02-17-2013, 00:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | 6730c flashing aborted I tried to flash a nokia rm-547 (6730c) in all ways but always flashing aborted .. could be a hardware problem? I state that this first Nokia was dead, and only after rehot are able to do so via Fbus Advance detects the .. Thank to all |
02-17-2013, 01:23 | #2 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 44
Member: 61667 Status: Offline Thanks Meter: 13 | did u hit in bus check or scan phone before flashing its seems ur rpl was already damage or may have hardware prob n u flashed it bro now try to wash n clean board heat all board n flash again via fbus cable if u wanna thanks me add me here n tell the status https://www.facebook.com/rizwan.sayyed.5 |
The Following User Says Thank You to 12ka4 For This Useful Post: |
02-17-2013, 13:53 | #5 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | 6730c flashing aborted hello atf version : ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.30 Software Version : v9.51 AdvanceBox SN : D4E7DB22925C6282B509ECC4 Box Status : ACTIVATED ========================== |
02-19-2013, 09:44 | #11 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | SOLVED " partly " 6730C FLASHING ABORTED Hello to all I tried it with a second rehot then the USB connection worked but still the same problem .. I formatted the flash and always with USB I downloaded the latest firmware but error SUPERDONGLE TEST FAILED> REPAIR USING FBUS CABLE> TRY WITH CUSTOMIZED SXA SD REPAIR> THEN WRITE PM AND 1 AM 309, runs ........ successfully with FBUS The mobile phone but 'has no signal and I always requires vodafone sim that still has the same problem .. any help thanks finally log 01.00.10 : ================================================ 01.00.10 : Simlock Information 01.00.10 : ================================================ 01.00.11 : CONFIG KEY : 0000000000000000 01.00.11 : PROVIDER KEY : 2440700000000000 01.00.11 : NETWORK NAME : Nokia Default;Finland 01.00.11 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 01.00.11 : SIMLOCK TABLE : 01.00.11 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 01.00.11 : SIMLOCK STATE : Not Locked 01.00.11 : 01.00.11 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK) 01.00.11 : SIMLOCK_TEST : PASSED 01.00.11 : SECURITY_TEST : PASSED 01.00.11 : SECURITY_CODE : ENCRYPTED 01.00.12 : PHONE_MODE : LOCAL 01.00.20 : 01.00.20 : WARNING: DCC Unavailable in Current State 01.00.20 : Change Phone Mode to TEST MODE 01.00.22 : 01.00.22 : 01.00.22 : ================================================== ==== 01.00.22 : Selected VPL File: 01.00.22 : RM547_0583017_031.022_005.vpl 01.00.22 : ================================================== ==== 01.00.22 : Variant Details : 6730 RM-547 Vodafone IT IT Free Navi Black V3 01.00.22 : Software Version : 031.022 01.00.22 : Product Type : RM-547 01.00.22 : Product Code : 0583017 01.00.22 : Variant Version : 005 01.00.22 : |
