05-22-2014, 08:38 | #31 (permalink) |
Junior Member Join Date: Apr 2013 Location: siliguri
Member: 1916173 Status: Offline Sonork: 100.1597111 Thanks Meter: 0 | Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : AE2E9704D7F2F90D8BD5BEA9 CONTACT YOUR RESELLER pls solv this problem. |
05-22-2014, 09:14 | #33 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Surabaya
Member: 247433 Status: Offline Thanks Meter: 25 | Please help me...thanks Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN: E2F6AE22FFA4097A8F6BC642 ================================================ CONTACT YOUR RESELLER ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Sof |
05-22-2014, 09:44 | #34 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Iran Age: 36
Member: 103435 Status: Offline Thanks Meter: 49 | same ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.20 AdvanceBox SN : AE9CF3B0C0FF2BC1EE455FA1 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-22-2014, 09:52 | #35 (permalink) |
Insane Poster Join Date: Dec 2006 Location: romania
Member: 407773 Status: Offline Thanks Meter: 22 | Same problem. Tried 20 times but always invalid handle error. ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 8B7CBA059B10CDAFAF05EFD5 CONTACT YOUR RESELLER ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
05-22-2014, 10:01 | #36 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Satcom Bangalore INDIA Age: 53
Member: 17098 Status: Offline Thanks Meter: 51 | Dear Support Team Pls Helpme... ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : BCAC4D1CE88BE913EBB88262 CONTACT YOUR RESELLER ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Thanks B.R Saro |
05-22-2014, 10:29 | #38 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 42
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | Quote:
WBR qwerthj | |
05-22-2014, 11:22 | #39 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 387370 Status: Offline Thanks Meter: 8 | AdvanceBox SN : A04F62AA87E2F3298D52EE3E ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software i have tired many times but same problem..please solve this problem?? |
05-22-2014, 11:45 | #40 (permalink) |
Insane Poster Join Date: Apr 2003
Member: 26567 Status: Offline Thanks Meter: 10 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020828 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 90558BACE7F09E44A0865F0C ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done some time CONTACT YOUR RESELLER thx..BR |
05-22-2014, 11:49 | #41 (permalink) |
No Life Poster Join Date: Jul 2012 Location: kashmir, india
Member: 1781818 Status: Offline Sonork: 100.1652308:ashaq Thanks Meter: 130 | i have aft box last time run ok i format my pc and install atf box then this error comes Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : 8D88FB1FC22479C3F388B7D8 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done i have connected internet connection reisntall windows but still smae please help me thanks |
05-22-2014, 12:19 | #42 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Kerala
Member: 207196 Status: Offline Sonork: 100.1646173 Thanks Meter: 15 | same error pls help me .i format my pc after get this error Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : A22009E5B1626458BA956215 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-22-2014, 12:31 | #43 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Online Imeis Codes Unlockings
Member: 1715845 Status: Offline Sonork: 100.1596500 Thanks Meter: 195 | Same Problim Help ATF Team ........... ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : C6255A7CCA099740E2E11AE6 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-22-2014, 13:35 | #44 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1603029 Status: Offline Thanks Meter: 20 | Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : A77180D399E11E2FD3744757 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done please help me to activate my box |
05-22-2014, 13:39 | #45 (permalink) |
Registered User Join Date: Apr 2007 Location: ir th
Member: 497475 Status: Offline Sonork: 100.1639072 Thanks Meter: 83 | Hi After restore and Update my box . need Active Box Type : ATF Nitro Software Version : v11.30 AdvanceBox SN : 9556F287AEC2BE45C3EE67D1 Box Status : NOT ACTIVATED Pls Active my box |
