317045794898
IMEI Spare : A354317045794890
IMEI SV : 33543170457948958F
Phone Type : RM-495
PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia S
HW Version : 2000
LCD Version : SEIKO
Content Pack Version : Content: s_blu V 07.97 13-09-10 RM-495 (c) Nokia
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Open
PHONE_MODE : TEST
DCC Ver: 002009
Status : OK
OK
OK
OK
OK
OK
OK
OK
Simple Touch Flash Process (select only PPM Files) Not full flash!
HW Version : 2000
LCD Version : SEIKO
AHNE Version : 30
RETU Version : 16
TAHVO Version : 22
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Open
PHONE_MODE : TEST
DCC Ver: 002009
Status : OK
OK
OK
OK
OK
OK
all Is Work Ok.....
: 0000:00 [/CODE]
I not need erase Nothing to Downgrade PPM Ver.........
I Wrong.....Sory...but i not crazy, i cant do that Before....Maybe Bad Step...The time and Yours lerning me everday
Thnks
Polaco
Old 08-26-2012, 14:27   #12 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
[/CODE]
This Phone Autorestart incoming call / calling.. no method recomend :P
br
polaco
Old 08-31-2012, 01:56   #13 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Testing USB Dead Mode
Just For Play in One Step...Phone is ok, not restart when call back/send
rm495__07.97.mcusw
CMT Type : BB5
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Entry Point: 0x5057
Page Format : -1
MAX PAGE : 0x00004000
rm495__07.97.ppm_s
CMT Type : BB5
Entry Point: 0x00BE
Page Format : -1
CMT Type : BB5
Entry Point: 0x00D0
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
BootFlashMode_DCT5
READING BOOTROM
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
ADL_SERVER: PROCESSING rm495__07.97.mcusw
ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
ADL_SERVER: CMT DATA BLOCKS FOUND
ADL_SERVER: CONSOLIDATING CMT BLOCKS
ADL_SERVER: PASUBTOC BLOCK FOUND
BB5 ADL Loader Start Up... (Please Wait...)
Found Nokia BB5 ADL Loader USB Generic...
Erase Block Found
>> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00140000 - 0x0137FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x01380000 - 0x0151FFFF, Type: NOR , Subsystem: CMT
Erase Complete : No Error - 0 (0x00)
Data Block Found : 1178 Blocks
Continue Flash Complete : No Error - 0 (0x00)
Erase Block Found
>> Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 513 Blocks
Erase Block Found
>> Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 832 Blocks
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:08:51
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI: 354317045794898
SIMLOCK TABLE :
Block [1] 1:Open
SUPER_DONGLE_TEST : PASSED
SL3 Phone detected
OK
OK
OK
OK
OK
OK
OK
best regard
polaco
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-25-1999 15:50
Page generated in 0.91554 seconds with 11 queries
