Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-03-2014, 15:31   #1 (permalink)
schwantz's Avatar
Member: 4975
Thanks Meter: 637
Activation Problem after latest Update and firmware - (SERVER SOLVED)
CONTACT ATF PRODUCT SUPPORTER
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
PS: I have this box since come to market, dont remember where i have buy the box
The Following 2 Users Say Thank You to schwantz For This Useful Post:
Old 02-03-2014, 15:36   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,059
@schwantz
Please Post BoX SN.
Did you just try to activate once?
B.R.
Old 02-03-2014, 15:37   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,528
Hi, this is not a problem. From v11.00, we implemented RSA Signing Server for AdvanceBox.exe
Follow steps given by ATF software, a activation key will be made on your PC and than you can start using AdvanceBox.exe again
Old 02-03-2014, 15:53   #4 (permalink)
schwantz's Avatar
Member: 4975
Thanks Meter: 637
Already try many times and no sucess
AdvanceBox SN : D6FC4AB9E1A53824D3F83E4B
Old 02-03-2014, 16:11   #5 (permalink)
Member: 651945
@schwantz
Try now. It should be OK already.
B.R.
Old 02-03-2014, 16:27   #6 (permalink)
schwantz's Avatar
Member: 4975
Thanks Meter: 637
Done thanks
PS: Can i use the box in another PC???
Because i use 2 pc's
Old 02-03-2014, 16:37   #7 (permalink)
Member: 651945
@schwantz
Yes you can.
RSA Signing is just for Statistical Purposes...
You can use it on more than 1 PC just like before.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 05-15-2014, 15:06   #8 (permalink)
Member: 1754148
Sonork: 12345
same issue
Please Try Again Later (Server Busy)
sn : C4A57394F51149D4EB287944
tried to restore box result request empty
activate box result request empty
Old 05-15-2014, 15:10   #9 (permalink)
Member: 1754148
Sonork: 12345
and kindly give us some sort of backup activation registry option if you are going to run activation system
Old 05-15-2014, 16:20   #10 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,271
Originally Posted by qualitymobile View Post
same issue
Please Try Again Later (Server Busy) Soon it will back to work
Br - srinibas
Old 05-15-2014, 16:26   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Server Back to function
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 05-15-2014, 17:03   #12 (permalink)
sunil002's Avatar
Member: 1212786
Sonork: 100.1626896
Thanks Meter: 18
atf box activation problem
pls help me
Your Box Distributor/Reseller has requested that your Box should be Disabled.
Please Contact your Box Distributor/Reseller and settle the Problem.
I have format the system yesterday and install atf now it will ask for activation. Before it works fine. Why the Distributor/Reseller request for disable?
The Following User Says Thank You to sunil002 For This Useful Post:
Old 05-15-2014, 17:24   #13 (permalink)
Member: 1836708
Sonork: GaFFeR
Thanks Meter: 2
same here
AdvanceBox SN : AF35AC4D9698B66C96774113
Box Status : NOT ACTIVATED
The Following User Says Thank You to gaffer1982 For This Useful Post:
Old 05-15-2014, 17:41   #14 (permalink)
Member: 651945
Check now. Server has been rebooted
Old 05-16-2014, 08:34   #15 (permalink)
sunil002's Avatar
Member: 1212786
Sonork: 100.1626896
Thanks Meter: 18
same problem. Restore Box Success. But Activation Problem
If you think you are getting this Message by Mistake, please visit ATF Support:
http://forum.gsmhosting.com/vbb/f609/
Page generated in 0.16800 seconds with 7 queries
