02-13-2013, 10:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | 800 after unlock making problem with windows7.8 <<< SOLVED - Solution inside >>> But it goes to Switch Off when it searching networks. Here is the log Code: ====================================================== Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0077E3F8 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:07 When he made update then it was locked. Phone ver si Software: windows@phone 7.8 Os ver : 7.10.8858.136 Firmware R number : 1750.0823.8858.12460 Hardware R number : 112.1402.2.4 Radio Software Ver : 1.7.50.08 Radio Hardware ver : 8255 Bootloader ver : 7.35.0.0 Chip SOC Ver 0.74.2.1 Mac Address : F4-8E-09-CE-35-FE Rm-801, Product Id : 059N705 Without Sim Phone is Ok. All operation is working fine. I think this is software problem. But i am confused , Please help me how to solve this problem.... Last edited by sanjoychy; 02-13-2013 at 10:34. |
02-13-2013, 22:50 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | Quote:
Lumia 800 is hardware related unlock by ATF .so pls check carefully network section again .maybe in network section doing some fault . Without SIM card press 112 and make dialled .if your set goes to power off its hardware related issue . I have a sad story about lumia 800.last 2 weeks ago I am received a lumia 800 just for upgrade from customer .after few updated flash is stop by ATF and set dead .then 3-4 days I am still tried to flash again with ATF also other box .but no success .then I repaired boot with tp and flash the phone again .after boot repair set goes on .but charging problem .charging continue but not saved in battery .i am removed a diot near by tp area .i was fully confrimed due to this Diot charge not loaded .added new Diot in correct mother board place and now set fully ok .after 7 days working hard when I am ready to delivery to customer he don't accept his set .i am open his set without permission And I Am damaged his set warranty .he bring it from Italy .also some scratch are whole touch area.finally he decide he don't received this set from me .finally I need to give him no open And spotless lumia800.now I am searching Fresh lumia 800 for given damarage! | |
02-16-2013, 07:01 | #4 (permalink) | ||
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
My phone is Ok. After Flash I Just Unlock again. And Working fine Now. Quote:
