08-23-2016, 12:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india-gujrat-nadiad
Member: 384984 Status: Offline Thanks Meter: 456 | 9008 port show only ? write protacation is on so i connect phone to atf with emmc adaptor & i remove write protation 2 i write full dump after write dump phone show onlu 9008 port in device menajor i also take this opration normal formet 2 samsung former 3 samsung emmc firmwere update + formet 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D3847325943006809644CA001 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 6809644C Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D3847325943006809644CA001.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ================================================== ==== Loading ATF MMC File... (Please Wait) ================================================== ==== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 520 RM-914 BIG BOOT V2 [3056.40000.1408.0007] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 3 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 4 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 5 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 6 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 7 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 8 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 9 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 10 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 11 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 12 Start Writing Blocks... Writing Blocks Done! Perform Firmware Flashing via USB Connection Total Elapsed Time 00:05:06 Write Success! Last edited by suneel; 08-23-2016 at 12:53. |
