04-23-2011, 17:00 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | 6500s just nokia after flash same ATF Box FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1316 Entry Point: 0x4532 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1316 Entry Point: 0x4532 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0D200107 ID DWORD 1 : DBD47C56 ID DWORD 2 : A21AC316 ID DWORD 3 : 26217561 ID DWORD 4 : 712D5F3A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 52 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x2E (46) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00040000-000BFFFF 2 : 000C0000-0013FFFF 3 : 01480000-015FFFFF 4 : 00140000-0147FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:26 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30.mcusw Total blocks to write : 1316 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:42 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30.ppm_c CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 411 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 411 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01600000-01CBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:27 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30.ppm_c Total blocks to write : 411 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:33 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30_ISM_001.image_c_tr_ctv_tr CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 736 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 736 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01FC0000-03F9FFFF 1 : 01CC0000-01FBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:11 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30_ISM_001.image_c_tr_ctv_tr Total blocks to write : 736 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:54 Total Flash Write Time (Flashing Only) : 00:03:09 Total Flashing Time (Booting + Erase + Flashing) : 00:06:14 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data FAILED FACTORY SET TO : Leave Factory FAILED FACTORY SET TO : Service Center FAILED FACTORY SET TO : Software Upgrade FAILED FACTORY SET TO : Production Tune FAILED FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data FAILED FACTORY SET TO : Leave Factory FAILED FACTORY SET TO : Service Center FAILED FACTORY SET TO : Software Upgrade FAILED FACTORY SET TO : Production Tune FAILED FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data FAILED FACTORY SET TO : Leave Factory FAILED FACTORY SET TO : Service Center FAILED FACTORY SET TO : Software Upgrade FAILED FACTORY SET TO : Production Tune FAILED |
04-24-2011, 07:18 | #6 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Egypt Age: 39
Member: 367220 Status: Offline Thanks Meter: 28 | SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK |
04-24-2011, 14:18 | #10 (permalink) | |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | Quote:
http://www.mediafire.com/?9ssx5664vf5972c | |
04-24-2011, 14:36 | #11 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | iwell try full erase no use ATF Software Version v7.40 ATF Box FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1316 Entry Point: 0x4532 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1316 Entry Point: 0x4532 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0D200107 ID DWORD 1 : DBD47C56 ID DWORD 2 : A21AC316 ID DWORD 3 : 26217561 ID DWORD 4 : 712D5F3A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 52 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : C5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x2E (46) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00040000-000BFFFF 2 : 000C0000-0013FFFF 3 : 01480000-015FFFFF 4 : 00140000-0147FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:05 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30.mcusw Total blocks to write : 1316 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:51 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30.ppm_c CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 411 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 411 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01600000-01CBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:06 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30.ppm_c Total blocks to write : 411 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:34 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\rm240__10.30_ISM_001.image_c_tr_ctv_tr CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 736 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 736 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01FC0000-03F9FFFF 1 : 01CC0000-01FBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:08 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz ChangeClock 2 Processing : rm240__10.30_ISM_001.image_c_tr_ctv_tr Total blocks to write : 736 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:58 Total Flash Write Time (Flashing Only) : 00:03:24 Total Flashing Time (Booting + Erase + Flashing) : 00:03:49 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data FAILED FACTORY SET TO : Leave Factory FAILED FACTORY SET TO : Service Center FAILED FACTORY SET TO : Software Upgrade FAILED FACTORY SET TO : Production Tune FAILED |
