Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 05-15-2011, 18:47   #1 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Sonork: 100.1603307
Question 5800 Only Vibrate{Advance-Box+Angel} - [Problem Solved]
HI
I GOT A WORKING 5800 JUST A SOFTWARE PROBLEM
I FLASH THE SET NOW ONLY VIBRATE
INTERESTING THING THAT SET COMING IN TEST AND LOCAL MODE
BUT NOT COMING IN NORMAL MODE
I TRY ENO STILL SAME
HERE IS INFO
MCU: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
IMEI: 357988039056374
Model : Nokia 5800 XpressMusic
Product Serial Number: C9B644748
Product Code         : 0575590
Basic Production Code: 0584488
Default SN Type      : 0
PPM Version          : V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
HW Version           : 1101
RFIC Version         : 17141716
DSP Version          : ICPR72_10w16
AHNE Version         : 11
APE SW Core Version  : V 52.0.007
APE Variant Version  : V 52.0.007V 52.0.007 V 52.0.007
APE Test Version     : eno_version
Retu Version         : 15
Tahvo Version        : 22
APE HW Version       : 256
APE ADSP SW Version  : 256
   ********   Reading SimLock   ********
CONFIG KEY:  0000000000000000
PROVIDER KEY:  2440700000000000
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : ENCRYPTED
PHONE_MODE              : LOCAL MODE
SHOULD I TRY THIS;-5800 just vibration only(solution here)
BUT BACK SIDE WRITTEN MADE BY NOKIA NOT CHINA
OR TRY THIS:-Nokia 5800 5230 5233 5530 Just power on variation tested solution here
IF BSI PROBLEM THAN PHONE NOT COME IN LOCAL MODE
PLZ HELP ME
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 05-15-2011, 20:22   #2 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
First check the RM which is,,,,ALL BACKUP AND FLASH VIA DEAD USB
for many new phones is better usb than fbus
5800 (RM-356) Major 52.0.101 v16 (EMEA)
DOWNLOAD Blue-Nokia.com by Obnoxy
I always succeed
I TESTED WITH MX and UB
Old 05-15-2011, 21:05   #3 (permalink)
lemor's Avatar
Member: 38562
Hi did you try with other battery? If still the same try to flash it with the same product code
The Following User Says Thank You to lemor For This Useful Post:
Old 05-16-2011, 04:20   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Write 504KB PMM File
Old 05-16-2011, 06:10   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Sonork: 100.1603307
where i will find this ppm?????
Old 05-16-2011, 06:58   #6 (permalink)
amyll's Avatar
Member: 502507
Sonork: 100.1620541
Sir for my experienced a lots of 5800 vibrate only, i change uda like this 52.0.007_c04_prd.rofs3.fpsx 947 kb
Old 05-16-2011, 09:04   #7 (permalink)
Member: 973412
Originally Posted by vijay-gsm View Post
HI
HERE IS INFO
Default SN Type      : 0
HW Version           : 1101
AHNE Version         : 11
Retu Version         : 15
Tahvo Version        : 22
PLZ HELP ME
hello bro
1. backup RPL - NPC, CCC, HWC
2. go to EraseFlash tab - tick to CMT and NAND, select 256MB and erase phone
3. flash with product code file, the one which is back at its lable, not new version - should be v30xx, 31xx
4. write backup RPL
5. repair simlocks(online method) from IMEI and Locks tab
6. go to PM tab, click to 'Customized SX4 with SD repair' and authorize it and window will ask to write PM 1 and 309
When all steps complete, your phone should be OK
The Following User Says Thank You to wasibutt For This Useful Post:
Old 05-16-2011, 09:07   #8 (permalink)
Mr.3.'s Avatar
Member: 962029
https://rapidshare.com/files/1724575...4KB_pmm_10.rar
Old 05-16-2011, 12:49   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
@vijay-gsm
dont worry
just backup rpl
reset NPC data put battery and power on the phone 100%phone is alive
now phone is working but imei and sl data damaged if u dont mind
u know befor flashing which version is runing in this phone
yes-restore this version and also restore backup RPL.im sure after restore this rpl phone imei restored but sl and sd data damaged,dont worry phone is sl2 platform just reapir sl and sd data with ATF and also write 1&309 pm
No-No problem just flash this version
RM-356_APAC_21.0.025_v5.0_5800XM
also do it green marked methode
post result
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-16-2011, 13:19   #10 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Sonork: 100.1603307
Originally Posted by shijilfonotly View Post
@vijay-gsm
dont worry:d
just backup rpl
reset npc data put battery and power on the phone 100%phone is alive
yes-restore this version and also restore backup rpl.im sure after restore this rpl phone imei restored but sl and sd data damaged,dont worry phone is sl2 platform just reapir sl and sd data with atf and also write 1&309 pm
no-no problem just flash this version
rm-356_apac_21.0.025_v5.0_5800xm
post result
thanks
soon i will post the report
Old 05-16-2011, 15:01   #11 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Sonork: 100.1603307
GREAT MY SET IS ALIVE AGAIN
THKS TO shijilfonotly
Old 05-16-2011, 15:11   #12 (permalink)
Member: 1559197
Sonork: 100.1604096
but what i did i case of sl3 phone???it set not get local mode how u backup rpl?
Old 05-16-2011, 16:51   #13 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hello.
if in case phone does not get local mode - try ERASE NPC data, this will allow phone to get local mode with damaged IMEI but you can backup PM120
And do NOT forget to make RPL backup before ERASE NPC
Old 05-16-2011, 17:35   #14 (permalink)
Member: 1559197
Sonork: 100.1604096
Originally Posted by ..::Angel::.. View Post
Hello.
sir u can't understand my point...........if i have a sl3 with no local mode........how i backup my npc data????
Old 05-16-2011, 18:06   #15 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
I had same problem in 5530, but i changed the file and download the same version and flashed with mxkee via usb and thd problem solved..........
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.74517 seconds with 11 queries
