Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-20-2012, 16:24   #1 (permalink)
vignesharmy55's Avatar
Member: 1531954
Sonork: 100.1619337
5230 (rm-588) after flash vibrator only
i have one mobile with phone start up filed problem..... i try flash latest ver but after flash vibrator only any one know how to solve this
Old 06-20-2012, 16:45   #2 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1587812
bro post here the logs......
Old 06-21-2012, 02:13   #3 (permalink)
fortunemobile's Avatar
Member: 1728389
Sonork: 100.1617627
download ENO file of this phone and flash it.
Old 06-21-2012, 10:06   #4 (permalink)
Member: 1531954
Sonork: 100.1619337
PHP Code:
ATF Software Version v8.80
ATF Box FBUS Flash Started
Number of Image Files3
Processing Image File
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.9.002_prd.core.C00
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
Secondary Sending Speed
:  650000 Hz
Algorithm Sending Speed
:  13000000 Hz
Program Sending Speed
:  13000000 Hz
Message Reading Speed
:  98000 Hz
Number of Blocks
:  461
Entry Point
:  0x289CCA
Page Format
:  128K
Maximum Page Size
:  0x00040000
Changing MODE
FLASH
Booting Phone via FBUS
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5
(0xC0) - 0  (0x00bytes returned
Number of Sub Blocks 7
(0x07)
1  SYSTEM_ASIC_ID 01
     Block Length
21  (15)
BB ASIC Index 0  (00)  CMT
     ID DWORD    0
00000001
     ID DWORD    1
00000226
     ID DWORD    2
00010006
     ID DWORD    3
400C1921
     ID DWORD    4
01051103
  2  EM_ASIC_ID 02
     Block Length
5  (05)
     ID DWORD    0
00000296
  3  EM_ASIC_ID 02
     Block Length
5  (05)
     ID DWORD    0
00000B22
  4  PUBLIC_ID 12
     Block Length
21  (15)
     ID DWORD    0
0580000E
     ID DWORD    1
B1330052
     ID DWORD    2
64E6380A
     ID DWORD    3
98165705
     ID DWORD    4
2F407965
  5  ASIC_MODE_ID 13
     Block Length
2  (02)
     Mode Id
00
  6  ROOT_KEY_HASH 14
     Block Length
17  (11)
     Hash
:  47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
  7  ROM_ID 15
     Block Length
9  (09)
     CRC         0
4B9B7510
     CRC         1
3E691FF8
Checksum           A6
SearchForBootstrap_DCT5
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File
Version  011.034.00
Boot File
Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  No Error (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using
default mode 04 DDRand2TX
59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID  06
 SubBlocks
06
 1 Sub Block ID
10  STORAGE_DEVICE_ID_BB5
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
RAM  05
   Device Index
00
   Manufacturer Code
0000 -> Flash
   Device ID
0000 -> not detected
   Extended
/Fixed ID 0000
   Revision ID
0000
 2 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
MMC  04
   Device Index
00
   Manufacturer Code
FFFF -> Flash
   Device ID
0000 -> BAD FLASH TYPE
   Extended
/Fixed ID 0000
   Revision ID
0000
 3 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
NOR  00
   Device Index
00
   Manufacturer Code
0400 -> Flash
   Device ID
0000 -> Type not in database
   Extended
/Fixed ID 0000
   Revision ID
0000
 4 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
NOR  00
   Device Index
01
   Manufacturer Code
0000 -> SPANSION
   Device ID
0001 -> not used
   Extended
/Fixed ID 0000
   Revision ID
0000
 5 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
MuxOneNAND  03
   Device Index
00
   Manufacturer Code
00EC ->
Device ID         0040 -> KAT00F00RA
   Extended
/Fixed ID 0000
   Revision ID
0231
 6 Sub Block ID
35  NAND_DRIVER_VERSION_BB5
   Block Length
09
   BB ASIC Index
CMT  00
   Data
XSR 1.5
 Checksum
14
No Error (0x00)
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03ManID :00EC DevID :0040 ExtID :0000 RevID :0231
C
:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg
Algorithm File
Version  011.034.00
Algorithm File
Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 No Error (0x00)
59 01 3E 00 C0
SendAlgoCodeFile_DCT5
No Error (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5
5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5
(Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index
00
CMT PAPUBKEYS HASH
7DC72D3FDC552426A4479BC820097D304CFB6C15
Read Type
FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  Name
NPC
  ASIC Index
CMT  0
Certificate 2
  Name
CCC
  ASIC Index
CMT  0
Certificate 3
  Name
HWC
  ASIC Index
CMT  0
Certificate 4
  Name
R&D
  ASIC Index
CMT  0
61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
No Error (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks
:   1
     1   PARTITION_INFO_BB5
            BB ASIC Index
0x00 CMT
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
            Partition Version
00010000
            Spare
FFFFFFFF
            Num Partitions
00000004
            Partition    1
              ID
00000003  COPIEDOS
              Attribute
00000002  RO
              Start Address
00080000
              Size
026C0000
            Partition    2
              ID
00000004  DEMANDONOS
              Attribute
00000002  RO
              Start Address
02740000
              Size
07720000
            Partition    3
              ID
00000008  FILESYSTEM
              Attribute
00000001  RW
              Start Address
09E60000
              Size
05620000
            Partition    4
              ID
0000000A  PMM
              Attribute
00000001  RW
              Start Address
0F640000
              Size
003C0000
PARTITION_INFO_REQUEST_BB5
64012F4F00030000010000FFFFFFFF00000004000000030000000200080000026C000000000004000000020274000007720000000000080000000109E60000056200000000000A000000010F640000003C0000F3
No Error (0x00)
ProcessPartitionInfo_DCT5 No Error (0x00)
StartErase_DCT5...
