Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-15-2011, 05:24   #1 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
5233 only vibrate.
I get this nokia 5233 vibrate only when you pressed the power button, it flashed with the highest version of navifirm and remained the same.
some way to revive it?
full erase can be done with this model?
Please help to raise the dead.
Old 04-15-2011, 05:49   #2 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
@3zr3vnoc
Do not full erase...
Show me 2 logs:
1. BACKUP RPL BUTTON LOGS
2. FULL FLASHING LOGS
Then send me your RPL file
B.R>
Old 04-15-2011, 05:52   #3 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
Ok!
Old 04-15-2011, 05:52   #4 (permalink)
arun4265's Avatar
Member: 239850
Thanks Meter: 34
flash with usb...............................
Old 04-15-2011, 15:32   #5 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
Here the RPL before flashing. - 352000046904813_212821.rpl - 4shared.com - online file sharing and storage - download
Old 04-15-2011, 15:52   #6 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 567
Flashing Error
Originally Posted by 3zr3vnoc View Post
Show Log..Cut and paste Here...
Scan phone and Check Phone
We need Know about Conection and Info about Error!
Thats all for help you..
B/R
The_polack
Old 04-15-2011, 16:37   #7 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
Same flash original Claro Chile -
Old 04-15-2011, 16:41   #8 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,117
@3zr3vnoc
Post ATF Logs because this is ATF Section.
Check Post #2, I already told you what to do...
Old 04-15-2011, 16:52   #9 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
ATF Software Version v7.40
ATF Lightning FBUS Flash Started...
Number of Image Files: 3
Forcing Test Mode via BUSCHECK...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051105
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 17F00104
ID DWORD 1 : 1C960052
ID DWORD 2 : E8506414
ID DWORD 3 : DA722F80
ID DWORD 4 : CD912FCA
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 0F
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version 010.050.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 06
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> KAT00F00RA
Revision ID : 0121
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : 24
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.f g
Algorithm File - Version 010.050.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
7DC72D3FDC552426A4479BC820097D304CFB6C15
Scanning Simlock Applet Type...
OK
PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
ERROR : PHONE READ INFO FAILED
Use "BUSCHECK" Button to Force the Phone
into Local Mode... Then "SCANPHONE" after.
For N95, N95-8GB and E90 Phones, you need a
Test Mode Adapter to provide some Extra Power
so that the Phone will go into Local Mode...
ERROR : FAILED TO BACKUP, TRY AGAIN...
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 0F
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Block Length : 09
Data : XSR 1.6
Checksum : 24
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\352000046904813\3520000469048 13_114901.rpl
Processing Image File : C:\5233 - RM-625 - V.40.9.3 - 059F6X6\RM-625_40.9.003_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 13000000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 403
Entry Point: 0x289C52
Page Format : -1
MAX PAGE : 0x00040000
CMT Type : BB5
Page Format : -1
VBATT OFF...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 0F
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Block Length : 09
Data : XSR 1.6
Checksum : 24
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02700000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 09E60000
Partition 4
Start Address : 0F640000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000002680000000000040000000202700000077600 00000000080000000109E60000056200000000000A00000001 0F640000003C0000F7
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x5F (95)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00040000-00082FFF
1 : 00083400-003FFFFF
2 : 00400000-007FFFFF
3 : 00800000-00D5FFFF
4 : 00D60000-09E5FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NOR
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : RM-625_40.9.003_prd.core.C00
Total blocks to write : 403
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*ENO
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:54
Processing Image File : C:\5233 - RM-625 - V.40.9.3 - 059F6X6\RM-625_40.9.003_prd.rofs2.V25
CMT Type : BB5
Number of Blocks : 109
Entry Point: 0x00D7
Page Format : -1
CMT Type : BB5
Entry Point: 0x00D7
Page Format : -1
No partition info....
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 06CE0000-0915FFFF
Time Taken to Erase : 00:00:00
Processing : RM-625_40.9.003_prd.rofs2.V25
Total blocks to write : 109
>> CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash : 00:00:15
Processing Image File : C:\5233 - RM-625 - V.40.9.3 - 059F6X6\RM625_40.1.003_001_003_U002.uda.fpsx
CMT Type : BB5
Number of Blocks : 38
Entry Point: 0x00D1
Page Format : -1
CMT Type : BB5
Entry Point: 0x00D1
Page Format : -1
StartErase_DCT5...
Device Index : 0x00
0 : 09E60000-0F47FFFF
Processing : RM625_40.1.003_001_003_U002.uda.fpsx
Total blocks to write : 38
Time Taken to Flash : 00:00:06
Total Flash Write Time (Flashing Only) : 00:01:16
Total Flashing Time (Booting + Erase + Flashing) : 00:01:19
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 0F
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Block Length : 09
Data : XSR 1.6
Checksum : 24
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Old 04-15-2011, 16:58   #10 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
I flashed with the highest version of navifirm and remains the same, only vibrates with black screen.
Conclude the process but rather to give "SCAN PHONE" I said "ERROR: READ PHONE INFO FAILED
Into Local Mode ... Then "SCANPHONE" after.
Test Mode Adapter to Provide Some Extra Power
That so will go Into the Local Phone Mode ... "
Old 04-15-2011, 17:03   #11 (permalink)
Member: 651945
Flash this to phone...
Old 04-15-2011, 17:04   #12 (permalink)
Member: 447849
Sonork: 100.1604076
Thanks Meter: 593
First Flash With Any Downgrade Firmware You Will Get Error In The End
Then Download Firmware From Navifirm With The Same Product Code Which Is On The Back Label Of Fone & Flash Your Phone
B.r.,
Sonu
Old 04-15-2011, 17:19   #13 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
The flash as exe? and execute? a picture please?
Old 04-15-2011, 17:26   #14 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
I have reached 5530, 5230 with the same error and I've never found a solution, this time I want to get to know what the problem you're 3 nokias.
(There are contacts of the battery)
Old 04-15-2011, 17:37   #15 (permalink)
3zr3vnoc's Avatar
Member: 1102095
Sonork: 0000
Thanks Meter: 55
Already flashed the rm625_ENO_x_09wk43v0.050.fpsx, now what?
Log:
Number of Image Files: 1
Processing Image File : C:\AdvanceBox Turbo Flasher\Nokia\ENO\rm625_ENO_x_09wk43v0.050.fpsx
CMT Type : BB5
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Number of Blocks : 56
Entry Point: 0x01E2
Page Format : -1
CMT Type : BB5
Entry Point: 0x01E2
Page Format : -1
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 0F
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Block Length : 09
Data : XSR 1.6
Checksum : 24
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Partition Info
Device Index : 0x00
Spare : FFFFFFFF
Partition 1
Partition 2
Start Address : 05B20000
Partition 3
Partition 4
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000005AA0000000000040000000205B20000043400 00000000080000000109E60000056200000000000A00000001 0F640000003C0000B2
StartErase_DCT5...
Device Index : 0x00
Device Index : 0x00
Processing : rm625_ENO_x_09wk43v0.050.fpsx
Total blocks to write : 56
Time Taken to Flash : 00:00:04
Total Flash Write Time (Flashing Only) : 00:00:04
Total Flashing Time (Booting + Erase + Flashing) : 00:00:10
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 09:41
only 1800Mhz ?? dofie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-17-2000 21:51
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.38931 seconds with 9 queries
