Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-15-2019, 12:03   #241 (permalink)
mr_meralikhil's Avatar
Member: 784983
Sonork: 100.1676767 QQ 1125933349
Thanks Meter: 39
Driver Version : 00021206
Library Version : 00030210
Box Type : AdvanceBox Turbo
Box Firmware : LogiCore 11.0.10
Software Version : v12.67
AdvanceBox SN : 8596A02FC599289B9A8FDD48
Old 04-17-2019, 05:05   #242 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
Atf activate
Originally Posted by CHAUDHRAY ARSHAD View Post
Advance Turbo Flasher Found
AdvanceBox SN : F3B8D785AA2C3E24FE2BCA29
Please Try Again Later (Server Busy)
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Hi is simple if u no how to delete the host file go and delete the host file then try again it will activate i hop it will work for you 👍if u don't no let me know
Old 04-17-2019, 05:07   #243 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
Atf activate
Originally Posted by Armkar View Post
Please Help Me activate my Box
Box Type : ATF Nitro
Software Version : v12.70
AdvanceBox SN : C7DD3B768DED5191ADC507F6
SET BSI Load Done
Old 04-17-2019, 05:12   #244 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
For ATF activation i solved the problem only Delete the host file and retry it will activate
Old 04-17-2019, 05:25   #245 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
Old 04-17-2019, 05:34   #246 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
SET BSI Load Done
Old 04-17-2019, 05:35   #247 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
Atf activate
AdvanceBox SN : 8D0CE54CC22D699DDD4B74A7
Box Status : NOT ACTIVATED
Old 04-17-2019, 05:38   #248 (permalink)
Member: 1585460
Sonork: 6678600
Thanks Meter: 3
Cool Atf activate
Originally Posted by anakbatam View Post
activation not available contact your reseller
Your Box Distributor/Reseller has requested that your Box should be Disabled.
Please Contact your Box Distributor/Reseller and settle the Problem.
If you think you are getting this Message by Mistake, please visit ATF Support:
Advance-Box - GSM-Forum please help me sir...
Old 04-17-2019, 06:43   #249 (permalink)
deepanshu_ag's Avatar
Member: 1239360
Thanks Meter: 58
not done after delete hosts file..... Please Try Again Later (Server Busy)
Old 04-17-2019, 09:23   #250 (permalink)
Member: 669066
Atf
Please help mi
AdvanceBox SN : B10F3253E6104683FDD498F1
SET BSI Load Done
Old 04-17-2019, 12:19   #251 (permalink)
Member: 2541648
Thanks Meter: 67
Library Version : 00030207
Software Version : v12.60
AdvanceBox SN : 4BF3C2B53E60FCFDCBC323DA
SET BSI Load Done
Old 04-17-2019, 14:10   #252 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 174
You can delete hosts, windows and other. But server is absent. It seems that its not payed because project is dead.
Old 04-17-2019, 15:38   #253 (permalink)
Member: 2541648
Thanks Meter: 67
can you tell me how to do that
Page generated in 0.26105 seconds with 7 queries
