08-19-2010, 10:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ✚✚✚✚✚✚✚✚✚✚ 7020 Full Flash with RPL Backup via USB (BroadCom CPU) RM-497 ✚✚✚✚✚✚✚✚✚✚ RPL ok, PM 0-400 ok, Flash ok Code: Number of Image Files: 3 Processing Image File : rm497__08.10.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 458 Entry Point: 0x01E2 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm497__08.10.ppm_a CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 117 Entry Point: 0x00FA Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm497__08.10_ISM_003.image_a_0579274_ctv_fi CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 291 Entry Point: 0x0134 Page Format : -1 MAX PAGE : 0x0000E000 @oem49.inf,%generic7020%;Nokia 7020 USB Generic []: Found 1 active devices. [Nokia 7020 USB Generic]: Opening Connection [Nokia 7020 USB Generic]: Port opened OK! SW: V 08.10 15-04-10 RM-497 (c) Nokia IMEI: 356073038734114 CONFIG KEY: 8000000000000002 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Application_NEW\Nokia\Backup\356073038734114\USB_FULL_BACKUP_V 08.10 15-04-10 RM-497 (c) Nokia_356073038734114_Not Locked_54828.pm Reading battery value : 3894 mV AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 cmt hardware : 200C0000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005331 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 6E02E601 ID DWORD 1 : 02F52C3D ID DWORD 2 : 55D2F9EE ID DWORD 3 : 27092EB5 ID DWORD 4 : 7E7215B8 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A START FLASHING RawLoaderExtract: Processing rm497__08.10.mcusw Match LOADER : C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_usb2nd.fg Loader Uploaded..... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00800000 (8388608) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 ROOTHASH : 1B0D74C532CA1C6133940C740E8C786E Match File.....C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_XSR16_usbalg.fg Done! FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 356073038734114 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Application_NEW\Nokia\Backup\356073038734114\356073038734114_54840.rpl Pabub KEY Request C5012A150057B0CD145768F65CDF89F47F1FAE61BF16EF7DD7A50000000000000000 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : RND ASIC Index : CMT 0 Certificate 5 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00020000 Size : 027E0000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00020000 Size : 027E0000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00020000 Size : 027E0000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00020000 Size : 027E0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000027E000000000008000000010280000004D400000000000A0000000107540000006000000000000B0000000107B4000000180000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x0080 (128) ERASE Blocks : 0x0003 (3) erase blocks : 3 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00020000-000203FF 2 : 00060000-01FFFFFF CurrPos : 20 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A000000010000000200000064000000020000000200000001000000000000 CurrPos : 51 CurrEraseLen : 2F 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000B000000000000000200000064000000020000000200000001000000000000 ERASE_REQUEST_BB5 : 5003120B000300000000000001FFFF120B00030000020000000203FF120B0003000006000001FFFFFF93 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000100000002000000640000000200000002000000010000000000003B ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B0000000000000002000000640000000200000002000000010000000000003B Successfully erased.. Total blocks to write : 458 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : GENIO_INIT StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02000000-027FFFFF ERASE_REQUEST_BB5 : 5001120B00030002000000027FFFFF5D Successfully erased.. Total blocks to write : 117 StartErase_DCT5... BlockLength : 0x003F (63) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02800000-0753FFFF CurrPos : 10 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 0000000000000008000000000000000200000064000000020000000200000001000000000000 ERASE_REQUEST_BB5 : 5001120B000300028000000753FFFF04 ERASE_REQUEST_BB5 : 5001192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000003E Successfully erased.. Total blocks to write : 291 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:27 (Booting time is NOT Included) Waiting for Phone to Start-Up...(Max 100 seconds) Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... Elapsed Time: 25 Seconds... Elapsed Time: 30 Seconds... Elapsed Time: 35 Seconds... Elapsed Time: 40 Seconds... Elapsed Time: 45 Seconds... Elapsed Time: 50 Seconds... Elapsed Time: 55 Seconds... Elapsed Time: 60 Seconds... Elapsed Time: 65 Seconds... Elapsed Time: 70 Seconds... Elapsed Time: 75 Seconds... SW: V 08.10 15-04-10 RM-497 (c) Nokia IMEI: 356073038734114 CONFIG KEY: 8000000000000002 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 12345 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK |
The Following 8 Users Say Thank You to Advance-Box For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
