Activation Problem after latest Update and firmware - (SERVER SOLVED) Activation Problem after latest Update and firmware CONTACT ATF PRODUCT SUPPORTER ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software PS: I have this box since come to market, dont remember where i have buy the box :( |
@schwantz Please Post BoX SN. Did you just try to activate once? B.R. |
Hi, this is not a problem. From v11.00, we implemented RSA Signing Server for AdvanceBox.exe Follow steps given by ATF software, a activation key will be made on your PC and than you can start using AdvanceBox.exe again BR |
Already try many times and no sucess :( AdvanceBox SN : D6FC4AB9E1A53824D3F83E4B CONTACT ATF PRODUCT SUPPORTER |
@schwantz Try now. It should be OK already. B.R. |
Done thanks :) PS: Can i use the box in another PC??? Because i use 2 pc's |
@schwantz Yes you can. RSA Signing is just for Statistical Purposes... You can use it on more than 1 PC just like before. B.R. |
same issue Please Try Again Later (Server Busy) sn : C4A57394F51149D4EB287944 ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software tried to restore box result request empty activate box result request empty |
and kindly give us some sort of backup activation registry option if you are going to run activation system |
Br - srinibas |
Server Back to function :):):) Br - srinibas |
atf box activation problem pls help me Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. I have format the system yesterday and install atf now it will ask for activation. Before it works fine. Why the Distributor/Reseller request for disable? |
same here AdvanceBox SN : AF35AC4D9698B66C96774113 Box Status : NOT ACTIVATED |
Check now. Server has been rebooted |
Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: http://forum.gsmhosting.com/vbb/f609/ |
