Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-12-2012, 13:52   #1 (permalink)
Alex1234's Avatar
Member: 31044
7203 RM-604 can't boot, need help
I have one 7230 RM-604? what need to write RPL.
I try all pinouts from there, add 2 resistors on Enable, but no luck(
Info is readings Ok:
Basic Phone Information
MCU Version: V 10.81 28-02-11 RM-604 (c) Nokia
IMEI Plain : 355365048424269
IMEI Spare : A355365048424260
IMEI SV : 33553650484242666F
Phone Model: Nokia 7230
Category : Entry Phone
Phone Type : RM-604
Extended Phone Information
Product Serial Number: HFH134815
Product Code : 059B9P8
Module Code : 0204267
Basic Production Code: 0585700
Long Production SN : 0
PPM SW Version : V 10.81 28-02-11 RM-598 (c) Nokia I
BT MCM Version : 1673-46038
MCU SW Version : V 10.81 28-02-11 RM-604 (c) Nokia
RFIC Version : |Vapaus_5.1 | Mikki_1.1
DSP Version : SPR91_10.80c
LCD Version : SEIKO
Content Pack Version : Content: i_059B1Q7 V 10.81 28-02-11 RM-604 (c) Nokia
AHNE Version : 41
RETU Version : 40
TAHVO Version : 00
Bluetooth ID : 9C:4A:7B:F4:29:58
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII
Simlock Information
Unable to read SP Data..
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
PHONE_MODE : LOCAL
But Check not work!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02044100
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 1CC00104
ID DWORD 1 : 54A85540
ID DWORD 2 : 6E4A9D5D
ID DWORD 3 : 91CABE3B
ID DWORD 4 : 123156CB
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
Checksum 56
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
Boot File - Version 012.08.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
ERROR: Phone did not respond...
ERROR: Sending Loader Failed...
ERROR: FBUS Boot FAILED
What i do wrong?
Old 07-12-2012, 19:42   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@Alex1234
It's your cable problem, use this pinouts:
New FBUS Pinouts for 205 / 2050 Added
However, you can also use USB cable in order to write RPL file.
Old 07-13-2012, 07:34   #3 (permalink)
Alex1234's Avatar
Member: 31044
Originally Posted by ..::Angel::.. View Post
@Alex1234
Pinout the same with mine, not works.
On another phone with same pinout(3710a) cable also not works, with same error.
Of cause i alraedy write RPL by USB, but i want working FBus cable
Old 07-13-2012, 10:17   #4 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Make a fresh installation of ATF Setup v8.90, after update EXE to 8.95 minor released, and do update important files...
PS: remove all old setup installed in PC, and remove AdvanceBox Turbo Flasher folder from C:/ before you make a fresh install.
PS2: make sure you cable has dual MBUS line connected togather, as these phone requires it to be connected togather.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.25067 seconds with 11 queries
