08-19-2013, 17:38 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Dublin Age: 43
Member: 25852 Status: Offline Thanks Meter: 31 | 6630 Killed by ATF Here is the log ================================================ Extended Phone Information ================================================ Product Serial Number: UD0838373 Product Code : 0529311 Basic Production Code: 0600395 MCU SW Version : V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. HW Version : 6100 RFIC Version : 150a160e DSP Version : 04w36v15 LCD Version : 2723348 AHNE Version : 21 APE SW Core Version : V 2.39.15 11-11-04 RM-1 (c) NOKIA. Variant Version : V 2.39.15-Euro1 11-11-04 RM-1 (c) NOKIA. RETU Version : 32 TAHVO Version : 41 APE HW Version : 256 APE ADSP SW Version : 37047 Bluetooth ID : 00:11:9F:C2:BB:B8 ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. IMEI Plain : 354349003717074 IMEI Spare : A354349003717070 IMEI SV : 33543490037170704F Phone Model: Nokia 6630 Category : Imaging Phone Phone Type : RM-1 ================================================ Extended Phone Information ================================================ Product Serial Number: UD0838373 Product Code : 0529311 Basic Production Code: 0600395 MCU SW Version : V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. HW Version : 6100 RFIC Version : 150a160e DSP Version : 04w36v15 AHNE Version : 21 RETU Version : 32 TAHVO Version : 41 Bluetooth ID : 00:11:9F:C2:BB:B8 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 PHONE_MODE : LOCAL Tryed repair SD data no LUCK Flashed Full PM via SX4 no LUCK Getting pissed now nothing seems to be working ...... STILL SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 Anyone have a solution a good PM maybe cuz i can't find it in the folder ... |
08-26-2013, 13:32 | #4 (permalink) |
Member: 25852 Status: Offline Thanks Meter: 31 | done still the same , Basic Phone Information ================================================ MCU Version: V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. IMEI Plain : 354349003717074 IMEI Spare : A354349003717070 IMEI SV : 33543490037170704F Phone Model: Nokia 6630 Category : Imaging Phone Phone Type : RM-1 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-1.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 1 Byte(s): 4 - Ok Field : 1 Sub : 2 Byte(s): 86 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 5 Byte(s): 4 - Ok Field : 1 Sub : 6 Byte(s): 86 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 86 - Ok Field : 1 Sub : 15 Byte(s): 4 - Ok Field : 1 Sub : 16 Byte(s): 86 - Ok Field : 1 Sub : 18 Byte(s): 86 - Ok Field : 1 Sub : 20 Byte(s): 86 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 16 - Ok Field : 1 Sub : 29 Byte(s): 6 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... ================================================ Basic Phone Information ================================================ MCU Version: V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. IMEI Plain : 354349003717074 IMEI Spare : A354349003717070 IMEI SV : 33543490037170704F Phone Model: Nokia 6630 Category : Imaging Phone Phone Type : RM-1 ================================================ Extended Phone Information ================================================ Product Serial Number: UD0838373 Product Code : 0529311 Basic Production Code: 0600395 MCU SW Version : V 2.0436v22.1 11-11-04 RM-1 (c) NOKIA. HW Version : 6100 RFIC Version : 150a160e DSP Version : 04w36v15 LCD Version : 2723348 AHNE Version : 21 APE SW Core Version : V 2.39.15 11-11-04 RM-1 (c) NOKIA. Variant Version : V 2.39.15-Euro1 11-11-04 RM-1 (c) NOKIA. RETU Version : 32 TAHVO Version : 41 APE HW Version : 256 APE ADSP SW Version : 37047 Bluetooth ID : 00:11:9F:C2:BB:B8 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 PHONE_MODE : LOCAL DCC ID : NOT USED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... DONE THAT LIKE 5 TIMES TRYED TO RESTORE FROM RPL NO F***** LUCK ..... SPEND ON THIS PHONE MORE TIME THAN IS ACTUALLY WORTH .....BUT CUSTOMER ISN'T HAPPY .... its pointless just wait for mx key new box and fix it properly ..... |