BlockLength  :  0x5F  (95)
ERASE Blocks :  0x02  (2)
0   ERASE_AREA_BB5 0x12
            Block Length
0x2B (43)
BB ASIC Index    0x00 CMT
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
00040000-00082FFF
               1
00083400-003FFFFF
               2
00400000-007FFFFF
               3
00800000-00D5FFFF
               4
00D60000-09E5FFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length
0x2F (47)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
            Format Info ID
0x02000000
            Format Info
000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress
... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      15 STATUS_NAND_OK_BB5
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Erase_SendFormatPartition_BB5_NAND
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Time Taken to Erase 00:00:01
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.9.002_prd.core.C00
Total blocks to write
461
>>  CMT Rootkey Hash CERT ADA
>>  CMT Rootkey Hash CERT KEYS
>>  CMT Rootkey Hash CERT PRIMAPP
>>  CMT Rootkey Hash CERT RAP3NAND
>>  CMT Rootkey Hash CERT PASUBTOC
>>  CMT Rootkey Hash CERT PAPUBKEYS
>>  CMT Rootkey Hash CERT SOS*UPDAPP
>>  CMT Rootkey Hash CERT SOS*ENO
>>  CMT Rootkey Hash CERT SOS*DSP0
>>  CMT Rootkey Hash CERT SOS*ISASW
>>  CMT Rootkey Hash CERT SOS+CORE
>>  CMT Rootkey Hash CERT SOS+ROFS1
ContinueFlash_DCT5 Complete
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Continue Flash Complete :  : No Error (0x00)
Time Taken to Flash  00:01:16
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.9.002_C01_prd.rofs3.fpsx
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  28
Entry Point
:  0x00FF
Page Format
:  128K
Maximum Page Size
:  0x00040000
StartErase_DCT5
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length
0x0B (11)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
09160000-09E5FFFF
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Time Taken to Erase 00:00:00
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.9.002_C01_prd.rofs3.fpsx
28
>>  CMT Rootkey Hash CERT SOS+ROFS3
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Time Taken to Flash  00:00:04
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.9.002_prd.rofs2.V25
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  110
Entry Point
:  0x00FF
Page Format
:  128K
Maximum Page Size
:  0x00040000
StartErase_DCT5
            Block Length
0x0B (11)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
06FE0000-0915FFFF
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.9.002_prd.rofs2.V25
110
>>  CMT Rootkey Hash CERT SOS+ROFS2
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Time Taken to Flash  00:00:19
Total Flash Write Time
(Flashing Only) : 00:01:40
Total Flashing Time
(Booting Erase Flashing) : 00:01:47
Waiting
for Phone to Go Online...
Elapsed Time1s
Elapsed Time
2s
Elapsed Time
3s
Elapsed Time
4s
Elapsed Time
5s
Elapsed Time
6s
Elapsed Time
7s
Elapsed Time
8s
Elapsed Time
9s
Elapsed Time
10s
Basic Phone Information
Old 06-21-2012, 10:07   #5 (permalink)
Member: 1531954
Sonork: 100.1619337
where can i get it? if u have plz share with me.........
