03-02-2010, 12:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | 6300 flash 7min 12sec i do not how to make it faster and faster i have used with cable that has vpp, when i plug it, i choose vpp external, it shown error so,i tried flashing without using vpp external, and then gave result 7min 12sec without backup rpl http://www.mediafire.com/file/gyiqmkynklw/6300 flahsing no certificate.rar |
The Following User Says Thank You to aswancamel For This Useful Post: |
03-02-2010, 13:09 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | Then you open "AdvanceBox.ini" and edit this: ;vpp settings ; 0: 00v, 1: 3v, 2:5v, 3: 9v, 4: 12v ;------------ VPP_SET=0 into this: ;vpp settings ; 0: 00v, 1: 3v, 2:5v, 3: 9v, 4: 12v ;------------ VPP_SET=3 Save "AdvanceBox.ini" Then Run the software again with "External VPP" Option Ticked... |
The Following 4 Users Say Thank You to Javajohn For This Useful Post: |
03-02-2010, 13:14 | #3 (permalink) |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | and remember that your vpp cable should be connected like this as shown in image below |
03-02-2010, 16:25 | #4 (permalink) |
Member: 303402 Status: Offline Thanks Meter: 346 | i flashed with vpp enable icluded backup rpl.. it is faster than before here the picture the record is here Code: http://www.mediafire.com/file/jm5jvwz10n4/6300 with vpp backup rpl simlock very ok .rar |
03-02-2010, 18:16 | #7 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: ? Age: 57
Member: 1198691 Status: Offline Sonork: 1589060 Thanks Meter: 148 | Quote:
time will be more better ..in newer release.. vpp should make stable providing correct volts. this needed to boost all new bb5 models flashing | |
03-02-2010, 19:38 | #8 (permalink) |
Member: 303402 Status: Offline Thanks Meter: 346 | finally, i got 5 min... faster than before i was using ufc combo with vpp enable here the picture here the video http://www.mediafire.com/?j4mzgdnneg2 but something miss in the phone, no content file.. the gallery is empty, no application, and soon i hope that it will fix by adding 128x force thanks br aswancamel |
03-02-2010, 19:47 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @aswancamel Thanks for reporting. Actually we thought we already solved this bug before. Can you tell me which firmware version of the RM-217 you are using? B.R. X-Shadow |
03-03-2010, 05:33 | #11 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | As u r saying There is no content file means all empty gallery,images etc. to fix this u can use 7.21_image_128 file as cnt....u will find it in product folder... wbr... |
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post: |
03-03-2010, 05:33 | #12 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | @aswancamel About content file i manage to flash now 6300 v.7.30 without any problem in content file.. |
The Following User Says Thank You to lemor For This Useful Post: |
03-03-2010, 05:56 | #13 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | @aswancamel same with lemor, about content file use same file with you with vpp enable no problem and all working good.. Ps gak masalah bos..semua lancar2x saja.. |
The Following User Says Thank You to titan_wonder For This Useful Post: |
Hp 6300 flash file? | hvelect | Various | 1 | 04-09-2010 17:07 |
7210 flash 7min 10 sec | aswancamel | Advance-Box | 5 | 03-02-2010 09:13 |
6300 flashing Error preparing flashing... | mobiletuch | Nokia Hardware & Hardware Repair | 7 | 12-05-2009 14:34 |
6300 Flashing. | danieldenham | Nokia Base Band 5 ( BB-5 ) | 0 | 04-05-2007 18:10 |
