01-07-2015, 10:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | 5530 write pm-still security test failed-why? ================================================ Product Serial Number: CGL316603 Product Code : 0577077 Module Code : 0204038 Basic Production Code: 0569346 Long Production SN : 0 MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia HW Version : 0802 RFIC Version : 17141716 DSP Version : ICPR72_10w26p1 Content Pack Version : v 30.0.001_001_000_U001 05-03-10 vanilla RM504 AHNE Version : 11 APE SW Core Version : V 40.0.003 Variant Version : V 40.0.003V 40.0.003 V 40.0.003 APE Test Version : 09wk19v0.130 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : EC:9B:5B:B4:699 Bluetooth ID : EC:9B:5B:B4:1B:B9 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST DCC ID : NOT USED write pm details as below SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-504.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 2 Byte(s): 98 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 6 Byte(s): 98 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 98 - Ok Field : 1 Sub : 16 Byte(s): 98 - Ok Field : 1 Sub : 18 Byte(s): 98 - Ok Field : 1 Sub : 20 Byte(s): 98 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 4 - Ok Field : 1 Sub : 26 Byte(s): 110 - Ok Field : 1 Sub : 28 Byte(s): 98 - Ok Field : 1 Sub : 29 Byte(s): 10 - Ok Field : 1 Sub : 31 Byte(s): 98 - Ok Field : 1 Sub : 34 Byte(s): 80 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... still security failed-phone start up failed- is it hardware? |