Old 06-21-2012, 11:19   #6 (permalink)
tontonflach's Avatar
Member: 168513
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing  : RM-588_51.9.002_prd.core.C00
Total blocks to write : 461
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*ENO
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ENO is included in flash file with ATF no need ENO...
*you solve your probleme with downgrade your phone.
*flash your phone with same product code.
Old 06-21-2012, 14:54   #7 (permalink)
Member: 1531954
Sonork: 100.1619337
I tryed to Downgrade with Same product Code after flash Same Problam
Here is the flashing log:
PHP Code:
Number of Image Files4
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.core.C00
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  461
Entry Point
:  0x289CCA
Page Format
:  128K
Maximum Page Size
:  0x00040000
Changing MODE
FLASH
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
(0x07)
1  SYSTEM_ASIC_ID 01
     Block Length
21  (15)
     ID DWORD    0
00000001
     ID DWORD    1
00000226
     ID DWORD    2
00010006
     ID DWORD    3
400C1921
     ID DWORD    4
01051103
  2  EM_ASIC_ID 02
     Block Length
5  (05)
     ID DWORD    0
00000296
  3  EM_ASIC_ID 02
     Block Length
5  (05)
     ID DWORD    0
00000B22
  4  PUBLIC_ID 12
     Block Length
21  (15)
     ID DWORD    0
0580000E
     ID DWORD    1
B1330052
     ID DWORD    2
64E6380A
     ID DWORD    3
98165705
     ID DWORD    4
2F407965
  5  ASIC_MODE_ID 13
     Block Length
2  (02)
     Mode Id
00
  6  ROOT_KEY_HASH 14
     Block Length
17  (11)
     Hash
  7  ROM_ID 15
     Block Length
9  (09)
     CRC         0
4B9B7510
     CRC         1
3E691FF8
Checksum           A6
Boot File
Version  011.034.00
Boot File
Revision 0x0002 (2)
59 01 3E 00 C0
MessageID  06
 SubBlocks
06
 1 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
RAM  05
   Device Index
00
   Manufacturer Code
0000 -> Flash
   Device ID
   Extended
/Fixed ID 0000
   Revision ID
0000
 2 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
MMC  04
   Device Index
00
   Manufacturer Code
FFFF -> Flash
   Device ID
   Extended
/Fixed ID 0000
   Revision ID
0000
 3 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
NOR  00
   Device Index
00
   Manufacturer Code
0400 -> Flash
   Device ID
   Extended
/Fixed ID 0000
   Revision ID
0000
 4 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
NOR  00
   Device Index
01
   Manufacturer Code
0000 -> SPANSION
   Device ID
0001 -> not used
   Extended
/Fixed ID 0000
   Revision ID
0000
 5 Sub Block ID
   Block Length
0B
   BB ASIC Index
CMT  00
   Device Type
MuxOneNAND  03
   Device Index
00
   Manufacturer Code
00EC ->
   Extended
/Fixed ID 0000
   Revision ID
0231
 6 Sub Block ID
   Block Length
09
   BB ASIC Index
CMT  00
   Data
XSR 1.6
 Checksum
13
No Error (0x00)
SendAlgoCode_DCT5..
Flash Descriptor
   Manufacturer Code
00EC
   Device ID
0040
   Extended
/Fixed ID 0000
   Revision ID
0000
   Size
10000000 (256 MB)
VPP Info          0000
   Erase10s
1E
   Block1s
32
   BErase1s
02
   Reserved0
00
   Reserved1
00
   Reserved2
00
C
Algorithm File
Version  011.034.00
Algorithm File
Revision 0x0002 (2)
Algo Loader Sent...
59 01 3E 00 C0
No Error (0x00)
FUR control Ok...
Using Internal VPP
Pabub KEY Request
(Asic Index 00 )
   BB Asic Index
00
CMT PAPUBKEYS HASH
Read Type
Certificate 1
  Name
NPC
  ASIC Index
CMT  0
Certificate 2
  Name
CCC
  ASIC Index
CMT  0
Certificate 3
  Name
HWC
  ASIC Index
CMT  0
Certificate 4
  Name
R&D
  ASIC Index
CMT  0
No Error (0x00)
Partition Info
    Partition Blocks
:   1
            BB ASIC Index
0x00 CMT
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
            Partition Version
00010000
            Spare
FFFFFFFF
            Num Partitions
00000004
            Partition    1
              ID
00000003  COPIEDOS
              Attribute
00000002  RO
              Start Address
00080000
              Size
026C0000
            Partition    2
              ID
00000004  DEMANDONOS
              Attribute
00000002  RO
              Start Address
02740000
              Size
07720000
            Partition    3
              ID
00000008  FILESYSTEM
              Attribute
00000001  RW
              Start Address
09E60000
              Size
05620000
            Partition    4
              ID
0000000A  PMM
              Attribute
00000001  RW
              Start Address
0F640000
              Size
003C0000
No Error (0x00)
StartErase_DCT5...
