Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-23-2011, 14:06   #1 (permalink)
rifaaq's Avatar
Member: 567810
Sonork: Xiaomi direct
Thanks Meter: 30
5230-1с RM-593 can not repayr Phone Start up Failed
This is RPL writing
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 01051103
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  ROM_ID 15
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 17000106
     ID DWORD    1 : A7970052
     ID DWORD    2 : CA645A8F
     ID DWORD    3 : FE38545E
     ID DWORD    4 : 6F8E1F49
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 4B9B7510
     CRC         1 : 3E691FF8
Checksum           40
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version  010.050.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0400 -> Flash
   Device ID         : 0000 -> Type not in database
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0040 -> KAT00F00RA
   Revision ID       : 0121
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 24
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   Size              : 10000000 (256 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg
Algorithm File - Version  010.050.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
053CA748F933E7C497F9DD5EF7A999E9B90BA153
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x10  (16)
ERASE Blocks :  0x01  (1)
     0   ERASE_AREA_BB5 0x13
            Block Length     : 0x0D (13)
            BB ASIC Index    : 0x00 CMT
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000000
          Additional Bad    :  00000000
          Correctable ECC   :  00000000
Successfully erased..
Found : CMT NPC Certificate 0x0200 Bytes
Write Ok
StartErase_DCT5...
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Found : CMT CCC Certificate 0x0200 Bytes
Write Ok
StartErase_DCT5...
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Found : CMT HWC Certificate 0x0200 Bytes
Write Ok
RPL Writing was Successful!
FlashInfo.RestartMode : 2
And this is Standalone SX4
MCU: V ICPR72_09w44.14 22-02-10 RM-593 (c) Nokia
IMEI: 359341034366802
Model : Nokia 5230-1c
Product Serial Number: CQH038816
Product Code         : 0592823
Basic Production Code: 0585852
Default SN Type      : 0
PPM Version          : V ICPR72_09w44.14 22-02-10 RM-593 (c) Nokia
HW Version           : 0530
RFIC Version         : 17141716
DSP Version          : simon_ICPR72_09wk43
APE BT Version       : HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
Content Pack Version : 11.2.080_001_U343
AHNE Version         : 11
APE SW Core Version  : V 11.2.080
APE Variant Version  : V 11.2.080V 11.2.080 11.2.080.343.01
Retu Version         : 16
Tahvo Version        : 22
APE HW Version       : 256
APE ADSP SW Version  : 256
   ********   Reading SimLock   ********
CONFIG KEY:  8000000000000000
PROVIDER KEY:  3102000000000000
Provider  :  T-Mobile;U.S.A.
Counters  :  0/3  ,  0/10
   Block [1]  1:Close
   Block [2]  1:Close
   Block [3]  1:Close
   Block [4]  1:Close
   Block [5]  1:Close
   Block [6]  1:Close
   Block [7]  1:Close
   Block [8]  1:Close
   Block [9]  1:Close
   Block [10]  1:Close
   Block [11]  1:Close
   Block [12]  1:Close
   Block [13]  1:Close
   Block [14]  1:Close
SP Lock Status :  Locked
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST     : FAILED
      >  Try SX4 "PM AUTH"
      >  Then Write PM 1 and 309
PHONE_MODE              : LOCAL MODE
      SX4 Custom Keys Stand Alone Edition
*** WARNING: Current Super Dongle Keys are Invalid! ***
Attempting to write New Super Dongle Keys...
Default SN Type      : 0
Unable to read SP Data..
SIMLOCK_TYPE             : PA_SL1/PA_SL2
SIMLOCK_TEST      : FAILED
      >  Try SX4 "PM AUTH"
PHONE_MODE              : UNKNOWN
       Super Dongle RPL Stand Alone Edition
Generating Super Dongle RPL...
(This may take upto 30 Seconds on New RAPIDO HASH)
Sending Superdongle RPL...
OK: Super Dongle RPL accepted
Successfully done.
>>> : SX4 Auth Successfull
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-593 1and309.pm
Start Uploading PM...
Field : 1 Sub : 0 Byte(s): 114  - Ok
Field : 1 Sub : 2 Byte(s): 98  - Ok
Field : 1 Sub : 4 Byte(s): 110  - Ok
Field : 1 Sub : 6 Byte(s): 98  - Ok
Field : 1 Sub : 8 Byte(s): 110  - Ok
Field : 1 Sub : 13 Byte(s): 98  - Ok
Field : 1 Sub : 16 Byte(s): 98  - Ok
Field : 1 Sub : 18 Byte(s): 98  - Ok
Field : 1 Sub : 20 Byte(s): 98  - Ok
Field : 1 Sub : 22 Byte(s): 16  - Ok
Field : 1 Sub : 23 Byte(s): 4  - Ok
Field : 1 Sub : 24 Byte(s): 84  - Ok
Field : 1 Sub : 25 Byte(s): 4  - Ok
Field : 1 Sub : 26 Byte(s): 110  - Ok
Field : 1 Sub : 28 Byte(s): 98  - Ok
Field : 1 Sub : 29 Byte(s): 10  - Ok
Field : 1 Sub : 31 Byte(s): 98  - Ok
Field : 1 Sub : 33 Byte(s): 36  - Ok
Field : 1 Sub : 34 Byte(s): 80  - Ok
Field : 1 Sub : 40 Byte(s): 16  - Ok
Field : 1 Sub : 41 Byte(s): 182  - Ok
Field : 1 Sub : 42 Byte(s): 4  - Ok
Field : 1 Sub : 43 Byte(s): 36  - Ok
Field : 1 Sub : 44 Byte(s): 182  - Ok
Field : 309 Sub : 0 Byte(s): 4  - Ok
Field : 309 Sub : 1 Byte(s): 2  - Ok
Field : 309 Sub : 2 Byte(s): 12  - Ok
Field : 309 Sub : 4 Byte(s): 12  - Ok
Field : 309 Sub : 5 Byte(s): 12  - Ok
Field : 309 Sub : 7 Byte(s): 12  - Ok
Field : 309 Sub : 8 Byte(s): 12  - Ok
Field : 309 Sub : 17 Byte(s): 12  - Ok
PM  Upload Done!...
In first log i cant see CMLA ,WMDRM,SD, Simlock writing. This is normal?
Old 03-23-2011, 17:21   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@rifaaq
Your RPL file may not contains CMLA Key and WM_DRM ! Anway, how to fix st_securtiy_failed:
1st way:
1. Repair Super Dongle data
2. With SX4 auth. PM 1, 309
2nd way:
1. Write CCC and HWC RPL data from other same working phone - RPL must without NPC data
3rd way:
1. Backup full PM 0-512
2. From ATF SX4 folder, write ErasePM 1, 309 with SX4 auth.
3. Write PM 1 and 309 with SX4 auth.
Hope that helps.
Old 03-24-2011, 06:53   #3 (permalink)
rifaaq's Avatar
Member: 567810
Thanks Meter: 30
Originally Posted by ..::Angel::.. View Post
@rifaaq
1st way:
2nd way:
3rd way:
Hope that helps.
No, rpl is factory and all data exist it in.
Yes, SX4 standalone with 1 and 309 already wrired (see my 2 log in 1 post)
Ill try 3rd way. Thanks
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.16548 seconds with 9 queries
