07-20-2015, 08:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | 520 flashing problem Loading Flash Files Please Wait... [DEAD BOOT REPAIR SUPPORTED] ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... IMEI: 35-------------- Version: 1.1.1.3 Product Code: 059S223 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x00300000 Check your Flash File and Phone Connection ERROR: Flashing Failed! |
07-21-2015, 10:39 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @gsaara Your flash file is corrupted. Download file again and click on CHECK Button first in ATF software, so that it will verify your downloaded file for if they are corrupted or not. BR |