            Block Length
0x2B (43)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
00040000-00082FFF
               1
00083400-003FFFFF
               2
00400000-007FFFFF
               3
00800000-00D5FFFF
               4
00D60000-09E5FFFF
            Block Length
0x2F (47)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
            Format Info ID
0x02000000
            Format Info
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.0.002_prd.core.C00
461
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Time Taken to Flash  00:01:14
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_C01_prd.rofs3.fpsx
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  28
Entry Point
:  0x00FF
Page Format
:  128K
Maximum Page Size
:  0x00040000
StartErase_DCT5
            Block Length
0x0B (11)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
09160000-09E5FFFF
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.0.002_C01_prd.rofs3.fpsx
28
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.rofs2.V21
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  52
Entry Point
:  0x00FF
Page Format
:  128K
Maximum Page Size
:  0x00040000
StartErase_DCT5
            Block Length
0x0B (11)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
06FE0000-0915FFFF
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.0.002_prd.rofs2.V21
52
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Time Taken to Flash  00:00:08
C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_000_001_U001.uda.fpsx
CMT Type
:  BB5
CMT Algorithm
:  XSR 1.6
:  650000 Hz
:  13000000 Hz
:  13000000 Hz
:  98000 Hz
Number of Blocks
:  75
Entry Point
:  0x00FF
Page Format
:  128K
Maximum Page Size
:  0x00040000
StartErase_DCT5
            Block Length
0x0B (11)
            Device Type
0x03 MuxOneNAND
            Device Index
0x00
               0
09E60000-0F47FFFF
Task in Progress
... Please Wait...
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Successfully erased
Flashing Speed
5.00 Mhz (AUTO)
Processing  RM-588_51.0.002_000_001_U001.uda.fpsx
75
          Block Length
:  0F
          BB ASIC Index
:  00
          Device Type
:  03
          Device Type
:  00
          Num Bad Blocks
:  00000004
          Additional Bad
:  00000004
          Correctable ECC
:  00000000
Time Taken to Flash  00:00:14
(Flashing Only) : 00:01:43
Total Flashing Time
(Booting Erase Flashing) : 00:01:48
Waiting
Elapsed Time1s
Elapsed Time
2s
Elapsed Time
3s
Elapsed Time
4s
Elapsed Time
5s
Elapsed Time
6s
Elapsed Time
7s
Elapsed Time
8s
Elapsed Time
9s
Elapsed Time
10s
Old 06-21-2012, 15:02   #8 (permalink)
Member: 1774953
remove the battery for 5 minutes trying to hold crushed button for 5 seconds the red and green room and stanbay together
Old 06-21-2012, 15:07   #9 (permalink)
Member: 1372118
if u have backup try erase phone
try flash lower version / high version (dont restore backup now) just power on
if live software damage u can restore backup
if not it hardware failure
peace
Old 06-22-2012, 15:58   #10 (permalink)
Member: 1663119
Sonork: iffi3
use latest version ....i had same problem now its fine
Old 06-23-2012, 13:45   #11 (permalink)
Member: 1531954
Sonork: 100.1619337
where can i get it? bro
Old 06-24-2012, 11:25   #12 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Get latest firmwares from Nokia Data Package or NaviFirm.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 06-24-2012, 16:47   #13 (permalink)
Member: 219803
Sonork: 1582317
Backup your phone ( RPL, PM ) and try to flash it with last version. If done with same problem: Full Erase with Full Flash and restoring or writing backup will back. If else it's a hardware ( I think it's a hardware because the flashing time is too less or too short for 5230 even erasing or flashing) Good Luck.
Old 06-25-2012, 12:48   #14 (permalink)
Member: 1531954
Sonork: 100.1619337
thx u for ur replay i instal navifirm but it's ask .net framework 4.......... i download .net but it's 64bit my system 32bit if u have plz share with me thx U...
Old 06-25-2012, 12:54   #15 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Install Nokia data pack manager - latest setup link
Br - srinibas
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 1.25854 seconds with 11 queries
